Alternatives to AutoData and Workshop Info-Tech for Auto Repair Diagnostics
ArcanusL 132097 18
What other diagnostic and service programs are used in auto repair besides Autodata and Workshop Info-Tech, and where can I get the latest Info-Tech Workshop version online?
Besides Autodata and Info-Tech Workshop, people mention Moto-Profil, TIS, ETKA and similar service/diagnostic programs [#2713928] Several replies say Autodata and Info-Tech complement each other because one often has car data the other lacks, so having both is recommended [#2882877] The thread does not provide a reliable web source for the latest Info-Tech Workshop version; it only suggests looking on p2p/emule networks and mentions older copies such as 2002/2004/2005 editions [#2729545][#2729735]
  • #1 2713885
    ArcanusL
    Hello and welcome!
    I have such an interesting question about this department, although I don't know exactly whether I did the right thing, but anyway, apart from the popular Autodata and Workshop, there are other diagnostic and service programs that are used in e.g. auto repairs?
    Are there any other programs?
    And the last question, where can I get the latest version of Info-tech Workshop from the web?
    Regards to everyone.
  • #2 2713928
  • #3 2729545
    kornik18704
    Everyone is looking for infotech because it is much better than autodata, it is best to look for p2p programs cheers
  • #4 2729735
    damiwr
    Help: 16
    Rate: 54
    or I have a version
    2002
    2004 2CD
    2005 3 CD
    PZDR
  • #5 2878453
    grzesiekk
    I have AutoDate 2004 as you write something.
  • #6 2882418
    lukas313
    Rate: 31
    I have info tech but I wouldn't say it's that good.
  • #7 2882877
    zibi70
    Help: 12
    Rate: 50
    kornik18704 wrote:
    Everyone is looking for infotech because it is much better than autodata, it is best to look for p2p programs, best regards
    I have both and this and I can not state clearly, because there are situations that there is a car with a description in one program and not in the other, and vice versa. If you want to do something, you need to have both.
  • #8 2883449
    krbl
    Help: 13
    Rate: 40
    here I agree with zibi
    but if someone had an infotech, workshop or whatever called them, but only the last one on 3cd
    and
    Autodata 2.16 or 3.16 with English (or only files from the first disc in English)
    so please let me know.
    if someone is interested, I have the last autodata, but in a few European languages without English.
    GREETINGS
  • #9 2884374
    Roli
    Help: 58
    Rate: 171
    I would just like to add that Autodata 2006 is currently on mussels ;)
  • #10 2884519
    krbl
    Help: 13
    Rate: 40
    on emule it may be, but for a few downloaded files, not a single version works
    did you manage to download?
    I have 2.15 coupled with 2.16
    but full in German and English is selective.
    I download 3.16, we'll see
    how did you get the version ok give info on pw
  • #12 2889128
    prg
    Rate: 12
    I have Autodate 2005 and during the installation it asks for a second CD "Place the CD2 in drive C: and choose OK" it does not help to mount a second CD in a virtual drive, there is a "GRAPHICS" file on it. How do I run this program?
  • #13 2890273
    RP
    Help: 14
    Rate: 52
    You can install from hard disk e.g. how you want to install to C: then copy both CDs to D: or E: keeping directory structure and install from here. Works on 2.15 and with others I don't know but it should.
    RP
  • #14 2890613
    prg
    Rate: 12
    Did not help! I keep popping up with this message "Place the CD2 in drive C: and choose OK" and I can't finish the installation!
  • #15 2890904
    krbl
    Help: 13
    Rate: 40
    maybe the disc is damaged
    or otherwise
    data on the disc
    from virtual or cd must work.
    if you install so that the data from the second disc will not be written to the disk but read from the disc, then the installer only needs to confirm that you have it. You put it in for a moment and the program says to insert cd1
    it should be
  • #16 2891168
    RP
    Help: 14
    Rate: 52
    It's best to download the "correct" CD1 version again
    and everything must be ok.
    RP
  • #17 2891199
    prg
    Rate: 12
    It is possible that there are corrupted files, it mounts in Daemon Tools or Akohol 120, but it does not go to finish the installation, cd2 calls, like a torrent file, it should be ok!
  • #18 2896385
    prg
    Rate: 12
    Disc 1 and 2 Autodata is an NRG file, I'm trying to change to iso with PowerISO but it doesn't work out! I open the file via paweriso but inside there is nrg file anyway, Maybe I'm doing something wrong? The program should be installed if there are files in nrg format ?
  • #19 2898243
    RP
    Help: 14
    Rate: 52
    Daemon Tools 100% supports .nrg files.
    Converting to PowerISO: either via File> Save as ...
    or from the context menu PowerISO> Add to image file and select
    either .iso or .bin or .daa.
    And what version of the program?
    Greetings
    Radek
The discussion revolves around alternatives to popular automotive diagnostic software such as AutoData and Info-Tech Workshop. Users mention several alternatives including Moto-Profil, TIS, and ETKA, with some expressing a preference for Info-Tech due to its perceived superiority over AutoData. There are mentions of various versions of AutoData (2004, 2005, 2006) and issues related to installation, particularly concerning the need for multiple CDs and compatibility with virtual drives. Users share links for downloading AutoData and discuss the challenges of obtaining the latest version of Info-Tech Workshop, with suggestions to explore peer-to-peer (P2P) programs for better access.
