Solder Paste Uses and Application Methods for PCB Assembly and SMD Components
Kumek 78347 7
  • #1 2497396
    Kumek
    I don't know what solder paste is for and how to use it. Write how to use it better!
  • #2 2498193
    hefid
    Rest in Peace
    Help: 546
    Rate: 6172
    The post was reported.
    I transferred from: What to buy and where to buy?
  • #3 2498204
    Yoshi
    Level 19  
    Help: 14
    Rate: 18
    Welcome,
    solder paste is used for soldering.
    It can be stenciled onto a printed circuit onto which surface mount components are placed, and then soldered in a reflow soldering oven.
    The paste can also be applied with a syringe, puppet, etc. in the case of repairs of electrical devices, and then solder the system with a Hot-Air soldering iron (hot air) (by desoldering the damaged one).
    The paste consists of a flux and a powdered mixture of tin, lead, gold, silver, copper - the composition is given on the packaging.
  • #4 2498221
    DonRomano
    Help: 199
    Rate: 730
    Generally speaking, solder paste is a flux that prevents oxidation of the brazed surface and facilitates solder wetting.
    The paste may have powdered solder, but there are some that do not.
    How to use? It all depends on what you want to solder.
    As for example with copper pipes, apply the paste with a brush to the cleaned surface and then with a heater.
  • #5 2498224
    mechanix
    Help: 7
    Rate: 40
    It is used for soldering. Contains hydrochloric acid. Sometimes solder elements on the boards. After soldering, rinse with water. There are short circuits between the paths on the board and therefore we rarely use it in electronics.
  • #6 2500345
    jacobsek
    Help: 61
    Rate: 24
    Hydrochloric acid???
    I think that the time when solder pastes in electronics contained this compound has passed ... unless we use it to solder metal gutters but it's probably not this section ...
  • #7 2500410
    DonRomano
    Help: 199
    Rate: 730
    We have no idea what Kumek meant.
    The question is general, the answer is also.
  • #8 2500455
    mpzeus
    Rate: 14
    The solder paste facilitates soldering, e.g. when whitening the wires, it allows the tin to be evenly distributed over the whitened tip
    When soldering slotted elements, it significantly improves the adhesion and appearance of the solder, the tin does not pull behind the tip
Solder paste is a crucial material used in soldering, particularly for surface mount components on printed circuit boards (PCBs). It consists of a flux and a powdered mixture of metals such as tin, lead, gold, silver, and copper. The paste can be applied using stencils or syringes and is essential for ensuring proper adhesion and preventing oxidation during the soldering process. For applications like copper pipes, it is applied with a brush to cleaned surfaces before heating. While some pastes may contain harmful substances like hydrochloric acid, modern electronics solder pastes typically do not. Proper use of solder paste enhances the quality of solder joints and prevents issues like short circuits on PCBs.
