Safe Use of BEKO WMI 71442 Washing Machine & Bosch WTH8500FPL Dryer on One Socket
Duelowsky 24528 13
Can I safely power a washing machine and a Bosch dryer from one bathroom socket using an extension cord?
No—using an extension cord for a washing machine in a bathroom is not recommended, and the safer solution is to install a proper socket or separate circuit instead [#18527497][#18528015] One reply noted the common rule that devices above 2 kW should have their own circuit and socket; in this case the BEKO WMI 71442 is listed at 2200 W, while the Bosch WTH8500FPL is listed at 600 W [#18525934] The main concern is that extension cords are easily misused: people add other loads, use too-thin cables, omit the protective conductor, or place them where water can reach them [#18527497] Another practical suggestion was to fit a double socket in the existing box if possible, since that avoids the extension lead altogether [#18527327][#18527420]
  • #1 18524555
    Duelowsky
    Hi i am totally green on these issues. I have an apartment completed in 2012, I want to install a BEKO WMI 71442 washing machine and a Bosch WTH8500FPL dryer in the bathroom. Unfortunately, I only have one socket, so the devices would have to work on an extension cord. Is it safe? I do not want to make another circuit, so if it is impossible to do otherwise, I would buy a single-socket extension cord so that someone would not make a mistake and connect both devices.
  • #2 18524598
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    Manufacturers do not recommend extension cords for correct connection to the installation.
  • #3 18524602
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    Oh, that's some news. What is the correctness about?
  • #4 18524828
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    I don't know the problem in using an extension cord. Just buy something decent like Legrand.
    You can have two devices attached to the extension cord. After all, they will not work?
    Added after 46 [seconds]:
    Where is it written?
  • #5 18524974
    kkas12
    Help: 1076
    Rate: 4312
    A washing machine in the bathroom and a dryer. The iron will be mounted there, it will be a complete set. Three in one. And an extension cord.
    I wouldn't like to be a bad prophet, but Grim Reaper must be rubbing his paws.
    And there should be enough sockets to eliminate the use of extension cords.
  • #6 18525036
    CYRUS2
    Help: 1241
    Rate: 3530
    I rummaged in the Legrand offers, all "goodies" (USB switches) and the parameters poor and somewhere in the corner.
    Someone get the author an extension cord.
    There are ready-made 1.5m and 2.5m 3x1.5mm2 cables
  • #7 18525497
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    You searched poorly.
    https://legrand-sklep.pl/50097 are also without protection (ordinary) I have two of them myself.
  • #8 18525934
    takijasiu
    Help: 91
    Rate: 161
    Seriously - such an extension cord for the bathroom?
    In general, according to the art, there should be a separate circuit with only one socket for each device above 2kW - if the washing machine and dryer are each of more than 2kW, then the installation of such a splitter seems to be against this rule by 2kW.
    Bosch WTH8500FPL has a connection power of 600W (https://www.bosch-home.pl/lista-produktow/pranie-i-suszenie/suszarki-do-ubran/suszarki-z-pompa-ciepla/WTH8500FPL#/Tabs=section) -technicalspecs / Togglebox = -1142913952 / Togglebox = -1464035028 / Togglebox = 484132764 / Togglebox = 830275007 / Togglebox = -1008297566 /)
    BEKO WMI 71442 has a connection power of 2200W - admittedly according to British specification: https://storage.beko.co.uk/bekoupload/manuals/WMB71442.pdf
  • #9 18527305
    CYRUS2
    Help: 1241
    Rate: 3530
    Duelowsky wrote:
    Hi i am totally green on these issues. I have an apartment completed in 2012.
    Unfortunately, I only have one outlet .
    Do not "take out" on the author of the topic.
    This is not why the author of the topic set up the topic.
    It is as it is, the author of tiles and walls will not be ripped apart.
    Author - you wrote that there is one outlet.
    Can't double socket be used?
  • #10 18527327
    Duelowsky
    Thanks for the advice and answers. As for a double socket - I need a solution for now, without the help of an electrician, I do not know if I would be able to install this socket, if it is not some rocket science then I will consider it - I will do research. Thanks!
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    Yes, manufacturers of devices with more power (e.g. washing machine) do not recommend connecting to an extension cord. You are probably in the vast majority of what you never read the manual. In the manuals that I read, it was such a recommendation. Probably this recommendation is because, for most people, an extension cord is an extension cord. I will connect like the one from the link in this thread and having 5 more free additional sockets, it will connect a few more devices to it. Or connect an extension cord without a protective conductor. Or put an extension cord on the floor and the washing machine floods. Or connect a 0.75mm extension cable. Or connect an IP20 extension cord in the bathroom.
    By the way, who is offering an extension cord or a socket for a bathroom with IP20 tightness?
  • #13 18527892
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    There are opponents and supporters of the use of pseudo extension cords, as a last resort all responsibility falls to the so-called owner of this extension cord. As for reading and understanding the manual, the second thing is, most do not even look at it, and then the problem is that something is wrong and that the equipment broke down by itself.
  • #14 18528015
    kkas12
    Help: 1076
    Rate: 4312
    Don't write nonsense about the use of extension cords in bathrooms. An electrician should be aware of the danger this extension cord poses.
    It is the promoters of such a solution that will be responsible for the consequences of a possible accident.
    Even moral responsibility.
The discussion centers around the safety of using a BEKO WMI 71442 washing machine and a Bosch WTH8500FPL dryer on a single socket via an extension cord in a bathroom setting. Participants express concerns regarding the manufacturer's recommendations against using extension cords for high-power appliances, particularly in wet areas like bathrooms. The Bosch dryer has a power consumption of 600W, while the BEKO washing machine consumes 2200W, raising issues about the adequacy of a single socket for both devices. Suggestions include considering a double socket installation instead of using an extension cord, as well as the potential dangers associated with improper electrical setups in bathrooms. The conversation highlights the importance of adhering to electrical safety standards and the risks of using extension cords in such environments.
TL;DR: One socket for a 2.2 kW washer and 600 W dryer is risky; "separate circuit ... for each device above 2 kW." [Elektroda, takijasiu, post #18525934]
Why it matters: This FAQ helps apartment dwellers with only one bathroom socket decide how to safely power a washer and dryer without damaging equipment or risking shock.
  • BEKO 71442 series washer: approx. 2200 W rated power (heater-heavy cycles). [WMB71442 User Manual]
  • Bosch WTH8500FPL heat‑pump dryer: 600 W connection power. [Bosch WTH8500FPL Product Page]
  • Best practice: one dedicated circuit and one socket for appliances over 2 kW. [Elektroda, takijasiu, post #18525934]
  • Manuals warn against extension cords; avoid IP20 and 0.75 mm² cords in bathrooms; use protective earth. [Elektroda, Ktoś_tam, post #18527497]
  • Short heavy‑duty cords exist (3×1.5 mm², 1.5–2.5 m) if you must extend temporarily. [Elektroda, CYRUS2, post #18525036]
Can I run a BEKO WMI 71442 washer and Bosch WTH8500FPL dryer from one socket?
It’s not recommended. The washer can draw about 2.2 kW, while the dryer is 600 W. One socket plus an extension increases overheating and mis‑use risk. Experts advise a dedicated circuit and single socket for appliances over 2 kW. If you have only one outlet now, run only one appliance at a time until you add sockets. [Elektroda, takijasiu, post #18525934]
Is using an extension cord in a bathroom safe?
No, it raises shock and fire risks. Moisture, splashes, and flooded floors can energize exposed parts. As one expert put it, "An electrician should be aware of the danger this extension cord poses." Install enough fixed sockets instead of relying on cords. [Elektroda, kkas12, post #18528015]
What temporary extension cord spec is minimally acceptable?
Use a short, heavy‑duty cord with 3 conductors and 1.5 mm² copper (3×1.5 mm²). Keep it as short as possible, like 1.5–2.5 m. This reduces voltage drop and heating. Place it away from wet areas and strain points. Replace damaged cords immediately. [Elektroda, CYRUS2, post #18525036]
Should I replace the single outlet with a double socket?
Yes, it’s a cleaner near‑term fix than a power strip. The unit fits the same wall box and uses the same three conductors. "You connect the same 3 wires." If you’re not confident, hire an electrician to ensure safe terminations and testing. [Elektroda, CYRUS2, post #18527420]
Do manufacturers allow extension cords for washers and dryers?
Manuals commonly require a direct wall connection and forbid extension leads. The reasons include undersized cables, missing earth, moisture, and overloading multi‑way strips. "Manufacturers... do not recommend connecting to an extension cord." Using one may affect safety or warranty. [Elektroda, Ktoś_tam, post #18527497]
How many amps does the BEKO 71442 draw, and why does it matter?
Approximate current is power divided by voltage. At 2200 W on 230 V, current is about 9.6 A. Heating phases cause the highest draw. This helps you judge headroom when sharing a circuit with other loads. Keep margins to avoid overheating cords and terminations. [Elektroda, takijasiu, post #18525934]
If the dryer is only 600 W, can I run both together?
Combined load is roughly 2.8 kW, about 12 A at 230 V. A single outlet and extension may still overheat, especially with poor contacts. The recommended practice remains one dedicated circuit for >2 kW appliances. Avoid simultaneous operation on one socket. [Elektroda, takijasiu, post #18525934]
Are multi‑way power strips a good idea here?
No. Multi‑way strips invite extra devices and accidental overloading. In bathrooms, that adds severe shock risk. An edge case: adding an iron to the strip with washer and dryer dramatically increases hazard. Install fixed sockets instead. [Elektroda, kkas12, post #18524974]
What are the risks of low‑IP (IP20) cords in bathrooms?
IP20 isn’t splash‑proof. Water ingress can energize the strip and casing, causing shock or tripping. An extension on the floor can be flooded by a leaking washer. Use splash‑resistant equipment and keep connections away from moisture. [Elektroda, Ktoś_tam, post #18527497]
Who is responsible if an extension cord causes damage?
The owner bears responsibility for using non‑compliant or unsuitable extension cords. Skipping the manual, choosing poor cords, or unsafe placement can shift blame to the user. Read and follow the manufacturer’s instructions. [Elektroda, niewolno2, post #18527892]
How can I safely swap to a double socket without rewiring?
Three‑step How‑To:
  1. Turn off the breaker and confirm the socket is de‑energized.
  2. Remove the single outlet; install a compatible double unit in the same wall box.
  3. Reconnect the same three conductors to L, N, and PE terminals; refit and test. [Elektroda, CYRUS2, post #18527420]
Is buying a premium brand (e.g., Legrand) strip enough to make it safe?
Quality helps, but it doesn’t remove bathroom risks or manufacturer prohibitions. A premium strip can still be misused or flooded. As one user noted, "Just buy something decent like Legrand," but location and load still matter greatly. [Elektroda, Magic_moon, post #18524828]
What cord mistakes should I avoid with laundry appliances?
Avoid cords without a protective earth, lightweight 0.75 mm² leads, and IP20 devices in bathrooms. Don’t place cords on the floor where leaks can reach them. Don’t daisy‑chain strips. These errors are common and dangerous with high‑load appliances. [Elektroda, Ktoś_tam, post #18527497]
I have one socket and need a solution now. Whats the safest stopgap?
Use only one appliance at a time. If you must extend, pick a short, heavy‑duty, grounded cord and mount it away from splashes. Plan to install a second socket or dedicated circuit soon to eliminate the extension. [Elektroda, kkas12, post #18528015]
