Low Sound Output in Experimental IRFZ24N Mosfet Amplifier Circuit: Possible Reasons?
minde1 8829 8
  • #1 12641142
    minde1
    Hi i am made circuit with one mosfet irfz24n.My used circuit- 10k resistor connect to gate and drain.When i test circuit, and hold audio input with finger, i have high tone, but when connect audio signal, not have high sound. What no have high sound ?
  • #2 12657107
    adamantan
    Help: 21
    Draw picture of your electric circuit. One resistor is not enough.
    In practice this transistor is not a good choice for MOSFET Class A amplifier, but if you want ...
  • #3 13964852
    WRadek
    Help: 59
    Rate: 52
    I'm sorry, i know this was a long time ago, but your circuit will not work.
    You must learn a lot. Start with basic bipolar transistor amplifier.
  • #4 13966998
    minde1
    I have made a working transistor power amplifier. Bipolar transistor is good to practice with amplifier, but now I have a question: why when I touch the MOSFET gate I have a big hum in the speaker? This circuit only has the MOSFET connected to power and speaker.
  • #5 13968207
    WRadek
    Help: 59
    Rate: 52
    Please sketch your circuit and show it here i it will help to help you.
    On the other hand, when you touch any other amplifier in - you will hear a hum in your speakers :)
    Best regards
  • #7 13970602
    WRadek
    Help: 59
    Rate: 52
    Really so easy circuit? I just can't belive this. Where are capacitors? What is the Voltage of power supply? How do you put a voltage on the Gate?
  • #8 13996871
    minde1
    I used atx 12v voltage, you say when touch amplifier input to - have hum, but if I used one transistor connect to power supply no hum, but one mosfet touch gate is big hum, whats is difference to mosfet and bjt ?
  • #9 14000115
    WRadek
    Help: 59
    Rate: 52
    Draw your circuit, otherwise i'm not able to help you.
The discussion revolves around a user's experience with a circuit using the IRFZ24N MOSFET, which exhibits low sound output when an audio signal is connected. Initial responses suggest that the circuit design may be inadequate, as a single resistor is insufficient for proper operation. The user notes that touching the MOSFET gate produces a significant hum, indicating potential grounding or circuit design issues. Further inquiries highlight the absence of capacitors and the need for a proper power supply voltage. Comparisons are made between the behavior of MOSFETs and bipolar junction transistors (BJTs), with emphasis on the differences in their operation and resulting audio output.
