Setting MasterCook Electric Cooker Clock: Class A, Button Response & Lost Instructions
fakk00 132061 6
  • #1 6867333
    fakk00
    Rate: 16
    I moved into the apartment there is a completely new electric cooker, class A, there are no more signs, unfortunately the gingerbread maker does not work without the clock set, I tried to set it myself but unfortunately it does not respond to the buttons under the clock, I will add that I do not have instructions and I cannot contact temporarily owner please help :) Thank you in advance
  • #2 6867368
    msichal
    Help: 19
    Rate: 46
    You could at least give a picture of this stove so that you can see the buttons, display, etc.
  • #3 6867386
    fakk00
    Rate: 16
    I'm not home at the moment
    I will add that
    mastercook class A + only this is written on the front of the stove, unfortunately, I can't locate anything else ... the clock is on the left, 4-burner hob ... any hint
  • #4 6867416
    msichal
    Help: 19
    Rate: 46
    How many buttons are there? I don't know anything about it, I just know how it is with me. And since it is similar with the oven, I somehow automatically thought that maybe the same ...
  • #5 6867421
    fakk00
    Rate: 16
    hmm under the clock I have 4 buttons and after pressing, holding, zero reaction, I don't know how else you can set this clock :) and it might seem so simple :)
    Added after 16 [minutes]:
    https://obrazki.elektroda.pl/98_1249659232.jpg
    the kitchen looks exactly like that, so it's probably a model
    Mastercook KC 2470 X Plus
  • #6 6867607
    msichal
    Help: 19
    Rate: 46
    I thought maybe it is like with me. Unfortunately, in such a situation, I will not help ...
  • #7 6867655
    pp1964
    Help: 79
    Rate: 124
    Press and hold, two left buttons, two right buttons set the current time (up, down), release the left buttons, after 5 sec. time is saved.
    Regards.
    Or maybe it has 4 buttons and a knob?
    Then, hold the two middle ones, the time is set by the knob.
The discussion revolves around setting the clock on a MasterCook Class A electric cooker, specifically the Mastercook KC 2470 X Plus model. The user is unable to set the clock due to unresponsive buttons and lacks the instruction manual. Other participants suggest troubleshooting steps, including pressing and holding specific button combinations to set the time. The user reports having four buttons under the clock, with no response when pressed. A visual reference of the cooker is provided to assist in identifying the model and controls.
