Windows 7 Netbook: UIOJKLM Keys Typing Numbers Instead of Letters—How to Fix?
Tabalugaaaaa 130209 5
  • #1 8546905
    Tabalugaaaaa
    Rate: 16
    Hello, I have a problem, I have a netbook on windows 7 and when I press the uiojklm keys, the numbers 4561230 come out and I can not change it Maybe someone of you knows how to change it?
  • #2 8546915
    Laptopstore
    Rate: 50
    if it's in a laptop - turn off num-lock
  • #3 8546933
    Tabalugaaaaa
    Rate: 16
    When I press the button near the left ctrl (fn), I write normally but only when I press it when I stop holding it, I write wrong again and I do not have a key that is signed num-lock
  • #4 8546954
    Laptopstore
    Rate: 50
    it should be described as num-lock, if you say no, it turns on and off num-lock by a combination of the FN function key and some other, but it should also be described, e.g. with a different color, different font, if you have instructions, check in instructions. If you hold down the FN key you turn off the function and therefore you can type normally - you just need to find with which key it turns off.
  • #5 12032061
    verring95
    Rate: 21
    I also had this problem but after pressing the Num Scr key (next to F12 :) ) everything is back to normal
  • #6 12032121
    RADU23
    Help: 2428
    Rate: 1732
    Enter the nootebook model.
