Creating an Adapter from RJ11 to RJ45 for DSL Internet Connection: Specific Schematics?
kinxsize 38097 11
How can I connect an RJ11 DSL line to a router that has only an RJ45 input, and is there a schematic for an RJ11-to-RJ45 adapter?
You cannot connect an ADSL line directly to a router with only an RJ45 WAN port; you need a DSL modem, or a modem-router combo, because the router description says broadband access is via a DSL modem [#5243895] [#5244045] [#5244033] A simple RJ11-to-RJ45 cable will not make the connection work, since the devices use different functions rather than just different plugs [#5244033] [#5244074] If you want to keep this router, place a DSL modem in front of it and set the router up behind the modem [#5243895] [#5244045] For an old analog phone line, the modem must support ADSL Annex A [#5244074] [#5244091]
  • #1 5243630
    kinxsize
    Rate: 10
    Hey I have a telephone cube that splits my phone line into :
    telephone and dsl internet connection(RJ11)
    Previously I had a router with rj11 input and the internet was working
    Now I have a router with Rj45 input-(I don't want to have two routers)
    How do I make an adapter from RJ11 to RJ 45?
    Any specific schematic?
    Thanks
  • #2 5243706
    11111olo
    Rate: 795
    The best thing is to make a proper cable. And this router has an ADSL modem?
  • #3 5243865
    kinxsize
    Rate: 10
    So this is an ADSL router
    has anyone perhaps a diagram of the RJ11 to RJ45 cable
  • #4 5243895
    Alana
    Level 37  
    Help: 361
    Rate: 245
    I do not think that a router with an RJ45 input has the ability to connect to an ADSL line.
    Change the router or use a DSL modem + Router with PPPoE set and entered logins and passwords for neostrada or whatever you have.
  • #5 5244007
    kinxsize
    Rate: 10
    this is the router: http://catalog.belkin.com/IWCatProductPage.process?Product_Id=141064
    I have a DSL connection from a UK-online provider and there is a phone cube that splits the signal to the phone and a separate DSL line. RJ11 output.
    Will it be possible with an RJ11 to RJ45 adapter cable to connect this?
    Because this router does not seem to have an internal modem...?
    Thanks for your reply
  • #6 5244033
    pala22
    Help: 43
    Rate: 23
    That's why these plugs are different so that it doesn't occur to someone to connect an adsl to the WAN ethernet port
    NOT POSSIBLE
  • #7 5244045
    zetdeel
    Help: 719
    Rate: 883
    kinxsize wrote:
    read the descriptions carefully :!:
    1ac014bb4 With a Wireless G Router as the central connection point for your network, your computers can share files, printers, hard drives and - via a DSL modem - broadband access to Internet. You have clearly written that this router MUST coexist with an xDSL modem.
  • #8 5244047
    kinxsize
    Rate: 10
    So surely it is impossible with such a cable
    RJ45 TO RJ11 1M LEAD/CABLE What is left for me using this router?
    I would have to buy some modem with rj45 output?
    Deleted eBay auction link. [mbo] .
  • #9 5244074
    zetdeel
    Help: 719
    Rate: 883
    Unfortunately, it is not possible. I, if I were you, I would sell this router and buy a modem with a router.
    Is your phone line analog or ISDN?
    If it is analog then ADSL standard: Annex A
    If it is ISDN then ADSL standard: Annex B
  • #10 5244089
    kinxsize
    Rate: 10
    No this is an old analog phone line and why?
  • #11 5244091
    zetdeel
    Help: 719
    Rate: 883
    It is the modem that must have the ADSL standard: Annex A
  • #12 5244105
    kinxsize
    Rate: 10
    Well that's cool I already know everything just a little pity that it won't work with this cable "adapter", well actually there is no modem in this router....
    Thanks a lot for all the answers.
✨ The discussion revolves around the challenge of connecting a DSL internet connection using an RJ11 output to a router that only accepts RJ45 inputs. The original poster inquires about creating an adapter or cable for this purpose. Responses indicate that a direct RJ11 to RJ45 adapter is not feasible due to the differing functionalities of the ports; RJ45 is designed for Ethernet connections, while RJ11 is for telephone lines. It is suggested that the user needs a DSL modem with an integrated router that supports ADSL standards, specifically Annex A for analog phone lines. The consensus is that the current router cannot function without a compatible modem, and alternatives such as purchasing a new modem/router combination are recommended.
