Cable cross-section for 25m distance and 10 kW power supply to garage
rysiu.e 48007 10
What cable cross-section should I use to supply a garage 25 m away with a 10 kW three-phase load?
For a 3-phase supply, a 5×4 mm² cable should do the trick [#5523498][#5523520][#5525168]
  • #1 5523483
    rysiu.e
    Rate: 65
    Hello all. As I wrote in the title, I need to choose a cable for a garage 25m away and a power consumption of 10 kW. I do not know what the section is, please help.
  • #2 5523498
    mietekn
    Help: 400
    Rate: 161
    The question is how many phases should there be?
  • #3 5523520
    rysiu.e
    Rate: 65
    I forgot to add 3 phases sorry.
  • #4 5525168
    Stary1952
    Level 32  
    Help: 164
    Rate: 242
    5X4mm? should do the trick.
  • #6 19770603
    jazeck
    Rate: 22
    I have a similar distance of 25-26m, white cable in a conduit, I want to pass 3-phase 5 wires 10mm?, can you ?! I have access to this, Load acc. contracts for 10-12A for 3 phases, if I remember correctly ;) summer house. Can you white?
  • #7 19770624
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1624
    jazeck wrote:
    Can you white?
    The white one has a symbol, for example: YDY and this should be given, you cannot - for placing in the ground the symbol is YKY or YAKY.
  • #8 19770658
    jazeck
    Rate: 22
    Well, yes, but I myself have seen installations on large objects on the connections between street lamps on white in a blue conduit and has been in operation for 7 years ... Thicker cable less loss ... I have free ... 25m, it is better to charge in a conduit and black cable with a smaller cross-section? How long will this white one last? 10-20 years? that's enough for me ;)
  • #9 19770717
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    What do you expect from us? For me, you can even power the gazebo with the aerial.
  • #10 19770799
    r103
    Level 37  
    Help: 284
    Rate: 971
    Well, what the author of the thread expects - of course, as usual - that his idea of putting "building" wires into the ground will be supported here enthusiastically and with applause - then he will do it / because he will do it anyway / with a sense of acceptance by "professionals :D
  • Warning against propagating unsafe cable-sizing advice
    #11 19863014
    jazeck
    Rate: 22
    Nobody is going to dig twice for this it goes arota fi 50 in one piece ... he will live 5 years, he will live, or maybe 10 ... There are also white sheep for public buildings and among black sheep.
    Moderated By Topolski Mirosław:
    The fact that Col. saw erroneous solutions does not mean that he has to propagate them.
    3.1.11. Publishing posts that do not contain substantive content with harmful advice.
    He got the correct hint col.
The discussion revolves around selecting an appropriate cable for a 25m distance to supply 10 kW of power in a garage, specifically using a 3-phase system. Initial responses inquire about the number of phases, leading to suggestions for cable sizes. Recommendations include using a 5x4mm cable, while others mention a 10mm cable for similar distances. The conversation also touches on the types of cables suitable for underground installation, with references to specific cable types such as YDY for above ground and YKY or YAKY for underground use. Concerns about the longevity and performance of different cable types are raised, with some participants expressing skepticism about using non-standard cables for permanent installations.
