How to type ~ on keyboard when the key outputs `` instead?
Damianikot 66848 10
How can I type a tilde (~) when pressing the tilde key produces backticks instead?
Press Shift with the ` / ~ key located below Esc and above Tab, then release the keys and press Space to produce ~. [#6146586] [#6146634] If this behaves differently, check that the keyboard layout is set to Polish Programmer rather than another layout. [#6146647] If the tilde is needed to open a game console, make sure the game’s console window is enabled. [#6149457]
  • #1 6146518
    Damianikot
    Rate: 9
    I have a problem where it wants to type tilde ~ and she writes `` `` such a sign (I wrote a few to make them more visible)
    The other keys work fine, and I need a tilde and don't have it?
    Has anyone had such a problem?
    I am waiting for advice and best regards.
  • #2 6146551
    K!lleR
    Help: 456
    Rate: 131
    And does Shift, dear colleague presses?
  • #3 6146586
    Oksy
    Help: 41
    Rate: 26
    This character `is typed with the Shift key pressed and then, by releasing both previously pressed, you press the space bar. Something like this comes out ~
  • #4 6146634
    warczyk_nbr
    Help: 6
    To create a 'Tilde' [~] you need to press two keys (Shift + `/ ~) (key under {ESC}) (above TAB) on the left side 1 /! (exclamation mark) it was more precisely xD
    I don't think there is any philosophy, right?
    PS
    The shift key is the primary key for various combinations
    e.g.
    Shift +; =: Shift +, =
  • #5 6146636
    Damianikot
    Rate: 9
    And is it not possible to somehow set the tilde to be simply after pressing the tilde? That's what I used to have and today I see that it doesn't work.
  • #7 6146664
    Damianikot
    Rate: 9
    PL Polish (Polish)
    Polish (programming)
    I also remember that I had such a problem and I know that I moved something, but I don't know what xD
    There is no such program, for example, that you could assign each letter to yourself where it goes, and this program can be useful for something?
    :arrow: KeyTweak 2.2
  • #8 6147541
    Damianikot
    Rate: 9
    Nice program but no tilde, all other characters except this one.
    Added after 7 [minutes]:
    and so it is a tilde for me to open the window so I can't copy it, it can't crash twice.
  • #9 6147783
  • #10 6147790
  • #11 6149457
    Damianikot
    Rate: 9
    ok, you had to turn on the window in the game
The discussion revolves around a user's issue with typing the tilde character (~), which instead produces a backtick (`). Various responses suggest checking the Shift key usage and keyboard layout settings, particularly if the Polish Programmer layout is active. The user recalls having previously configured the tilde key differently and inquires about software options for remapping keys, mentioning KeyTweak 2.2. Additional advice includes changing in-game key bindings for the tilde if it is used for console commands in games.
