TTI 880 and AMC 5010: Guide to Replacing Plucked Wires on Pear Cable Plug - Schematic Explanation
pin54 14358 4
  • Request for pear cable pinout and connector orientation
    #1 5288814
    pin54
    Help. I got rid of pear cables (from the plug). I have downloaded the schematic, but for me it is black magic. I tried to solder it by the markings on the plate and diagram: one to one, etc., except that on the plate in the pear there is a pin 4A, soldered it to the six in the plug, but it does not work. Someone can write it down, but like a complete electronic :) . Maybe it's enough if you give me the colors of the cables? Is it always the same?
    Ps. on the diagram the plug is from the side of the cables or from the socket side?
    EDIT: those plugin pages no longer relevant, I found a mark on the plugin, but the current one - without a CB like without a hand
  • Reassembled plug and documented six-wire pinout
    #2 5637689
    Didi1102
    Rate: 18
    6 I have the same problem but I do not have the :-) scheme and 2 cables have broken off when I manage to do it, I will write what and how :-) how I will find the schematic of course
    Added after 1 [hours] 27 [minutes]:
    I just managed to put it together and even hula
    and the wires in the plug are arranged
    1 - Blue
    2 - white
    3 - red
    4 - yellow
    5 - bare finished 5mm black
    6 - black
    I had torn out only 2 cables so I managed to do it without painfully folding my :-) greetings
  • #3 7971804
    Witoldinho
    Rate: 17
    I also have a gruche AMC-5010
    but the colors are different
    1- blue
    2-white
    3-red
    4-yellow (wrapped with aluminum foil screen)
    5- SCREEN (piece of black thermo-shrinking shirt)
    6-violet
  • #4 10557695
    saperq_4
    Thank you for the topic. It was very helpful!
  • #5 10799601
    RadekPawlak
    Rate: 21
    I confirm the correct wiring in the AMC-5010 microphone
    1-blue
    2-white
    3-red
    5-EKRAN (piece of black thermo-shrinking shirt)
    6-violet
    To ensure that the fault does not recur, a rather thick thermo shirt should be added to the cord.
