Locating Break in 50-Meter 2x2.5 mm Double Rubber Insulated Extension Cord: Non-Pyrotechnic Methods
Majkello 54530 12
How can I locate a break in a 50-meter double-insulated extension cord without cutting it open?
If you have a capacitance meter, measure the broken conductor’s capacitance from both ends and use the ratio to calculate the fault position: the two capacitances are proportional to cable length, so the break is at C1/(C1+C2) of the total length from the first end [#5117443] Do the measurement only when the cable is stretched and the fault is actually present, because an intermittent contact will make both ends read the same [#5118091] A simpler field method is to put phase on the broken wire, connect a load such as a lamp at the far end, and walk along the cable with a non-contact voltage detector/phaser until the signal disappears; that is where the break is [#8066171]
  • #1 5117319
    Majkello
    I have a - maybe trivial - question: how to locate a break in a 50-meter extension cord made of 2x2.5 mm wire in double rubber insulation?
    After measuring with the phaser sensor, one of the wires (exactly blue :-) shows a lack of continuity, but I don't know exactly where, and I don't want to cut the entire extension cord.
    The wire was used at a construction site where it was laid on the road and somewhere it got crushed by car wheels.
    I'm wondering whether to connect the broken wire of the welding machine to both ends for a moment, set to 20A, then the break in the circuit will immediately be visible outside :)
    Maybe there are some more subtle and less pyrotechnic methods of detecting a break in the wire?
    greetings majkello!
  • #2 5117443
    Rzuuf
    Help: 1355
    Rate: 1700
    Hello!
    I assume there is only 1 break.
    With a capacitance meter (many multimeters have this function), measure the capacitance of the broken wire in relation to the remaining wires connected, measuring once from one end and once from the other. The measured capacitances are proportional to the length of the cable, so, for example, you will get the result:
    I - 2340 pF,
    II - 5670pF.
    Now the calculation: the total capacitance is 2340+5670=8010pF, the break is 2340/8010=29% from the first end, i.e. at a distance of 50*0.29=14.5m.
    Simple?
  • #3 5117583
    Majkello
    Simple! :)
    Unfortunately, I don't have access to a capacitance meter today, maybe tomorrow I'll be able to get it.
    when I was winding the cable on the spool, I noticed that after rolling it, it started to make contact - I don't know what it changes, makes it easier or more difficult.
  • #4 5118091
    Rzuuf
    Help: 1355
    Rate: 1700
    What I wrote to you applies to the situation when the break IS. If the cable makes contact, unfortunately, the capacitance measured at both ends will be the same, so before the measurement, it would be good to stretch the cable and check whether it will actually have a break at the time of measurement.
  • #5 5118379
    irekr
    Help: 1192
    Rate: 1239
    Several years ago I was locating a break in a cable lying at a depth of about 50 cm below the surface of the earth.
    Having no equipment, we had to cope.
    I used:
    1. A buzzer built on a telephone relay and powered by a flat battery (I wonder if the young generation knows what a "flat battery" is...).
    2. A portable radio receiver with a range of long and medium waves.
    Then I connected the ends of the wire to the contacts of the buzzer breaker. The radio receiver placed in a place where there was no radio station received strong crackling of the breaker. Walking along the route of the cable, I found a place where the strength of the crackling changed abruptly. I dug up the cable and hit the fault with better than 20 cm accuracy.
  • #6 5118399
    roks
    Automation specialist
    Help: 77
    Rate: 55
    If there is a break in the cable, theoretically this method should be enough
    With an indicator for detecting live wires in walls (the most common one from Nomi), run along the wire with the damaged wire connected to the phase, where it stops showing voltage -> there is a break.
    Regards
  • #7 8065971
  • #8 8066069
    retrofood
    Help: 1140
    Rate: 4798
    Breaks usually occur in plugs, or in the cable right at the exits of the plugs. If you can't do it yourself, find an electrician, because you'll hurt yourself.
    The way to detect a break in the cable was given by Col. year . That should be enough.
  • #9 8066114
  • #10 8066171
    krzysiek7
    Moderator of Electricians group
    Help: 678
    Rate: 1953
    The place of a break in the wire can be detected with a "phaser", available in electrical stores for not too much money, about PLN 20 - 30, there is a detector there. You unwind the cable, connect it to the mains and walk along it, holding the "phaser" close to the cable, where the signal breaks off, you have a break. Just don't overdo it with the sensitivity of the phaser. The plug should be connected to the mains in such a way that there is a phase on the broken wire, and at the end connect some load, e.g. a lamp, to the extension cord. Thanks to it, the place of the break will be quite accurately indicated by the phaser.
  • #11 8066993
  • #12 8067172
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Topic exhausted - closing.
  • #13 20745051
    genc
    The capacity measurement method is fantastic.
    I found a break in the shielded cable, where the method of connecting to 220V and checking the method
    with an interrupt checker is not effective.
The discussion revolves around methods to locate a break in a 50-meter extension cord made of 2x2.5 mm wire with double rubber insulation. Users suggest various non-destructive techniques, including using a capacitance meter to measure capacitance differences, which can indicate the break's location based on proportional calculations. Another method involves using a buzzer and a portable radio receiver to detect changes in signal strength along the cable's route. Additionally, an indicator for detecting live wires can help identify breaks by checking for voltage loss. The importance of ensuring the cable is stretched before measurement is emphasized, as contact can affect readings. Overall, the conversation highlights practical, non-pyrotechnic approaches to troubleshooting electrical issues in extension cords.
