Windows 7 Command Line Console Closes Immediately After Opening - Possible Fixes
Lasek001 15477 13
Why does the Windows 7 Command Prompt open briefly and close, while a Library window also opens at login, and how can it be fixed?
The behavior was caused by a suspicious Winlogon Shell configuration associated with an infection, which launched cmd.exe, checked for SoundMixer.exe, and started Explorer or the Library window [#16837358] Run FRST for the correct Windows version, review its logs, uninstall Spybot, and apply the supplied Fixlist to remove the suspicious scheduled tasks, Spybot remnants, and related entries [#16836256] [#16837973] After the repair, neither the unwanted command window nor the Library window started, and the problem was resolved without formatting Windows [#16839721]
  • #1 16836128
    Lasek001
    I do not want to turn on the command line, i.e. when entering "cmd" in the run, a console (a small window) appears for a moment, then closes immediately. I also noticed that when logging in to the account (when the desktop appeared), the console opens and the "Library" folder starts running for me. I tried to start the computer in an emergency - it did not help. Windows 7
    I would ask for help in this matter.
  • #2 16836145
    krzychupar
    Help: 1490
    Rate: 633
    Other commands in run work? Have you tried to run as an administrator?
  • #3 16836150
    Kasek21
    Help: 4981
    Rate: 3547
    After selecting a command line from the start menu is the same?
  • #5 16837237
    Lasek001
    Yes, everything works in run, except "cmd". I tried to run as an administrator. I always open a command line from the start menu. It does not work either from the menu, folder and .bat (start cmd.exe start blabla.exe)
    Please, scan in the attachment.
    • Addition.txt (36.96 KB) You must be logged in to download this attachment.
    • FRST.txt (30.31 KB) You must be logged in to download this attachment.
  • Malicious winlogon cmd.exe startup entry found
    #6 16837358
    krzychupar
    Help: 1490
    Rate: 633
    Otwórz notatnik systemowy i wklej:
    ContextMenuHandlers1: [SDECon32] -> {44176360-2BBF-4EC1-93CE-384B8681A0BC} => C:\Program Files (x86)\Spybot - Search & Destroy 2\SDECon64.dll -> Brak pliku
    ContextMenuHandlers1: [SDECon64] -> {44176360-2BBF-4EC1-93CE-384B8681A0BC} => C:\Program Files (x86)\Spybot - Search & Destroy 2\SDECon64.dll -> Brak pliku
    ContextMenuHandlers5: [igfxcui] -> {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => -> Brak pliku
    ContextMenuHandlers6: [SDECon32] -> {44176360-2BBF-4EC1-93CE-384B8681A0BC} => C:\Program Files (x86)\Spybot - Search & Destroy 2\SDECon64.dll -> Brak pliku
    ContextMenuHandlers6: [SDECon64] -> {44176360-2BBF-4EC1-93CE-384B8681A0BC} => C:\Program Files (x86)\Spybot - Search & Destroy 2\SDECon64.dll -> Brak pliku
    Task: {1E0513C6-CE77-4432-8166-29B4B5E022B0} - C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser => Command(1): %windir%\system32\rundll32.exe -> aepdu.dll,AePduRunUpdate -nolegacy
    HKLM-x32\...\Run: [SDTray] => "C:\Program Files (x86)\Spybot - Search & Destroy 2\SDTray.exe"
    HKU\S-1-5-21-3728886683-294045490-3694822398-1000\...\Run: [AdobeBridge] => [X]
    HKU\S-1-5-21-3728886683-294045490-3694822398-1000\...\MountPoints2: {0eacd0b2-762a-11e7-bc4b-fcaa14240824} - H:\startme.exe
    HKU\S-1-5-21-3728886683-294045490-3694822398-1000\...\MountPoints2: {75adcb9b-58ad-11e7-b702-fcaa14240824} - H:\HiSuiteDownLoader.exe
    HKU\S-1-5-21-3728886683-294045490-3694822398-1000\...\Winlogon: [Shell] C:\Windows\System32\cmd.exe [345088 2010-11-21] (Microsoft Corporation) NUL | find /I /N "SoundMixer.exe">NUL && exit & if exist "C:\Users\dmNen\AppData\Roaming\Microsoft\SoundMixer\SoundMixer.exe" ( start /MIN "" "C:\Users\dmNen\AppData\Roaming\Microsoft\SoundMixer\SoundMixer.exe" & tasklist /FI "IMAGENAME eq explorer.exe" 2>NUL | find /I /N "explorer.exe">NUL && exit & explorer.exe & exit ) else ( tasklist /FI "IMAGENAME eq explorer.exe" 2>NUL | find /I /N "explorer.exe">NUL && exit & explorer.exe & exit )
  • Malicious Winlogon cmd.exe startup entry found
    #7 16837359
    Acorus 20
    Help: 3247
    Rate: 1063
    AlternateDataStreams: C:\ProgramData\Microsoft:1HpGaBeqmAD5cTinjYY7suS3 [2184]
    AlternateDataStreams: C:\ProgramData\Microsoft:hE5bKKu5PQmRDSgOi4JDOZFK [2322]
    AlternateDataStreams: C:\ProgramData\Microsoft:UafJNZ5nRsCk3vFHCC [2172]
    AlternateDataStreams: C:\Users\dmNen\AppData\Local\DOycCMwx3jjNzP:pecjhhohiQJTMjL6Yk [1978]
    AlternateDataStreams: C:\Users\dmNen\AppData\Local\xudI8yzch:Yo2yIfmnjnIcO0wO8I6JOkyc [2104]
    Winlogon\Notify\SDWinLogon-x32: SDWinLogon.dll [X]
  • #8 16837391
    Lasek001
    Managed to! The command line works when the desktop starts up, then cmd is turned on, but the Library folder no longer, so it's ok :) What was the reason? And of course, thank you for your help.
  • #9 16837788
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Like what? Infection.
    Insert new logs from FRST, from scanning.
  • #10 16837872
    Lasek001
    Attach logs.
    • FRST.txt (27.3 KB) You must be logged in to download this attachment.
    • Addition.txt (38.94 KB) You must be logged in to download this attachment.
  • SpyBot removal and FRST fixlist cleanup
    #11 16837973
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Odinstaluj SpyBot.
    Wykonaj Fixlist.txt dla FRST:
    Task: {1E0513C6-CE77-4432-8166-29B4B5E022B0} - C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser => Command(2): %windir%\system32\rundll32.exe -> appraiser.dll,DoScheduledTelemetryRun
    Task: {3C5D9430-D7F4-4ADE-B93E-143422BEDE9F} - C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\ProgramDataUpdater => Command(1): %windir%\system32\rundll32.exe -> aepdu.dll,AePduRunUpdate
    Task: {3C5D9430-D7F4-4ADE-B93E-143422BEDE9F} - C:\Windows\System32\Tasks\Microsoft\Windows\Application Experience\ProgramDataUpdater => Command(2): %windir%\system32\rundll32.exe -> invagent.dll,RunUpdate
    (Safer-Networking Ltd.) C:\Program Files (x86)\Spybot - Search & Destroy 2\SDFSSvc.exe
    HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Local Page =
    2017-11-20 05:11 - 2017-11-20 16:39 - 000000000 ____D C:\ProgramData\Spybot - Search & Destroy
    2017-11-20 05:11 - 2017-11-20 16:39 - 000000000 ____D C:\Program Files (x86)\Spybot - Search & Destroy 2
    2017-11-20 05:11 - 2017-11-20 05:11 - 000000000 ____D C:\Windows\System32\Tasks\Safer-Networking
    2017-11-20 05:10 - 2017-11-20 05:10 - 051725936 _____ (Safer-Networking Ltd. ) C:\Users\dmNen\Downloads\spybotsd-2.6.46.exe
    2017-11-20 05:09 - 2017-11-20 05:09 - 000000000 ____D C:\ProgramData\adaware
  • #12 16838450
    Lasek001
    Subsequent logs after repair.
    • FRST.txt (26.31 KB) You must be logged in to download this attachment.
    • Addition.txt (37.37 KB) You must be logged in to download this attachment.
  • #13 16838694
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Is it still cmd during the start?
  • #14 16839721
    Lasek001
    Nothing starts. It turns out that the problem solved, it was without format :)
    Thanks a lot!
The discussion revolves around a Windows 7 issue where the command line console (cmd) closes immediately upon opening. The user reports that cmd does not function from the run command, start menu, or batch files, and that the Library folder opens unexpectedly upon login. Various troubleshooting steps are suggested, including running cmd as an administrator, scanning the system with the Farbar Recovery Scan Tool (FRST), and checking for issues related to the Spybot - Search & Destroy software. Ultimately, the user resolves the issue without needing to format the system, indicating that the command line now works correctly after addressing the underlying problems.
TL;DR: In 1 Windows 7 case, cmd closed instantly due to malware altering Winlogon Shell; “Like what? Infection.” Remove unwanted tools, run FRST fixlist, and clean the Shell entry to stop cmd/Library popups. [Elektroda, Kolobos, post #16837788]
Why it matters: This FAQ helps Windows 7 users fix a cmd window that opens then closes and a Library folder that pops up at logon.
How do I fix a Windows 7 cmd window that opens and closes immediately?
Treat it as malware. Uninstall conflicting tools like Spybot, run FRST, and apply a provided fixlist to clean Winlogon Shell and scheduled tasks. Reboot and confirm cmd no longer flashes and no Library window appears. “Like what? Infection.” [Elektroda, Kolobos, post #16837973]
Why does the Library folder open at startup along with a flashing cmd?
A malicious Winlogon Shell command chained cmd.exe and then launched explorer.exe, which triggers the Library window. Cleaning the Shell value and any referenced binaries stops both the cmd flash and the Library popup at sign‑in. [Elektroda, krzychupar, post #16837358]
Is Safe Mode enough to bypass this problem?
No. The original report notes that booting in Safe Mode did not change the behavior. That indicates a persistent logon hook, not a normal startup item that Safe Mode disables. [Elektroda, Lasek001, post #16836128]
What is FRST and why use it here?
FRST (Farbar Recovery Scan Tool) produces detailed logs of autoruns, tasks, and registry keys. Helpers use it to craft a targeted fixlist that removes malicious entries without reinstalling the OS. Attach FRST.txt and Addition.txt. [Elektroda, RADU23, post #16836256]
How do I safely run a FRST fixlist?
  1. Save FRST.exe and the provided Fixlist.txt in the same folder.
  2. Run FRST as Administrator and click Fix.
  3. Reboot when prompted and share the Fixlog for review. [Elektroda, Kolobos, post #16837973]
Should I remove Spybot Search & Destroy before cleaning?
Yes. The helper advised uninstalling Spybot before applying the fixlist. This avoids conflicts and removes related shell extensions and services referenced in the logs. [Elektroda, Kolobos, post #16837973]
How do I confirm the infection is gone?
After reboot, the desktop should load without a cmd popup, and the Library folder should not open. The user confirmed success on Nov 21, 2017, after following cleanup steps. [Elektroda, Lasek001, post #16839721]
What logs should I post for help?
Generate and attach FRST.txt and Addition.txt from FRST. These logs show autoruns, tasks, and critical registry values needed for a tailored fixlist. [Elektroda, RADU23, post #16836256]
What exactly changed in the registry?
The Winlogon Shell value was altered to run cmd.exe and conditionally start SoundMixer.exe, then explorer.exe. Restoring Shell to explorer.exe fixes the startup chain. [Elektroda, Acorus 20, post #16837359]
Could a USB device have introduced this?
It’s possible. The logs list MountPoints2 entries pointing to autorun‑style executables on drive H:. Disable autorun and scan removable media when cleaning. [Elektroda, Acorus 20, post #16837359]
How long did the successful fix take in this case?
It was confirmed solved by Nov 21, 2017. That is within roughly one day of the initial report on Nov 20, 2017. [Elektroda, Lasek001, post #16839721]
What if cmd still opens at startup after I run the fixlist?
Rescan with FRST, post fresh FRST.txt and Addition.txt, and confirm the behavior after boot. A helper explicitly checked whether cmd still appeared at start. [Elektroda, Kolobos, post #16838694]
What is SoundMixer.exe in AppData in this context?
It is a malicious file referenced by the altered Shell command in AppData\Roaming\Microsoft\SoundMixer. Remove it during the fix to stop reinfection. [Elektroda, krzychupar, post #16837358]
Can running cmd as Administrator or from .bat help?
No. The user tried Run as Administrator and .bat wrappers, but cmd still closed immediately. The root cause was the Shell hijack, not permissions. [Elektroda, Lasek001, post #16837237]
What is the Windows Winlogon Shell?
It’s a registry value that defines the program launched after user logon. Here, malware replaced the default explorer.exe with a chained cmd call. Restore it to explorer.exe only. [Elektroda, Acorus 20, post #16837359]
