Easiest Methods to Detect Underground Cable Damage Between House and Garage
CiekawyŚwiata 29646 17
How can I check whether an underground cable between a house and garage has damaged insulation or is leaking current into the ground?
Use an insulation resistance test with a megohmmeter/insulation tester; measure each conductor against the other conductors and against earth/PE [#17594856][#17597379] If the cable is healthy, the insulation resistance should be well above 1 MΩ, and a weak earth electrode can still be much less than 1 kΩ, so a comparison between the cable cores and earth can reveal a fault [#17596982] The thread also notes that new cable should be around >20 MΩ/km, while readings of 3–10 MΩ are not really OK and may indicate moisture or insulation deterioration [#17503167][#17602990][#17603031] One reply mentions using a 250 V test voltage on the insulation tester [#17597379]
  • #1 17594845
    CiekawyŚwiata
    Rate: 15
    I have a cable in the ground between the house and the garage and I suspect that it may be damaged and the electricity "leaks into the ground". What`s the easiest way to check this?
  • #2 17594856
    mawerix123
    Help: 482
    Rate: 951
    Measurement of insulation resistance with a device intended for this purpose.
  • #3 17594867
    arturdip
    Help: 170
    Rate: 324
    You can try to disconnect all loads in the garage and turn on the ammeter (a result above zero will confirm the thesis) if it is a single-phase installation. Of course, all precautions must be taken.
  • #4 17594912
    kloszi
    Help: 34
    Rate: 89
    Better disconnect everything and check the meter to see if there is any consumption on the meter.
  • #5 17596328
    CiekawyŚwiata
    Rate: 15
    I`m wondering because I can easily measure the insulation resistance between individual wires by applying the measuring probes of the meter (insulation resistance meter) to the wires between which I want to test the insulation, but how can I measure the insulation resistance between each wire of the cable and the ground?
    Added after 1 [minute]:
    This is basically not possible for me because the cable to the garage does not run directly from the meter
    I was also thinking about this method, except that the installation is 3-phase (the cable is 5x10) and copper, although I don`t know what difference does it make if the installation is not single-phase?
  • #6 17596353
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    CiekawyŚwiata wrote:
    from the wires of the cable and the ground?
    From PE cable. :D He should (?) be your Land (Promised or Flat) :D
  • #7 17596375
    CiekawyŚwiata
    Rate: 15
    Even if the PE earth electrode is several dozen meters from the place where the insulation is damaged?
  • #8 17596383
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @curious about the world Of course, unless it`s interrupted, but I don`t think so.
  • #9 17596982
    Jacek Rutkowski
    Help: 69
    Rate: 275
    Leakage does not usually constitute a perfect short circuit, but the insulation resistance should be greater than 1MΩ. If it is smaller, it indicates damage to the insulation. Even a weak earth electrode several dozen meters from the measurement point should be much less than 1kΩ. By measuring between it and the wires of the cable, it is possible to deduce damage to the insulation.
  • #10 17597379
    KaW
    Help: 170
    Rate: 306
    A "mag meter" with a measuring voltage of 250V is used and measures the insulation of each wire in relation to the others and to "earth".
  • #11 17601931
    KonradGatek
    Level 30  
    Help: 79
    Rate: 745
    KaW wrote:
    A "mag meter" with a measuring voltage of 250V is used =(...)
    for 2500V cables.
    Jacek Rutkowski wrote:
    (...) but the insulation resistance should be higher than 1MΩ. (...)
    100MΩ cable up to 1 km.
    As the elderly gentleman from the Power Plant said while turning the crank: If it`s going great, there will be something
  • #12 17602207
    CiekawyŚwiata
    Rate: 15
    Insulation resistance measurements showed values from 3 to 10MΩ, so it looks like the cable is OK
  • #13 17602990
    rtvserwisant
    Help: 59
    Rate: 97
    A value of 3 - 10 MΩ, in my opinion, gives the impression that something is wrong with the cable, there is probably moisture between the wires. A major failure may occur soon.
  • #14 17603031
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    It`s not OK. What voltage was the measurement made and at what time?
    No, buddy. Which doesn`t mean you can`t. The measurement standard "talks" about it differently.
  • #15 17603167
    Jacek Rutkowski
    Help: 69
    Rate: 275
    The cable should have >20MΩ/km on the core compared to the other wires, but new. I don`t know how this relates to insulation aging?
    Does the standard take into account aging or are these hard parameters?
  • #16 17603233
    KaW
    Help: 170
    Rate: 306
    I had occupational health and safety in mind when taking measurements. Well, if the cable - its wires -
    If we measure it, there will be an electric charge on the wires.
    If we do not discharge this charge, a discharge will occur when we touch (e.g. with fingertips) the ends of the cable wires. If the megometer had a measurement voltage of 2500 V.
    This will be 2500V remaining on the wires..
    The quality of a megometer is measured by the measurement voltage and max. measured value.
    I was measuring telecom cables. Measuring cables is not fun.
  • Megger discharge to safe potential after testing
    #17 19868163
    Jacek Rutkowski
    Help: 69
    Rate: 275
    Currently, after completing the measurement, cable insulation testers discharge the cable to a safe potential, usually around 24V, and only then signal the end of the measurement. Only the old inductors didn`t do this...
  • #18 19868200
    Jacdiag
    Level 30  
    Help: 116
    Rate: 382
    KaW wrote:
    A "mag meter" is used
    Read: "mega omo "measure"
    :D
To detect potential damage in an underground cable between a house and a garage, several methods can be employed. Measurement of insulation resistance using a dedicated device is recommended, with values above 1MΩ indicating good insulation. Disconnecting all loads and checking the ammeter can also help identify leakage. For three-phase installations, measuring insulation resistance between each wire and ground is complex but necessary. A megohmmeter (megger) with a voltage of 250V or higher is typically used for these measurements. Values between 3 to 10MΩ may suggest moisture issues, indicating potential future failures. Proper safety precautions must be taken during measurements to avoid electric shock.
TL;DR: Most buried-cable leaks show as insulation resistance below 1 MΩ; “insulation resistance should be greater than 1 MΩ.” Use a megohmmeter to test each core to earth/PE and compare readings. Low‑megohm results need action. [Elektroda, Jacek Rutkowski, post #17596982]
Why it matters: This FAQ helps homeowners and electricians quickly diagnose house‑to‑garage underground cable faults and choose safe, effective tests.
What’s the easiest way to detect underground cable leakage between house and garage?
Isolate the circuit, then run an insulation resistance test between each conductor and earth/PE. Readings should exceed 1 MΩ. Lower values indicate leakage or insulation damage. Use the building’s earthing system or a ground rod as the reference. This simple test is the fastest way to confirm a fault. [Elektroda, Jacek Rutkowski, post #17596982]
Can I check it with an ammeter if all garage loads are unplugged?
Yes, for a quick check on single‑phase. Disconnect all loads and insert an ammeter in series on the feed. Any current above zero supports a leakage suspicion. Use full electrical safety precautions. This method does not quantify insulation resistance or locate faults. [Elektroda, arturdip, post #17594867]
Can I just watch the utility meter for consumption to confirm leakage?
Yes. Disconnect everything on the garage circuit and observe the meter. Any consumption indicates a leakage path or an unintended load. This is a simple field check when you can isolate that run. Verify isolation before relying on the reading. [Elektroda, kloszi, post #17594912]
How do I test insulation to ground if the ground rod is far away?
Use the PE conductor as your earth reference. The distance to the electrode is fine if PE is intact. A broken PE will invalidate the reading. Confirm continuity of PE before testing. [Elektroda, Krzysztof Kamienski, post #17596383]
What insulation resistance value is a clear red flag?
Below 1 MΩ. Leakage is rarely a perfect short, but healthy insulation reads higher. Measure between the grounding system and each conductor. Low insulation resistance indicates damage or contamination. Investigate before energizing the cable again. [Elektroda, Jacek Rutkowski, post #17596982]
Is a reading between 3–10 MΩ acceptable for a buried garage feed?
No. Values around 3–10 MΩ point to moisture between conductors. That condition often precedes a major failure. Plan remediation, drying, or cable replacement before it escalates. [Elektroda, rtvserwisant, post #17602990]
What test voltage should I use on a low‑voltage house‑to‑garage cable?
Do not assume 250 V is correct. Test voltages follow the cable’s insulation rating and standards. The 250 V setting relates to cables with about 2.5 kV insulation class. Use your tester’s guidance and the applicable standard. [Elektroda, KonradGatek, post #17601931]
How do I perform a basic megohmmeter test on this cable?
Use a megohmmeter to test each core to the others and to earth. “Measure the insulation of each wire in relation to the others and to ‘earth’.” How‑To: 1. De‑energize and disconnect loads at both ends. 2. Test L1, L2, L3, N against each other and each core to PE. 3. Record values and compare; investigate any low reading. [Elektroda, KaW, post #17597379]
Will a distant ground rod skew my readings?
Unlikely. Even a weak earth electrode often measures under 1 kΩ. Use it as a solid reference for insulation tests across many meters. Distance is not the limiting factor; continuity is. [Elektroda, Jacek Rutkowski, post #17596982]
Do modern insulation testers auto‑discharge the cable after testing?
Yes. Modern testers discharge the cable to a safe potential, about 24 V, before signaling completion. “Only the old inductors didn’t do this.” Treat old crank‑type testers with extra caution. [Elektroda, Jacek Rutkowski, post #19868163]
Is a "mag meter" the same as a megohmmeter?
Yes. The term refers to a mega‑ohm meter, used for insulation tests. Wording varies, but the function is identical. Use any reliable insulation resistance tester. [Elektroda, Jacdiag, post #19868200]
Do measurement voltage and time matter when interpreting IR results?
Yes. Always note the test voltage and how long you held it. Interpretation depends on both parameters. If results look marginal, repeat with proper voltage and timing. Keep those details in your report. [Elektroda, elpapiotr, post #17603031]
What IR values are typical for longer power cables?
A practitioner’s rule of thumb: about 100 MΩ for up to 1 km of cable. Treat it as orientation, not a strict pass/fail. Compare trend lines and installation context. [Elektroda, KonradGatek, post #17601931]
What should I expect from new cables versus aging ones?
New cables can exceed 20 MΩ per kilometer core‑to‑core. Aging, moisture, and contamination reduce readings over time. Track periodic measurements to catch deterioration early. [Elektroda, Jacek Rutkowski, post #17603167]
If my cable reads "OK", could there still be an intermittent fault?
Yes. Moisture can create low‑megohm readings that worsen over time. Intermittent paths may pass once and fail later. Re‑test after wet conditions and plan corrective work. [Elektroda, rtvserwisant, post #17602990]
What if the garage feed isn’t directly from the utility meter?
Then the meter‑watching method will not help. Use an insulation resistance meter instead. Test each conductor to earth and between conductors to confirm leakage. [Elektroda, CiekawyŚwiata, post #17596328]
