How to solder a PSU plug – where are + and -: inner pin or outer shell?
macio_28 27328 3
  • #1 6207129
    macio_28
    Rate: 11
    Hello!
    I have a power supply with a plug like in the picture.
    I have a problem because my younger brother accidentally tore the cable from this plug when the power supply was charging such a small car with a battery.
    I cut the plug along with a knife and I don't know where to solder the minus and where the plus ?? So either outside or inside this plug.
    Please help.
    GREETINGS!
    gonzalo
    Help: 194
    Rate: 157
    The plus is usually inside that plug.
    ion-tichy
    Help: 147
    Rate: 145
    Usually the minus is on the outer ring a + inside.
    However, there are exceptions and it may be the other way around (but it is a rarity and it is usually quite strongly marked, for example on the charger itself) - it is worth looking at the markings of the device that this power supply supplies
  • #4 6214882
    macio_28
    Rate: 11
    Thanks a lot for your help !!!
    GREETINGS!!
