Testing MOSFET: Analyzing Conductivity of B-Z, D-Z, and Z-D Connections with Power Meter
Wojtek 24 lata 65296 6
  • #1 5498950
    Wojtek 24 lata
    Help: 7
    Rate: 72
    How to check the MOSFET?
    I have one that, after powering (with the meter) the connector (B-Z), conducts between D-Z and Z-D (i.e. the same in both directions). When discharged, it is not conductive at all.
    I have a replacement to buy, but is there such a need, maybe this transistor is working ??
    Thank you.
  • #2 5498978
  • #3 5499230
    Wojtek 24 lata
    Help: 7
    Rate: 72
    I checked as my friend advised.
    The new irf mosfets, after charging the gate, lead both towards DS and SD (polarity is irrelevant here).
    So the ones I have now must be functional because they are behaving the same.
  • #4 5499238
  • #5 5615153
    pniewy
    Rate: 8
    What does it mean to charge the gate? How to do it?
  • #6 5615194
    hefid
    Rest in Peace
    Help: 546
    Rate: 6173
    I transferred from: Electronic Components
  • #7 5615321
    Paweł Es.
    Help: 1236
    Rate: 693
    The gate is galvanically separated from the channel and forms a kind of capacitor with it.
    If you apply any voltage between the gate and the source, this capacitor will charge. If the voltage between the gate and the source is greater than the threshold voltage for a given type of MOSFET, the transistor will start to conduct.
    Note: the gate-source voltage should always be less than +/- 20V. Otherwise, the gate-channel breakdown will occur and the transistor will be irretrievably damaged. Static electricity can do this too
    Checking the MOSFET transistor (with enriched channel - non-conductive when Ugs = 0V).
    1. We close the gate with the source: then there should be a gap between the source and drain (channel cut off)
    For the N-type channel, plus we put it on the drain.
    With the opposite polarity, the diode should open, connected in parallel to the transistor channel (drain-cathode, source-anode) - voltage drop approx. 0.8V
    For P channel, minus drain, plus source and gate.
    2. Checking if the transistor turns on:
    After applying a voltage higher than the threshold (usually> 3V) between the gate and the source, the transistor should open - the resistance measurement of the source channel should show low resistance.
The discussion revolves around testing a MOSFET to determine its functionality, specifically focusing on the B-Z, D-Z, and Z-D connections. The user initially inquired about checking a MOSFET that conducts between D-Z and Z-D after being powered, but shows no conductivity when discharged. Responses suggest charging the gate circuit to check conductivity between the drain and source (DS), with a recommendation to use a simple meter powered by a 6F22 battery. It was confirmed that new IRF MOSFETs behave similarly when the gate is charged, indicating that the user's MOSFETs may also be functional. The importance of maintaining gate-source voltage within safe limits to prevent damage was emphasized, along with a method for testing the MOSFET's channel behavior.
