Insert key toggles overwrite mode in Word—how to turn it off without restarting?
autokomputer 16893 3
  • #1 3618715
    autokomputer
    Level 19  
    Rate: 45
    Sometimes I have a problem - I probably press a shortcut and that's why:
    For example, I wrote the sentence "Ala ma ota" - that is, the letter "k" is missing, so I come back to type "k", it erases "o", I type "o", it erases "t", I enter "t", it erases " and"
    How can this problem be solved ??
    The problem disappears when I close a program like Word and restart it, but how to fix it without shutting down the program?
  • #2 3618732
    Lilith_100
    Help: 70
    Rate: 18
    hit the "Insert" key - it should help
  • #3 3619684
    marek003
    Level 40  
    Help: 801
    Rate: 488
    As above, but for the sake of information only
    when this is done, a black inscription ZAS appears on the status bar of the word (next to the word Polish [English]), i.e. replace if you press then the inscription ZAS will turn gray, i.e. inactive
  • #4 3619748
    Robert B
    Help: 2027
    Rate: 1412
    Tools> Options> Edit - and there uncheck "Overwrite Mode".
    Same thing just different :)
