Siemens IQ 500 "(WD14H420GB). - AKO 731799-06 Fuse blown
snowgold 9225 3
  • Repeated LNK304 and 100 ohm resistor failures
    #1 17135217
    snowgold
    I got tired of replacing the 100 Ohm resistor and LNK304. The washing machine starts normally.
    But after some ignition functions, the fuses are connected and I have tried it with more than 10 PCBs.
    Can anyone give me a solution for the resistor value?
    Or what can we do well on this?
    Sir, I work in a hotel, we have 200 plus washing machine in every room. After replacing the new PCB, it works. I'm afraid we can fix it or not?
    same PCB for
    Bosch washing machines, model WAA24260EN.
    Electronics symbol:
    AKO 716200-01
    BSH 5560 006 901
    But after some ignition functions, fuses are fused and I tried it with more than 10 PCBs.
    Can someone give me the solution for the value of the resistor?
    Or what can we do well in the case?
    sir i am working ih hotel we have 200 plus washing machine in each room .after replacing the new PCB its working .so i am worried we can make it repair or no?
    same PCB for
    Bosch washing machine, model WAA24260EN.
    Symbol of electronics:
    AKO 716200-01
    BSH 5560 006 901
    • Siemens IQ 500 "(WD14H420GB). - AKO 731799-06 Fuse blown 1705973500_1420978783.jpg (2.73 MB) You must be logged in to download this attachment.
    • Siemens IQ 500 "(WD14H420GB). - AKO 731799-06 Fuse blown 5152770100_1420978787.jpg (3.21 MB) You must be logged in to download this attachment.
  • #2 17135270
    Loker
    Help: 575
    Rate: 721
    I don't get you... What kind of board do you have? 731799 or 716200? There are different products and different SMPS chips - LNK 304 vs. TNY264.
  • #3 17135607
    snowgold
    AKO 731 799-06.
    FSD - 21 Advance.
    The ones shown in the picture
  • Overvoltage spikes likely blew the fuse resistor
    #4 17148210
    Loker
    Help: 575
    Rate: 721
    In most cases failure you described is caused by overvoltage (spikes) from the mains. You can try to reduce them by applying surge protectors like this (of course matched to your power supply network) but hard to say if it will help or not.
    You can also play with value of fuse resistor - in theory higher value, a little bit beter overvoltage resistance - but also higher standby power consumption and if resistor will be to big washing machine will not work.
