Connecting Wires to a New-Type Telephone Socket: A Step-by-Step Guide
stefanito 92472 16
How do I connect the wires from an old telephone socket to a new unmarked RJ11-style socket?
Connect only the two telephone line wires to the new socket; the polarity does not matter, and in a standard 4-pin RJ11 socket the line goes to the two middle contacts [#2322555][#2364944] If you have several cable pairs and do not know which one is active, find the pair with about 40–60 V DC (around 50 V) and use that pair [#2322555][#2359563] The forum also notes that the active pair is often a twisted white/blue or similar pair, but the exact colors depend on the installation [#2331718][#2359563]
  • #1 2322524
    stefanito
    Hello everyone,
    I searched and searched, but I couldn't find any information that would satisfy me ;-)
    Well, I have a gutted telephone socket (old type) - no clamps, etc., the cables are connected to the old socket, and from it come cables to 2 sockets of the new type.
    well, I would like to throw out all this crap and reinstall a new socket (of a new type), but the number of cables and the recombined way of connecting them exceeds my humanistic concept .....
    Can you tell me which wires I have to plug into which holes? ;-) in a new outlet...
    the new outlet simply has a series of places to plug in - maybe four or something, none of them marked.....
    phew...
    kiss,
    Stefanito
  • #2 2322555
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Only two wires are connected. It doesn't matter how you connect them (interchange). If you have something to measure, there must be a voltage of about 50V (constant) in the line. Connect these wires to the socket so that the device is simply connected with a signal. Without seeing the socket you bought, they can't tell you anything else. Is that the colors. As a rule, it is red and green in the outlet.
  • #3 2322940
    stefanito
    I don't have a meter unfortunately...
    it looks like:
    there are two independent collective wires - let's call them "cables" - each consists of several colored wires - let's call them "wires"
    2 wires were taken from each cable:
    once white + green
    and once white + blue ....
    two white ones come together on one connection of the old plug.
    green and blue converge on the second connection of the old plug.
    the other 2 connections of the old plug are not connected to anything...
    yeah. and how to connect a regular new plug to this set of 2 cables? connect the short wires to which inputs in the new plug?
    it has a series of 4 screw terminals, none is marked with anything...
  • #4 2323256
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    I'm guessing that you have more than one socket in your house, since there are two cables and the white and blue and green wires connect to each other. There is definitely a voltage of about 50V. Now, if you want to connect this new socket, first connect a telephone set to it and then try to connect to those points with some wires (two white and colored ones) and test connect to two terminals (holding the handset up) and see if you have a signal, if not then try on other terminals. If it is a typical old-type socket with a side RJ socket, then we connect the two screws on the right side. [/url]
  • #5 2331718
    Unitra153
    Level 19  
    Help: 28
    Rate: 45
    White with another color is usually always a pair, for example white with blue. There must be a power line on such a pair, as the previous colleague wrote.
  • #6 2359563
    eljak
    I will say this briefly
    In my region, TPSA installed sockets on a blue pair (blue and white twisted together) and Netia wanted them to be installed on an orange pair (orange and white twisted together). Individual case. It's best to take a meter or some voltage indicator in your hand and look for a pair with a voltage in the range of 40 to 60V
  • #7 2364944
    mozdzmar
    Help: 10
    Rate: 50
    If you have a new telephone socket, there is a socket for a telephone micro-plug. Usually four pins. In every telephone set (if someone has not converted), the two middle pins are the telephone line. This is also the case in the socket, if there are four wires, connect the middle ones to the wires disconnected from the old socket and it should be ok.
  • #8 2370424
    host74
    Hello !!!!
    In this unfortunate country two internal veins are used, it will probably be green and red, in any case two internal in germany, in turn two external ...
    Regards... :D
  • #9 2378669
    snicek
    Help: 6
    Rate: 31
    if you don't have a meter, you can check it in a simple but not very humane way, namely by briefly shorting each vein with a weak one until you get a "spark" from the short circuit. just don't play too much because firstly tpsa doesn't like it and secondly you can dial 0700... because that's how the so-called routing used to work, i.e. dialing a number and you'll pay a larger bill :D :D (unlikely, but it works and is possible)
    so if it sparks then those veins are the right ones. the rest, as the predecessors wrote, i.e. the rj11 plug must have these wires with voltage inside, 2-3 contacts
  • #10 2385950
    Marmat59
    Help: 9
    Rate: 25
    let me tell you this, in the old-type socket, the wires were plugged in from the right side (top, bottom), if you had two white wires twisted together and two blue with orange and the phone worked for you, it must be like this, and the new socket with a small input (RJ- i.e., RJ11) because that's what it's called, you should turn on the middle contacts, i.e. green and red, as host 74 wrote, and yellow and black should be free. If it should be correct. Regards
  • #11 2387328
    telwisalfa
    Help: 34
    Rate: 86
    stefanito ........ you must have connected this phone a long time ago and your colleagues are wondering how to give you a hint here .... if so, close this topic because you can write a book about it.
    .... sorry maybe I'm exaggerating?
  • #12 2387653
    Marmat59
    Help: 9
    Rate: 25
    I think so too.
  • #13 2390557
    przezorny
    Help: 9
    stefanito wrote:
    Hello everyone,
    you already connected, if not, give g
    phew...
    kiss,
    Stefanito
    Added after 54 [seconds]:
    if you do not connect .... then give gg
  • #14 8022874
    FCBJimi
    And I'm getting off topic a bit
    I bought a double socket to connect the phone and Router - unfortunately I can't do it.
    The phone works and the Router too, but only on one plug. Both devices work on the splitter. However, after 1:1 bridging, they still only work in one plug.
    This is the second socket in the apartment that I installed myself to pull the cables from the original socket that still exists and is single-plug established by TPSA.
    Regards.
  • #15 8023548
  • #16 8024880
    W.Wojtek
    Phones specialist
    Help: 245
    Rate: 430
    let it go. If you have problems with such a simple matter, buy beer (6X) and let the professionals earn money..
  • #17 8025406
    FCBJimi
    Will the number of red squares next to your nickname mean the percentage of your posts commented as not useful, unnecessary and offtopic??
    You don't want to help, don't help - You can get wise at home as long as your family allows you - Mr Wojtek.
    Moderated By Tracer2:
    Sorry, elementary question.
    Please start digging the forum for education.
✨ The discussion revolves around connecting wires to a new-type telephone socket, specifically addressing the challenges faced by a user with an old-type socket setup. The user describes having multiple colored wires from two cables, with specific combinations of white, green, and blue wires. Responses suggest that typically, two wires (often white with another color) are sufficient for connection, and that the new socket likely has four terminals, with the middle ones designated for the telephone line. Users recommend testing connections by trial and error, checking for voltage, and ensuring proper pairing of wires. Some responses caution against unsafe practices, while others provide insights into regional wiring standards and the importance of identifying the correct pairs for successful installation.
