Fonici PW0350 Amplifier: Seeking 2x35W C180 (2x4700uF) Component Replacement Options
SiLeNt_hUnTeR 8029 12
What replacement capacitor should I buy for the missing three-pin power capacitor in this 2x35W amplifier?
Buy a dual electrolytic capacitor in one housing, around 2x4700 µF for a symmetrical ±35 V supply, with three leads for the +, -, and center/ground connection [#3332956] A 4700 µF 50 V replacement was confirmed to be suitable [#3340701] If there is enough physical space, a larger low-profile capacitor such as 8200 µF / 50 V can also be used [#3332597]
  • #1 3332529
    SiLeNt_hUnTeR
    Help: 26
    Rate: 33
    Hello!
    Buddy has this amplifier (power is 2x35W?) Only this element is missing in it. What to buy?
    dybas
    Help: 419
    Rate: 338
    Depends how many places there is (height). I'm inserting Samsung capacitors
    8200 ?F / 50 V. They are low, bulky, and cost PLN 5.
  • #3 3332934
    SiLeNt_hUnTeR
    Help: 26
    Rate: 33
    This capacitor has 3 pins, and it looks like this:
    maryann
    Level 37  
    Help: 342
    Rate: 337
    Sure! These three pins are the easiest way to have two capacitors in one housing; they support symmetrical voltage, eg +/- 35V. If you solder two capacitors in series, they will also have three pins: middle (to ground), + and -. A colleague above advises well. But how it was 2x4700 is enough, there is no exaggeration; but you can.
  • #5 3340378
    SiLeNt_hUnTeR
    Help: 26
    Rate: 33
    Can I ask a schematic, how to solder it ??
    AVG
    Level 30  
    Help: 120
    Rate: 32
    • Fonici PW0350 Amplifier: Seeking 2x35W C180 (2x4700uF) Component Replacement Options bez tytułu.GIF (2 KB) You must be logged in to download this attachment.
    marian1981.02
    Unitra equipment specialist
    Help: 989
    Rate: 756
    It will be fine. The capacitors will also be suitable.
    AVG
    Level 30  
    Help: 120
    Rate: 32
    yes this combination is supposed to look like, and the horses can be
  • #10 3340708
    SiLeNt_hUnTeR
    Help: 26
    Rate: 33
    thank you all
  • #11 3341289
    Mery84
    Help: 427
    Rate: 271
    I am just going to a change in condition, but I have to exchange two ELNY at 5600uF 45V (the original has 2x4700uF 40V) and I have a problem connecting because the terminals have 3 outputs and I do not know how to sleep together and Tosce was one of the condensers with 3 leads.
    Will you do according to this drawing, that is, minus to minus on the board plus the minus of the second capacitor and plus the second capacitor to the plus on the plate and NC output together to the mass on the plate will be ok or everything must be connected parallel ???
  • #12 3342067
    SiLeNt_hUnTeR
    Help: 26
    Rate: 33
    ELNA produced combined capacitors (two in one housing), hence three leads
  • #13 3342404
    Mery84
    Help: 427
    Rate: 271
    ELNA not ELWA (Elwa is original in Tosca). I have two capacitors of 5600uF and I want to know if it will be good if it connects as shown in the picture.
The discussion revolves around finding a suitable replacement for a missing capacitor in the Fonici PW0350 amplifier, specifically a component rated at 2x4700uF. Participants suggest using Samsung capacitors rated at 8200uF/50V due to their low profile and affordability. The importance of the capacitor's three-pin configuration is highlighted, allowing for symmetrical voltage support. Users inquire about soldering techniques and schematics for proper installation. The ELNA brand is mentioned in relation to combined capacitors, and there is a discussion about connecting capacitors with three leads. Overall, the community provides guidance on selecting and installing appropriate capacitors for the amplifier.
