Outdoor Cable Choice: Wire or Cord for 20m Garage to Sub-Meter Connection Year-Round
mochna830 26691 7
  • #1 16697805
    mochna830
    I want to let the cable from the neighbor 20m from the garage to the sub-meter. The cable will be attached to the handles and routed along the garage wall under the gutter. The question is: what cable to use - wire or cord? Of course, it is a year-long period.
    Thank you in advance for your reply, best regards.
  • #2 16697864
    kokapetyl
    Help: 1787
    Rate: 2107
    As a permanent connection is used as you called "wire"
    However, more important are other parameters, its cross-section, number of wires and type of cable.
  • #3 16697876
    rafcio_21
    Help: 137
    Rate: 299
    The question is why this cable? Will it be for powering something or for the Internet, or maybe for a camera? anyway i would use a wire. such as black soil, e.g. YKY 3x1.5mm. Write something more about using this cable.
  • #4 16697906
    mochna830
    In the garage I use small power tools - 200w hairpins, 620w jigsaws and 130w dremel + lighting.
    2 or 3-wire cable (the neighbor has electricity from the apartment to the garage, where we have old installations in the apartment ... so if he did not make a new installation then 2 wires, if he did 3) cross-section 1.5.
    The neighbor suggested a line, although I don't know why.
  • #5 16697920
    rafcio_21
    Help: 137
    Rate: 299
    The cable will be more expensive and requires sleeves at the end. The so-called ground cable (black) e.g. YKY 3x2.5mm is more resistant to external conditions.
  • #6 16697946
    kokapetyl
    Help: 1787
    Rate: 2107
    mochna830 wrote:
    cross section 1.5.
    It should already be 3x2.5mm?. Why three wires, new installations are supposed to have it. The new installation should already be 3x x and 2.5mm? just in case you need more power.
  • #7 16698135
    r103
    Level 37  
    Help: 284
    Rate: 971
    Not so just in case - only 2.5 square millimeter sockets ...
  • #8 16698160
    djlukas
    Help: 94
    Rate: 266
    Just in case I would put 4x10mm ;-)
The discussion revolves around the choice of cable for a 20m connection from a garage to a sub-meter, with considerations for year-round use. Participants suggest using a wire, specifically recommending a YKY 3x1.5mm or YKY 3x2.5mm cable, depending on the power requirements of tools used in the garage, such as hairpins, jigsaws, and dremels. The importance of cable cross-section, number of wires, and resistance to external conditions is emphasized. There is a debate on whether a 2-wire or 3-wire configuration is necessary, with suggestions leaning towards a 3-wire setup for new installations to accommodate potential power needs.
