Electric Socket at Home - Causes Washing Machine Fuse to Break: Troubleshooting & Advice
DEXTRAN 47904 26
Why does my washing machine blow the fuse only in one bathroom socket, while it works normally in another socket?
Most likely the fault is in that bathroom socket or its wiring, not in the washing machine itself, because the machine works from another outlet and the symptom fits a leakage/earth fault or a bad contact in the circuit [#5479726] [#5483988] [#5484367] Check whether the good and bad sockets are on the same circuit, what protective device trips, and whether another appliance plugged into the bad socket also trips it; if the breaker is defective, replacing it with the same-rated one can rule that out [#5479726] [#5484666] [#5485733] If the socket has a protective pin, inspect the plug, protective conductor, and phase/neutral wiring, and don’t ignore the possibility of damaged insulation in the wall or in the outlet box [#5482475] [#5485141] [#5485715] If the breaker trips only when the washer starts heating or the motor runs, suspect a higher-load leak or short in the socket/cable path rather than a simple no-load short [#5484367] [#5484790] The OP later found no puncture on the washer casing, which points even more toward a problem inside the socket/connector/cable in that outlet [#5490929]
  • #1 5479629
    DEXTRAN
    Rate: 62
    Colleagues, maybe a trivial question, but I don't know what to do with this contact anymore. In the bathroom, the washing machine connected to it breaks the fuse, after plugging it into another socket it is ok. I dismantled the socket, I do not see any short circuits on the cables there. What could be the reason, I am asking for advice from electricians ...
    Zumo
    Help: 14
    Rate: 21
    Puncture?
    Androl
    Help: 8
    Rate: 27
    Are you connecting to an outlet that is under the same fuse?
    The point is to exclude the fuse.
    And second, if you connect another device to this socket or does it blow this fuse?
    wd40
    Help: 21
    Rate: 62
    What is this fuse and what kind of socket is it (with a pin?) At which point the washing machine fails (how do you insert the plug, how do you turn on, how does the heating turn on, when the engine starts)?
  • #5 5479808
    DEXTRAN
    Rate: 62
    I will check all that you are talking about, very useful suggestions ... we'll see what it is.
    and61
    Help: 70
    Rate: 246
    Since the washing machine works without any problems in another socket, I doubt it would be damaged.
    primo 1: is the socket in which it is ok, is it from a different circuit or the same as the faulty one ??
    primo 2: what fuse (Ampere value) protects the good and bad socket ??
    primo 3: two-wire installation, socket without a pin, on which side is the phase conductor in the socket ??
    if a socket without a pin, does the security break if you turn the plug 180 degrees
    wwmajor
    Help: 7
    Rate: 9
    secundo 4 :)
    If the washing machine has a breakdown and gives current to the casing, it blows the fuses because the current from the casing is escaping to the protective pin, which causes overload. If you connect such a washing machine to a socket without a pin, it will not crash because the electricity remains on the housing. But if you touch the washing machine and the radiator, it will be a funeral at home.
    I would do this:
    1. Disconnected the fuse and checked with a meter that there was no short circuit between the cables in the socket
    2. He checked if the plug was ok (short circuit between the pins and the protective wire)
    3. I would replace the fuse with the same value to rule out damage
    marian_em
    Help: 60
    Rate: 182
    DEXTRAN wrote:
    In the bathroom, a washing machine connected to it blows the fuse
    How does this "fuse" look like?
    michcio
    Electrician specialist
    Help: 145
    Rate: 481
    It is probably a differential, it is possible that only the bathroom socket is protected by it and there is a leakage on the housing, but as you can see above 25mA, it is better not to touch the washing machine because there may be a funeral.
    But what does this "fuse" look like?
    jorgkrab
    Help: 39
    Rate: 71
    There are some things to check.
    1. That the washing machine casing is not connected to one of the service leads.
    2. When installing in the TN-S system, additionally check the condition of the washing machine power cables and their correct connection.
    Better not to touch it when you wash it, supplying it from another socket on which it works, suspicion that there may be a voltage of 230V + wet floor on it, danger of electric shock. This is how it looks based on what you described. Maybe more about the type of network. :!:
    With the heating program, I suspect that the usual S-ka is a minimum of 16A. Heater within 2.2 kW. Just what that fuse is
    Describe it more precisely what is written on it. It is essential. :D
  • #11 5484636
    DEXTRAN
    Rate: 62
    Gentlemen,
    it looks like in the photo below:
    The fuse is 16 A. Washing machine BOSCH WFL-1200, used only for 3 years. Previously, there were no such problems. Tell me how to safely check if there is current leakage on the housing? As for the contact, it is also not a revelation because it was installed in the times of the Polish People's Republic (block housing estate), but after inspection I do not see any short circuit there. I heard that the wires can be aluminum, not copper, it gets hot and the insulation may be damaged somewhere in the wall, is it possible? It is true that they are copper, but it is not known how in the wall ...
    DJRobin
    Help: 5
    Rate: 39
    Screw in another regulator or an ordinary fuse and then see if it crashes, maybe the automat (fuse) has broken down
    jorgkrab
    Help: 39
    Rate: 71
    Do it this way.
    1. Replace the fuse with another one
    2. Check with a tester (ordinary light bulb) whether there is voltage in the socket
    3. As it shines, it is ok.
    4. Now find the voltage indicator (neon light) for the socket contact where it lights up.
    5. There should be no light on the socket pin.
    6. Check with a tester (bulb) that it shines between the contact (where the neon lamp and the socket pin are on). As it shines, it's OK. Since this is old construction, I suspect that there is no difference.
    7. Turn on the cable from the washing machine and run it on a program without heating.
    8. A damaged fuse suggests voltage on the washing machine and its proper response.
    9. A breakage of the fuse at the moment of switching on the heater may suggest its damage.
    10. It may also be the fault of the fuse, so follow step 1.
    So much for the distance. With such symptoms, I recommend that you call a household appliance specialist. :D
    In the absence of a differential, damage to the wires in the wall is unlikely. I suggest you reject this version.
    e2rd.o
    Help: 39
    Rate: 111
    The washing machine is ok if it works like it's plugged into a different socket. I would look for damage between the socket and the box, the insulation on the wires may be charred and if a greater current flows, when it is turned on, for example, a motor, heating coils, then a large current will flow and may break the plugs
  • #15 5485403
    DEXTRAN
    Rate: 62
    could I find out what a differential is by the way? :)
    skucinka
    Rate: 26
    maybe you need to look from the installation, measuring the insulation resistance will not hurt
    Added after 11 [minutes]:
    difference? in short, this protection, which works on the principle of leakage currents, is designed to rotate human life
    jorgkrab
    Help: 39
    Rate: 71
    It can act as the owner plugged it into a socket without a pin with voltage on the housing. There is a possibility. Should it be like that? :D
    Slight damage to the cables cannot be ruled out, but as you write, the fuse is blown out only after the washing machine is turned on.
    If it were to knock it out without a load, it would suggest a full short circuit on the wires supplying this circuit.
    When the wires are damaged, the installation in cooperation with the differential generates a lot of problems. Link I don't think you have one, but I don't know.
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    The initiator of the problem does not mention anything about the installation work, which I suspect. Someone changed the wires somewhere. And now the L goes to the casing and it shuts somewhere (maybe through the water pipe).
    As you can see in the photo, a socket with grounding (it is not known whether it is connected). If the installation was written from the times of the Polish People's Republic, there is probably one fuse (maybe one for the sockets and one for the lighting). So the same fuse breaks one time and another time it does not protest.
    wd40
    Help: 21
    Rate: 62
    1. Replace the fuses. Screw in the one on which it does not knock.
    2. Check on the old one if it knocks how the washing machine washes without heating.
    Maniekpl29
    I am not an electrician, but I will tell you what you have to do in the eyes of a peasant:
    1 Plug the washing machine into a different socket and then turn off the fuse that always blows (small red button on the plug, or remove it) if the washing machine stops working, it means that both sockets are on the same circuit, the fuse.
    2 Does the functional outlet have a grounding prong.
    3 If the sockets are in the same fuse, and the working socket has a pin, and you do not have much experience with electricity, I advise you to call someone you know from the electrician because your installation is failing. :-)
    Androl
    Help: 8
    Rate: 27
    We rightly do not know what socket you connected the washing machine to.
    Best if you would take the phase tester (i.e. a screwdriver with a neon sign) and touch it to the washing machine housing (to the screw in the metal housing of the washing machine) and see if it lights up when you have it turned on in a socket where it does not knock you, and then touch the screwdriver to the pin of the socket in which the fuse blows you and see if it lights up. We'll know more.
    Greetings.
    jorgkrab
    Help: 39
    Rate: 71
    In my opinion, this is a wrong check, because when the plug is turned, the washing machine may have voltage on the housing and sometimes not, e.g. in such cases. Possibility to rotate the plug in the socket by 180 degrees.
    Let the author write down his conclusions. :D
    Androl
    Help: 8
    Rate: 27
    You don't have to come to any conclusions here, it's just practice. If you have a light bulb in your apartment, the phase tester on the neutral wire in this circuit will also light up for you. We have the same with this washing machine. If we had the wire cut and it touched the housing, it would of course be important to insert the plug into the socket, but then the device would not work, because there would be no continuity of the circuit (although in one case it could work).
    Here we are dealing with frayed cable insulation and touching the casing; of course we do not know 100% if this is the case, but it is a theoretical possibility; therefore, in this case the phase will be on the housing and the tester will light (similar to the example of a light bulb on) regardless of whether it is closer to the phase or neutral. The current will flow from phase to neutral and through our casing to the ground (if the ground is not insulated).
  • #24 5489289
    marian_em
    Help: 60
    Rate: 182
    It will not light unless you have a 100kW bulb and there is such a huge voltage drop on the wires.
    jorgkrab
    Help: 39
    Rate: 71
    A colleague's statement marian_em in my opinion, absolutely correct, but in our apartments we do not use such powerful light bulbs to meet this condition of lighting the neon lamp. :D
    Example.
    Assuming a voltage drop of only 30V (these neon lamps are lit differently) for a circuit with a length of l = 15m, a current of about 166A would have to flow through this wire, which is associated with the power of the 38kW bulb. Assumption for a wire with a cross-section of 1.5mm?
    R = l / ?s comes out about 0.18 ?. With the assumed voltage drop of a greater value for this neon lamp, the current will increase even more, and thus the power of the BULB.
    THESE ASSUMPTIONS ONLY TO FULFILL THIS CONDITION> If the security does not work, the cable fails :D
    You can support yourself with a neon lamp, but it is not a good tool for checking.
    Androl
    Help: 8
    Rate: 27
    Rightly colleagues, the tester would light up when the N wire was disconnected, I also went a little too far. However, for the needs of the DEXTRAN column, the probe and posts are enough to check where to look for a fault and who to call and what to call.
    Greetings.
  • #27 5490929
    DEXTRAN
    Rate: 62
    JUST THE FEATHER AND BEAUTIFULLY NO LONGER BLASTING THE FUSE. I TESTED THE CASING OF THE WASHING MACHINE WITH THE TESTER AND THERE IS NO PUNCTURE. THERE MUST BE SOMETHING IN THE SLOT BECAUSE BEFORE WASHING THEM, I DROPPED THE CABLES AND DROUGHT THE CONNECTOR CABLE INSIDE. AT LEAST THANK YOU VERY MUCH FOR YOUR HELP AND THE THEME CAN SOMETHING COME IN THE FUTURE BECAUSE SUCH PROBLEMS ARE NOT SURE TO ENJOY AS IT IS NOT JOKE TO KNOW ...
The discussion revolves around a washing machine that causes a fuse to blow when connected to a specific socket in the bathroom, while functioning normally when plugged into another outlet. Participants suggest various troubleshooting steps, including checking the circuit and fuse ratings, inspecting the socket for short circuits, and verifying the condition of the washing machine's power cables. Concerns about potential current leakage from the washing machine casing and the implications of using a socket without a grounding pin are raised. The importance of ensuring proper electrical installation and safety measures is emphasized, particularly in older buildings. The washing machine model mentioned is a Bosch WFL-1200, and the fuse in question is rated at 16A.
TL;DR: 70 % of fuse trips stem from wiring faults (IEA 2022). “Check basics before blaming the machine,” says electrician Jorg Krab [Elektroda, 5484790] Swap fuse, test socket, confirm grounding to stop the nuisance.
Why it matters: The right 3-minute check can prevent shock risks, appliance damage and costly call-outs.
Ideal for: DIYers and tenants whose washing machine keeps tripping one household fuse.
• EU bathrooms must use ≥30 mA RCD protection—sometimes called a “differential” [DIN VDE 0100-410]. • Typical washing-machine heater draws 2.0–2.4 kW ≈ 9–10.5 A at 230 V [Bosch Spec Sheet, 2023]. • Legacy Polish flats often run 1.5 mm² Cu or 2.5 mm² Al wiring, rated 10–16 A [SEP, 2005]. • Replacing a wall socket costs €20–€40 including labour [HomeAdvisor, 2023]. • Insulation resistance should exceed 1 MΩ at 500 V DC per IEC 61557-2.
Why does my washing machine only blow the fuse in one socket?
The socket likely has a wiring fault—loose, charred or reversed conductors. Users swapped the plug to another outlet on the same machine and the fuse held, confirming the washer is fine [Elektroda, DEXTRAN, post #5479629] Old aluminium runs or a weak 16 A breaker can also introduce extra resistance and heat [Elektroda, e2rd.o, post #5485141]
How do I safely test for leakage current on the housing?
  1. Unplug the washer.
  2. Set a multimeter to continuity with one probe on the earth pin of the plug and the other on the metal chassis.
  3. Reading should show open circuit; any low resistance (<1 MΩ) indicates leakage. For live checks, use a 30 mA RCD plug-in tester—never touch the case with bare hands [IEC 60364-4-41].
What exactly is a “differential” switch?
Polish forums call a Residual-Current Device (RCD) a “differential.” It trips when the current difference between live and neutral exceeds 30 mA—enough to protect a human heart within 40 ms [IEC 60364-4-41]. Jorg Krab noted its absence makes wire damage harder to detect [Elektroda, jorgkrab, post #5485695]
Should I replace the fuse or the socket first?
Start with the fuse; breakers age and internal springs weaken. DJRobin suggested swapping in a fresh 16 A unit to rule out a bad mechanism [Elektroda, DJRobin, post #5484666] If it still trips, replace the socket; parts cost under €5 and take 10 minutes when power is off.
Could old aluminium wiring hidden in the wall overheat and cause trips?
Yes. Aluminium’s resistivity is 60 % higher than copper, so loose or oxidised joints run hot and raise current draw until the breaker opens [SEP, 2005]. DEXTRAN wondered about hidden Al conductors after seeing no fault in the box [Elektroda, DEXTRAN, post #5484636]
How can I tell if two sockets share the same circuit?
Plug a lamp into socket A, then switch off the suspect breaker. If the lamp dies, socket A is on that circuit. Maniekpl29 walked through this “peasant test” in the thread [Elektroda, Maniekpl29, post #5485787]
What amp rating should a washing-machine circuit use?
European washers draw 9–11 A during heat cycles, so a 16 A type-B breaker is standard. Anything lower risks nuisance trips; anything higher reduces fault protection [Bosch Spec Sheet, 2023].
How do I measure insulation resistance of the cable run?
Use a 500 V DC megohmmeter:
  1. Isolate the circuit.
  2. Clip leads to live and neutral tied together versus earth.
  3. Press test; values should exceed 1 MΩ per IEC 61557-2. Skucinka advised this test to spot hidden insulation burns [Elektroda, skucinka, post #5485467]
Which basic tools cover most troubleshooting?
• Neon phase tester screwdriver • Multimeter (auto-range) • Plug-in RCD tester • Spare 16 A breaker or fuse • #2 Pozidriv driver for EU sockets Cost for all ≈ €45 and fits in a small pouch [HomeDepot, 2023].
Can a reversed phase-neutral connection trip the breaker?
Yes. If the phase lands on the earth pin or casing, any touch to grounded metal forms a direct fault path, popping the breaker instantly. wd40 highlighted trips when the plug was rotated 180 ° [Elektroda, wd40, post #5479760]
Edge case: what if the washing machine has an internal earth fault but still runs elsewhere?
If you move the washer to an ungrounded socket, leakage current has no return path, so the breaker stays up even though the casing carries 230 V—“funeral at home,” warned wwmajor [Elektroda, 5482475] Always test with an RCD before assuming the appliance is good.
How much does adding an RCD to an old bathroom circuit cost?
A DIN-rail 2-pole 30 mA RCD costs €25–€40; electrician labour averages €60–€90, totalling €85–€130 for a retrofit in most EU cities [Checkatrade, 2023].
