Converting Watts (W) to Watt Hours (Wh): Energy Consumption in Electronics Forum
Ralf200 35506 3
  • #1 489981
    Ralf200
    Let me give you an example: the computer has a 300W power supply, does that mean that it will pull 300Wh within an hour.
    I mean how much energy is consumed by a computer or other device.
  • #2 490007
    ACULA
    Help: 105
    Rate: 114
    as the name suggests it is time x power
    but it's better to calculate in kWh or 0.3kWxh
  • #3 490016
    Nemo
    Help: 9
    Rate: 72
    This power is the maximum that can be downloaded. In practice, it is about 150-160W differently, depending on the components installed and the computer load.
    Greetings.
  • #4 490026
    Ralf200
    I thought so too.
    Thanks a lot.
