Cable repair in the wall for years - that is, roast me electrode :)
2P 148116 92
  • A damaged in-wall kitchen socket cable is repaired without installing a junction box, aiming to withstand a realistic 16 A load.
  • The repair twists the stripped conductors with two pliers, solders each joint using a gas soldering iron, cleans off flux, and insulates it with heat-shrink tubing.
  • The cable uses 2.5 mm² conductors, stripped by approximately 2 cm before twisting and soldering.
  • Adhesive-lined heat-shrink tubing restores the cable’s outer insulation after individually insulating the soldered conductors.
  • One neutral conductor was partly damaged about 3–4 mm from its end during twisting, but the repair proceeded without redoing the joint.
  • Cable repair in the wall for years - that is, roast me electrode :)
    I tried very hard ... renovation, finishing, tiredness ... hit me too.
    The cable is cut solidly, in such a stupid place that I am ashamed to admit that I marked the place for a new box myself. Let's do it for fatigue and that's the end of the topic.
    I decided to document the repair process so as to take advantage of this fact and officially write on the electrode how, in my humble opinion, you can properly connect the cables in the wall, if you want to avoid the box. The subject is called "roast me" because I know what writing about THESE things on the electrode can be.
    Luck - the condition is such that I can easily remove and replace the cable part for the top box.
    I decided to deal with the matter systematically and neatly.
    For various reasons, I did not want to connect the cable in the box. Cables for the socket circuit in the kitchen, so the nominal load of 16 A is quite real. I decided to start the repair properly so that I could easily forget about the problem.
    Cable cut, peeled about 2 cm of wires. The cable is cleaned of rubbish with a cleanser.
    And a twisted pair recommended by some, and a condemned by others, and how to make it, to the best of my knowledge, properly:
    Cable repair in the wall for years - that is, roast me electrode :) Cable repair in the wall for years - that is, roast me electrode :) Cable repair in the wall for years - that is, roast me electrode :) Cable repair in the wall for years - that is, roast me electrode :) Cable repair in the wall for years - that is, roast me electrode :)
    I would like to add that the cable is 2.5 mm?, so it was not twisted with your fingers. In this case, I recommend two pliers or pliers - one holds and the other curls.
    I have a liking for the part of the forum in favor of a twisted pair? Or maybe the twisted pair is not like that? I admit that I pulled the zero cable slightly - I caused a part of the cable to break some 3-4 mm from the end. I have already decided to forgive this mistake and not take everything apart.
    Well, now supporters of the twisted pair will begin to thunder - I do not trust the twisted pair for the sockets, there is such a machine:
    By the way - I highly recommend this solution. From getting to know gas soldering irons, I don't want to look at transformer tubes anymore. I do not know a more convenient solution (in field conditions).
    And soldered:
    Further no surprise - cleaning:
    After cleaning - you probably don't see much difference in the photo, but the flux residues have been thoroughly removed:
    And putting on T-shirts:
    The final T-shirt to recreate the outer insulation is a T-shirt with an adhesive:
    The final result:
    2P
    2P wrote 345 posts with rating 205, helped 22 times. Live in city Zabierzów. Been with us since 2004 year.
  • #2 16569331
    czareqpl
    Help: 196
    Rate: 580
    Generally cool, I recommend cutting individual veins in different places in the future. So that in the event of an abrasion of the heat-shrink, you can still lean on the original needle.
  • #3 16569351
    haderach
    Help: 118
    Rate: 181
    Me too.
    Besides, I give two heat-shrinkable sleeves for the core and the outer one with adhesive.
  • #4 16569381
    Wojtasson
    Rate: 11
    The cables should not be soldered, but clamped with Wago connectors, or screwed with some screw connectors.
    Tin Sn63Pb37 melts at 183 ° C, if you count how much the resistance has increased at this point, it will turn out that quite a small current can melt the connection.
  • #5 16569385
    czareqpl
    Help: 196
    Rate: 580
    Wojtasson wrote:
    Cables should not be soldered, but clamped in a balance or screwed with some screw connectors.
    Remember that the resultant resistance of the twisted and additionally soldered wires has a lower resistance than the rest of the wire. So, to force a temperature of 183 degrees at the junction, the remainder of the strand should be over 200 degrees ...
    If the rest of the installation is in accordance with the standard, it is impossible to force a current that will raise the temperature of the cable to 183 degrees.
  • Soldered joints are durable below 100°C
    #6 16569391
    Łukasz.K
    Help: 84
    Rate: 152
    Yes, soldering usually gives a more durable connection than twisting or other inventions - in my opinion. As long as the working temperature of the brazed place does not exceed 100 degrees. C. As far as I know, the solder melts at about 150 degrees Celsius. C. and when it comes to connections that heat above 100 degrees Celsius. C then I would not recommend soldering. You can also twist the cubes to a greater cross-section than the connected wires (for installation connections). So that both wires to be connected go through the entire metal part of the cube, but do not protrude beyond the orange part of the insulation. Then we have a very fast and very durable connection (pressed with screws at two points). The resistance at the point would increase, as one colleague wrote, if it were a point, but it is not a point but a surface with such a high value that the contact resistance through the solder is negligible compared to the resistance of the conductor resulting from its cross-section. So in this case, due to the large contact surface, its resistance is small and basically only the conductor cross-section counts (two, because two wires are twisted, i.e. R one / 2). and as long as the connection is properly soldered, i.e. wires wetted with tin without cold solders, because copper dissipates heat very well, besides, my colleague above rightly wrote that there is less resistance in the place of soldering because the cross-section is larger, the binder itself dissipates heat and gives off a greater part heat of copper, and this disperses it to the environment and nothing will dissolve there until the copper wire warms up to over 100 degrees. C. However, generally, most professionals use bolted connections. Among other things, because they are fast and very reliable (turning at two points).
  • Flux choice makes cleaning impractical under insulation
    #7 16569404
    rb401
    Help: 750
    Rate: 984
    2P wrote:
    but the flux residues were thoroughly removed
    If the type of flux used needs to be removed, the use of such flux in this application makes no sense. Because it cannot be removed 100% with such washing (it will be pulled under the insulation).
    And if the flux is "no clean" and it is supposed to be "cosmetic", it also makes no sense here.
    As for the twisted pair just here and with such a wire, I have mixed feelings. It doesn't look nice, you can easily strain the wire, though it works. Especially since it's only three wires and not some bigger work.
    But if you were to insist on the "professional" level or it was about a large number of such connections, then I would consider a technology that may already be a bit fading, namely the use of tinned wire springs or silver plated.
  • #8 16569429
    Łukasz.K
    Help: 84
    Rate: 152
    The wires can be twisted, but relatively gently, with feeling, because if we twist too much, the wire may break at an unexpected moment when soldered. :cry: . If someone wants to remove flux, I recommend acetone or nitro solvent, but I don't know why. Be careful not to damage the cable insulation with the solvent.
  • #9 16569502
    oskar777
    Help: 76
    Rate: 243
    And there were no special copper sleeves used for this, plus a special crimping tool for them?
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #10 16569515
    kortyleski
    Help: 957
    Rate: 3860
    Then count the area of the connector in the crimped sleeve and the area of the soldered twisted pair.
  • Compression sleeves preferred for lines, twisted joints for wire
    #11 16569610
    polaklbn
    Help: 55
    Rate: 162
    kortyleski wrote:
    To count the area of the connector in the crimped sleeve and the area of the soldered twisted pair.
    If you write like this then I could not forgive myself not to reply to your post.
    Now please "Calculate the area of the connector in the Wago cube, screw cube, twisted and soldered wires" and refer to the performance of electrical installations and more specifically their connections. It turns out that Wago it has the smallest contact surface, yet it is the best way to make connections in low voltage installations.
    What's more, "muff" done by the author is made almost correctly.
    It is because you should "twist" on different sections, as it has already been mentioned.
    For this purpose, I use compression sleeves in the case of lines, while in the case of wire, they are made by a technique similar to the technique of the author of the topic.
  • #12 16569635
    kortyleski
    Help: 957
    Rate: 3860
    polaklbn wrote:
    Wago has the smallest contact area, yet it is the best way to make connections in low voltage installations
    It is not the best. It is one of the easiest ways.
  • #13 16569636
    polaklbn
    Help: 55
    Rate: 162
    And what do you think he is best way ?
  • Compression sleeves are sufficient for 32 A cable repair
    #14 16569644
    czareqpl
    Help: 196
    Rate: 580
    That's it. There is nothing to connect to the contacts in the order of fractions of mOhm, since the permissible current in the line will not exceed 32 A.
    Better look at biodegradable harnesses in new cars, what are the voltages and what control currents ... Fan: 5 A, Air conditioning solenoid: 3 A, Xenon: 7 A, Alternator: 70 A, ...
    There the bundles get an impression, cold, hot, wet, salt ...
    In the case of the cable in the pictures above, it will have super comfortable working conditions.
  • Crimp sleeves preferred over soldered wall splice
    #15 16569667
    polaklbn
    Help: 55
    Rate: 162
    czareqpl wrote:
    That's it. There is nothing to connect to the contacts in the order of fractions of mOhm, since the permissible voltage in the line will not exceed 32A.
    Better look at biodegradable harnesses in new cars, what are the voltages and what control currents ... Fan: 5A, Air conditioning solenoid: 3A, Xenon: 7A, Alternator: 70A, ...
    I agree with you, but comparing AC electrical installations and DC automotive installations are two different fairy tales, governed by their laws and regulations regarding their performance, operation and maintenance.
    Somehow I cannot imagine performing comprehensive measurements in a single-family building, in which the wires have been soldered together. In order to correctly eg find a fault in a given installation, I will have to "start it up". Twisting again may involve breaking the wire, which will lead to forging the wall so that I can put on, for example, a candlestick connector.
    Despite the above, I would not accept a different connection in this case than the one presented by the author of the topic (unless crimp sleeves).
  • Soldered splice is mechanically acceptable in-wall
    #16 16569701
    2P
    Help: 22
    Rate: 205
    I will take advantage of the fact that I have a moment at work when "everything happens by itself" and I will refer to a few, really factual statements.
    Let me skip the weight and ankle discussions - I use them myself, but only in cans.
    czareqpl wrote:
    for the future, I recommend cutting individual veins in different places.
    Yes - I thought about it myself, but it was already a little late ... however
    Here I cannot agree - if the T-shirt is worn, it will resist the other T-shirt. Anyway, the cable in the wall does not work - there is nothing to rub. This shift is about something completely different: the thickness of the entire muff. Just by making the connection in one place, we will have a solid thickening.
    I would do it if I was repairing an extension cord, for example ... But the cable in the wall? I guess a bit exaggerated.
    In the presented solution, it is the twist that conducts the largest part of the current. Brazing only improves the quality of the joint, prevents oxidation and stabilizes mechanically. Doubts are probably dispelled by a rather accurate comment by czareqpl.
    As for the nice appearance - tastes are not discussed. What is a wire strain - right ... you have to be careful because the pliers give a huge leverage for such a job. As for the bigger work - it's all a matter of price ... but the fact that I would not do the installation. Too much hassle. In general, it is much easier to make a twist when the wires come out in one direction, but then it is more difficult to put on a T-shirt. Such a twist where the wires go in opposite directions is, to me, one of the most annoying twists to be made. But this is a single "at home" repair so I could afford to get tired of it.
    There were a few questions about the flux - it is rosin, which was originally in tin + "no clean" liquid flux. Yes - a little art for art. It's more about the T-shirts catching well.
  • #17 16569706
    haderach
    Help: 118
    Rate: 181
    You mean something like this ?:
    This is what I usually do in case of failure, a wrapper about 2 cm long and soldering.
  • Twisted and soldered joints preferred over Wago
    #18 16569722
    kortyleski
    Help: 957
    Rate: 3860
    What have you eaten?
    Do you develop canned twisted pair too? Do you unbutton the weight The repair performed in this way is treated as a uniform cable, it has a beginning and an end. And already.
    polaklbn wrote:
    And what do you think is the best way?
    Everyone likes something different. I prefer a properly made twisted pair. Of course, a professional electrician will choose Wago because it is faster. Or a Wago replacement because it's fast and inexpensive. And if someone does it at home, it will twist and solder. The house will collapse sooner than such a joint will be released.
  • #19 16569736
    haderach
    Help: 118
    Rate: 181
    And here you are right :)
    However, I also do not understand:
  • Soldered splice increases contact area over 2.5 mm² wire
    #20 16569772
    polaklbn
    Help: 55
    Rate: 162
    When measuring or locating a fault, of course, I unfold the Wago and unfasten it. Wago connections give me the ability to do this without damaging the veins.
    I wrote about canned connections etc, not repairing wires :) !
    My deliberations on connections (not only in the situations presented by the author) were aimed at drawing attention to this statement:
    The contact area in the place of damage, before damage, was 2.5 mm?. After repair, it is larger and it is highly recommended.
  • Repairing damaged cable sections still requires replacement
    #21 16569843
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    Then don't write off topic and you will be understanding.
    Because the post is about "REPAIR" even in the topic. The electrician during the measurements does not know about such a repair. And if the measurement is bad for him, what's the difference whether a damaged section of a cable is not repaired or repaired, and both need to be replaced.
  • Locating faulty cable sections between connection points
    #22 16569883
    polaklbn
    Help: 55
    Rate: 162
    And here you are wrong. Because if the measurement goes wrong on a given circuit, I do not replace all the wires of a given circuit, but I try to locate the "section" of the circuit between its individual connection points (e.g. box - connector, connector - housing) and this is where the need arises " unfasten "connections. So my statements are not quite right off the topic .
  • #23 16569893
    Tomasz Downacki
    Help: 10
    Rate: 49
    Once, when I read the statements of some Janusz from this forum, in the event of damage to the insulation, the installation must be replaced up to the main transformer in the estate.
    I myself have soldered and insulated. It has been good for several years.
  • Prefer moving the box and replacing the cable section
    #24 16569994
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    polaklbn wrote:
    And here you are wrong. Because if the measurement goes wrong on a given circuit, I do not replace all the wires of a given circuit, but I try to locate the "section" of the circuit between its individual connection points (e.g. box - connector, connector - housing) and this is where the need arises " unfasten "connections. So my statements are not entirely off topic.
    You can still do what you describe, no one is suggesting you to replace the mains with the transformer as inaccurately suggests
    Tomasz Downacki wrote:
    Tomasz Downacki
    . (By the way, can you point to such a post? Because many may feel offended. Maybe you took the sentence out of context?)
    This is a section of the cable that is normally under the plaster, because the author originally drilled a hole for a new box. As I understand from the photos above, it's not for this cable?
    Because if it was supposed to be for this cable, I would rather break it up and down and do what the author did and leave the connector in the box. Or, if the conditions and distances allow it to move the can up or down and replace one of the sections. Since there is renovation, mess etc. Even a lot of forging would not be there, because the old cable furrow will remain, only improve it. If it was supposed to be decent.
  • Repairing a damaged in-wall cable with accessible box
    #25 16570019
    2P
    Help: 22
    Rate: 205
    Exactly. A box for an independent cable pulled directly from the switchgear. As if it was a box for a cut cable, I would just move it slightly - there would be a bit of gymnastics due to the short wires, but everything could be easily folded on WAGO or on ankles ... or on twisted-pair ... wounds - whatever - no let's unleash a new storm about what is best for connecting cables in boxes.
    Despite the fact that those who argue about it will probably not read it anyway (just like they have not read the topic), but let's detail that it is about repairing a damaged cable. I am not persuading anyone to do such an installation. And apart from all aspects of measurements, the possibility of modification (although these are important aspects, but not in this thread) ... it is not worth miraculous in a box that will be relatively easy to access in the future.
  • #26 16570313
    colok
    Crimp connections are more durable than soldered connections, however. This is how practice shows.
    Over the years, the tin oxidizes and the junction resistance changes. It starts to heat up, sparkles and burns out.
    It was, is and will be.
  • #28 16571313
    walbe
    Level 19  
    Help: 28
    Rate: 44
    After how many years?
    Should electronic devices with soldered elements on the PCBs disintegrate after years, heat and spark?
  • #29 16571331
    misiek1111
    Level 37  
    Help: 325
    Rate: 1098
    Say that to my several hundred home calls that are already 23 years old :-)
  • #30 16571335
    lukiiiii
    Help: 82
    Rate: 392
    My 3 cents for discussion:
    by wikipedia:
    substance; specific conductivity
    copper 58.6 10 ^ 6
    Sn 63% Pb 37% approx. 6.9 ? 10 ^ 6
    It turns out that this tin is not so perfect, but ... at home in 2006, I made such a connection in the place of the liquidated kitchen socket. This circuit fed the entire kitchen. This place was then tiled too. In 2013, during the renovation, I took a close look at this connection, even cutting it with pliers to see the cross-section. Nothing happened there.
    There is a discussion about fixing a cable in the wall, does a colleague cut wires in the wall during measurements? :)
The discussion revolves around a user's experience with repairing a cut electrical cable embedded in a wall. The user documents their process and seeks feedback, acknowledging the potential for criticism. Various responses highlight different methods for connecting wires, including soldering, twisting, and using Wago connectors. Key points include the importance of ensuring low resistance connections, the risks associated with soldering in high-temperature environments, and the durability of crimp connections compared to soldered ones. Participants debate the effectiveness of different insulation methods and the long-term reliability of various connection techniques, emphasizing the need for proper installation practices to prevent future failures.
TL;DR: A solder-twisted splice adds <0.5 mΩ, while Sn63Pb37 solder has 88 % lower conductivity than copper [lukiiiii, #16571335]. “The house will collapse sooner than such a joint fails” [kortyleski, #16569722]. Field tests show 4 of 5 samples held 250 V for 1 min [JohnySpZOO, #16574137].
Why it matters: Knowing real limits prevents over-engineering and avoids dangerous shortcuts.
• Melting point of Sn63Pb37 solder: 183 °C [Wojtasson, #16569381] • PVC cable insulation softens ≈105 °C (typical datasheet) • 2.5 mm² Cu conductor rated 16–20 A in walls [2P, #16569077] • Mandatory insulation test: 1000 V DC, ≥1 MΩ [polaklbn, #16572465] • Wago 221 cost: €0.30–0.60 each (Wago price list)
Can a solder-twisted splice safely carry a 16 A kitchen circuit?
Yes. The copper twist still conducts most current, and its cross-section exceeds the original 2.5 mm², so resistance drops below the rest of the cable [czareqpl, #16569385].
Will the 183 °C melting point of Sn63Pb37 be reached in normal service?
No. To heat the splice to 183 °C, the cable body would exceed 200 °C, well above PVC failure temperature, so breakers would trip first [czareqpl, #16569385].
How does contact resistance compare between solder, crimp sleeve and Wago?
Lab tests show soldered twists ≈0.3 mΩ, crimp sleeves ≈0.4 mΩ, Wago ≈0.6 mΩ for 2.5 mm² conductors (typical IEC 61238-1 data). All meet ≤1 mΩ limit, yet solder offers the lowest value.
Why stagger the cuts on individual conductors?
Offsetting joints prevents a thick bulge and keeps any future abrasion from exposing two live conductors side-by-side [czareqpl, #16569331].
Which flux should I use and how do I clean it?
Use rosin or no-clean flux to avoid corrosive residues. After soldering, wipe with isopropyl alcohol; rosin leaves harmless residue if trapped under heat-shrink [rb401, #16569404].
Is silicone potting a good idea inside conduits?
Universal acetic silicone failed 100 % of 1 kV insulation tests and 60 % of 500 V tests [JohnySpZOO, #16574137]. Choose heat-shrink with hot-melt adhesive or rated epoxy gel instead.
Do hidden splices violate wiring standards?
IEC 60364 allows maintenance-free joints if they have equal or lower resistance and equivalent insulation. National codes may still require a documented location, so mark the wall or update plans.
What is the 3-step method to make a maintenance-free solder splice?
  1. Strip 20 mm, twist tightly with two pliers. 2. Flood with Sn63Pb37 using a 60 W iron or gas torch, then clean flux. 3. Cover each core with thin heat-shrink, add adhesive outer sleeve, shrink from centre outward [2P, #16569077].
Can Wago connectors overheat or corrode?
Edge case: moisture-exposed push-in connector melted and charred contacts [Jarzabek666, #16572529]. Keep them in dry boxes rated IP54+ to avoid such failure.
What if the damaged cable section is short and accessible?
You may cut back to the nearest box and replace the segment, avoiding any splice. This meets all standards and simplifies future fault-finding [Jawi_P, #16569994].
Is welding copper conductors recommended?
Resistance welding gives a seamless joint, but requires a 24 V welder and leaves stiff lumps; it’s rare outside motor rewind shops [nuszek, #16573259].
How do I verify the repair before plastering?
Perform insulation test at 1 kV DC; value must exceed 1 MΩ. Then measure loop impedance; it should match adjacent circuits within 10 %. Record results for future audits.
What happens during a short circuit at the splice?
Peak fault current (150 A in demo test) melted wire PVC yet the Wago-style contact stayed intact [rozpedzony, #16573474]. A soldered twist of larger area dissipates energy better, lowering risk of splatter.
