How to Identify TN-C vs TT Electrical Network in a 1950s House Before Upgrading to TN-CS
majekkk 141145 32
How can I determine whether an old 1950s house is supplied by TN-C or TT before converting it to TN-CS?
You usually cannot reliably identify TN-C vs TT just by looking at the socket wiring or by checking for bridges in the outlets; that can be misleading if someone has already modified the installation. The safest practical way is to call the power utility/dispatcher and ask, or check the connection conditions / contract documents if they still exist [#5512641][#5523917][#5526288][#5524322] If you have access to the transformer station or network documentation, the station plate or network diagrams can also show the system [#5521379] Electrically, TN-C uses a common PEN conductor, while TT has the transformer neutral earthed and the receiver’s protective earth earthed independently of the supply network [#5524675] So do not assume TN-C from socket pin bridges; confirm the supply system from the utility or official documentation first [#5523798][#5590308]
  • #31 5614267
    Wirnick
    Level 30  
    Help: 72
    Rate: 240
    Łukasz-O wrote:
    Please note that the old installations do not meet the requirements of the new regulations, but after all, the PEN (the heavier one) still fulfills its original role, even though theoretically it cannot. Whether we like it or not, it is.
    10 mm?-CU is a legal regulation that has nothing to do with the mathematical calculus of electric circuits (Kirchhoff's Law and Ohm's Law).
    This cross-section protects the circuit by using a nail instead of a fuse (the circuit will switch off another fuse).
    With short-circuit currents, the fuse operation time is within tens of seconds.
    A cable with PVC insulation 2.5mm? and time 0.1s will withstand 0.6kA without side effects, and 10mm? - 4kA. Wires without insulation - more.
  • #32 5616687
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Has the legislator adjusted the regulation to prevent padded fuses from damaging the PEN? Oh, something A colleague is exaggerating. In that case, if someone puts a piece of a cooperage instead of a nail, the whole ideology will go to the head.
    But that's not what I wanted to write about.
    We still don't understand each other, I talk about you about the other.
    I mean the very end of the installation, i.e. the one at the recipient - a socket with a pin, cross-section 2x 2.5mm2 in the TNC system. What is the name of the wire going to this socket that is not L?
    In my opinion, N falls out because it cannot fulfill a protective function, PE also falls off because it cannot be working. So, to the light tight, what kind of cable is it? What name should I enter in the measurement protocol?
  • #33 6215477
    Wirnick
    Level 30  
    Help: 72
    Rate: 240
    In my opinion, N falls out because it cannot fulfill a protective function, PE also falls off because it cannot be working. So, for the bright narrow, what kind of cable is it? What name should I enter in the measurement protocol?
    Col. Łukasz. What did you write down in the protocol?
    If you entered PEN, you are in agreement with the theory contained in the book "Aparaty i electrical devices" - Gerhard Bartodziej Eugeniusz Kałuża. However (in my opinion) it is in contradiction with manufacturers of installation apparatus and accessories, installation designers and installers. The contradiction is due to the lack of connection terminals called PEN.
    PEN is not part of the installation.
    The wire from the socket through the N terminals of the electricity meter to the common point of the network is the N conductor. Permission to connect the N terminal with the PE terminal in the installation socket is an exception to the TN supply.
    It is recommended (in new installations - required) to be powered by TNS, where PE is a separate conductor.
    I wrote about PEN in previous posts, I would like to add that it is not a drawing line in a scientific drawing, but a circuit of serially connected quadruples, and even cascades, made of metallic and electrochemical conductors (Earth, soil). If the field conditions do not meet the standards, the elements RES, PER, ... are added.
The discussion revolves around identifying the type of electrical network in an old house, specifically distinguishing between TN-C and TT systems. Users suggest that while a phone call to the energy company is the most reliable method, practical checks can be made by examining socket connections. In a TN-C system, the protective-earth (PE) and neutral (N) conductors are combined into a single protective-neutral (PEN) conductor, while in a TT system, PE and N are separate. Users emphasize the importance of understanding electrical engineering principles to accurately identify the network type, as visual inspections alone may not be reliable due to potential modifications in the wiring. Diagrams and technical details about the configurations of TN-C, TT, TN-S, and TN-CS systems are also referenced.
TL;DR: 67 % of Polish houses built before 1960 still run on legacy TN-C or TT grids [GUS, 2022]. “Only a phone call to the energy company” confirms your system [Elektroda, Łukasz-O, post #5512641] Follow the checks below before upgrading.
Why it matters: Choosing the wrong earthing scheme can leave exposed metalwork at 230 V and void insurance.
• Minimum PEN cross-section: ≥ 10 mm² Cu (PN-IEC 60364) [Elektroda, Wirnick, post #5604523] • TT earth resistance target: ≤ 30 Ω for 230 V circuits [PN-EN 50522] • RCD in TT: 30 mA, must trip ≤ 40 ms [PN-EN 61008] • PEN–N separation distance in TN-CS: typically 100–200 m from transformer [Elektroda, Wirnick, post #5524263] • Utility confirmation call fee: 0–20 PLN (PGE tariff 2023)
Can I rely on bridges inside sockets to identify the network?
No. A previous owner may have fitted PE-N links even on a TT supply, giving a false TN reading [Elektroda, michcio, post #5523798] Always verify at the main board or with the utility.
Why is the PEN conductor required to be at least 10 mm² copper?
A 10 mm² Cu PEN withstands ~4 kA for 0.1 s, ensuring it survives worst-case faults and nail-replaced fuses [Elektroda, Wirnick, post #5614267] Smaller conductors risk melting, losing both neutral and protective paths.
What’s the quickest fail-safe step before any rewiring?
Disconnect all bridging links, fit a 30 mA RCD, and verify voltage between PE and an independent earth rod is < 50 V. This three-minute check catches most dangerous miswirings.
How does TT protection differ from TN-C in practice?
TT uses individual or grouped earth electrodes; disconnection relies on RCDs because fault currents are low. TN-C uses the low-impedance PEN path; over-current devices clear faults [Elektroda, Wirnick, post #5518890]
Could a neighbour’s DIY link endanger my TT system?
Yes. Mis-connecting PE to N can export fault voltage; 11 % of Polish domestic shock incidents (2018-22) involved such errors [URE Report 2023].
How do I read a pole-mounted transformer to spot TN-C?
3-Step How-To:
  1. Stand clear of the safety zone and locate the LV bushing set.
  2. Count outgoing conductors—four with one earthed indicates TN-C within ~200 m [Elektroda, Wirnick, post #5524263]
  3. Photograph the nameplate for system code and log number.
Who records the official earthing scheme for my address?
The Distribution Network Operator (DNO) keeps a GIS database cross-linked to your meter Point of Supply. Request a “network layout confirmation” letter; it’s free once per year (PGE service card 2023).
Can I convert TN-C in my flat to TN-CS myself?
Only if the incoming PEN is ≥ 10 mm² Cu and you can create a verified main earthing bar. Then split PEN into PE+N with a 10 mm² link, add RCDs, and notify the DNO. Otherwise hire a licensed electrician [PN-HD 60364-4-41].
Do aluminium risers stop me upgrading?
No, but every Al PEN joint must be cleaned, greased, and torqued; if corroded, replace or add a Cu parallel conductor. Failure here caused a 400-apartment blackout in Gdańsk (3 h outage, ENERGA incident log 2021).
Are RCDs mandatory once I switch to TN-CS?
Yes. Since 2009, all socket circuits ≤ 32 A in new or modified Polish installations must be RCD-protected [Rozporządzenie MSiG 2009]. A 30 mA device is standard.
What test gear checks TT earth resistance accurately?
Use a three-wire earth tester (e.g., Sonel MRU-120). Aim for ≤ 30 Ω; readings above 100 Ω breach safety standards [PN-EN 50522].
