Creating a DIY Jack-to-Cinch Cable: Step-by-Step Guide and Connection Instructions
13329 4
  • #1 16355876
  • #2 16355952
    kokapetyl
    Help: 1787
    Rate: 2099
    terminatorek123 wrote:
    How do you connect it all to which one?
    Golden together.
    On one side you have yellow and red, you connect them under blue and red respectively.
    As it turns out that the left channel is swapped with the right one, the latter ones are reversed
  • #3 16355966
  • #4 16355987
    kokapetyl
    Help: 1787
    Rate: 2099
    Can I have some numbers about what?
    Because I do not understand
    5 + 7 + 3 = mass, together
    4 + 2 = signal
    6 + 1 = Signal
    If the right channel will be swapped with the left channel, then swap 1 of 2.
  • #5 16356252
