Excel Data Collapse/Expand Using Mouse Wheel - How To?
automatyk120 24173 5
  • #1 4560762
    automatyk120
    Please, give me a hint on how to collapse and unfold a column with data in an Excel spreadsheet using a mouse wheel.
  • #2 4561117
    metalli
    Level 30  
    Help: 116
    Rate: 43
    I do not really understand what is going on and what would it be for? I am asking for an example to clarify the topic
  • #3 4561190
    automatyk120
    This is very useful when the data column is quite long. By scrolling with the scroll wheel, you can go to the "distant" cell and do not pull or look through the entire column.
    Maybe it'll help.
    Data scrolling does not start from the first row, but is shifted down by a dozen or so.
    The whole problem is how to do this shift.
  • #4 4561288
    mareczko
    Help: 16
    I don't really understand what you are asking but maybe you are talking about the grouping function. ALT + SHIFT + "right arrow"
    This way you can group selected columns or rows.
  • #5 4561323
    automatyk120
    Thanks for your interest, but it's not about grouping, I've already mastered it.
    More about how to move the place from which the cell with the given data will start scrolling. This means that the previous cells, despite being scrolled with a roller, remain visible.
    It looks like moving the sheet itself down.
    Regards
    Smilox
    Help: 37
    Rate: 30
    Select several cells and press Window | Lock panes.
    This is it?
