No Polish characters - No Polish characters and a keyboard of the Polish languag
Razormocz 27840 10
Jak w Windows 7 przywrócić polskie znaki, gdy nie działają skróty przełączania klawiatury i zniknęły ustawienia języków?
Najskuteczniej było przywrócić system do punktu przywracania — w tym wątku to naprawiło problem z polskimi znakami [#16902562][#16902685] Jeśli chcesz tylko odtworzyć układ klawiatury, wejdź w Panel sterowania → Region i język → Zmień klawiatury, ustaw domyślny układ na „Polish Programmer” i użyj przycisku „Dodaj” [#16902230] Gdyby problem wrócił, warto uruchomić `sfc /scannow`, choć tutaj nie naprawił błędu [#16902539] Dodatkowo sprawdź stan dysku SMART w CrystalDiskInfo, obecność `ctfmon.exe` oraz ewentualnie użyj `dism.exe`, `Intlcfg.exe` albo skanu FRST [#16902562]
  • #1 16902151
    Razormocz
    Good day.
    From day to day, the keyboard refuses to obey and does not write Polish characters. Please forgive for signs without a line or tail, but this is the thing. Keyboard shortcuts CTRL + SHIFT, or ALT + SHIFT do not work. No external program was installed, so no system assigned ALT + [letter] characters shortcuts. It is probably probable that I used LEWY ALT + SHIFT shortcut for changing the language, but I can not change the language back to Polish. Prejudice all posts - yes, I was looking for information on this subject, so I got to the control panel, and further the language, region and time and what I found in the options:
    Literally, no language is available. I started Windows Update again in search of the Polish language package, but I was disappointed. There are only language packages of foreign countries and the only thing that I managed to get is the resumption of a memory flaccid in the form of svchost.exe, which I will deal with. The priority is for me to restart the possibility of writing Polish characters, because I am writing an engineering work, and without it I can write with figs with the poppy. You have to guess what the author is after his head. In any case - are there any ways? Really the last thought that comes to my head is the format, I completely do not allow such a possibility.
    My system is Windows 7. I am asking for help.
  • #2 16902174
    broziu
    Hejka, and you can not just add a keyboard layout?
  • #3 16902204
    Razormocz
    I did not try. How can you do this?
  • #4 16902221
    zibq
    Help: 83
    Rate: 181
    Oh yes:
  • #5 16902230
    broziu
    Control Panel / Region Language -> Change keyboards
    The default language -> Polish Programmer
    And at the bottom, the button -> Add
  • #6 16902241
    Razormocz
    Ah yes, I tried it. Everything would be nice if something was there:
    zibq
    Help: 83
    Rate: 181
    You did not write about it.
    Did you do some cleaning on the disk?
    If you have a carrier, try "sfc / scannow"
    If it does not help, you probably have to think about:
    safbot1st
    Help: 2719
    Rate: 1585
    Put a SMART disk with Crystal Disk Info.
    If you have a restore point - use it.
    Have you got any Windows 7 bug? I remember there are a lot of them in this regarding the disappearing language bar.
    Playing with fixing this may involve the use of CMD and the commands dism.exe, Intlcfg.exe.
    https://docs.microsoft.com/en-us/previous-ver...indows/it-pro/windows-vista/cc722068(v=ws.10)
    Maybe an infection. Do you have ctfmon.exe in processes?
    Upload the FRST.txt and Addition.txt logs from FRST:
    https://www.bleepingcomputer.com/download/farbar-recovery-scan-tool/
  • #9 16902685
    Razormocz
    You know what? I've never ever used a restore point. ON LUCK, the copy was updated the day before yesterday, before the error occurred. As you can see, it worked. The only thing that worries me is:
    I tried, sfc / scannow could not fix this error. Although it is not important now :)
    I still do not have ctfmon.exe in the processes. Generally, the topic to close, but I'm afraid that the situation may happen again. I do not remember installing external programs that eliminate the operation of the Polish keyboard or delete registers. My last question - can you save yourself from it? Create some backup on the disk? And can you make a backup on one of the disks, and then format the C drive, which creates some problems?
    You helped me and you became interested in the subject, so I gave you deserved points :) You can only inform me on these matters and I will close the topic. Greetings.
    zibq
    Help: 83
    Rate: 181
    Check the equipment as it writes @ safbot1st
    Make copies of important documents on other media.
    Making a copy of the system a bit too late, the copy is made from a stable system. At this point, as the restoration was only partially successful, I do not know if it's a good idea.
  • #11 16902763
    Razormocz
    Well, from this point the system is already quite stable. I think I will have to buy a good and roomy external drive. Well, it seemed that the case would take a few more days, but in time to restore the system gave advice. Thank you very much for your help. Best wishes and Merry Christmas :) I close the topic.
The discussion revolves around a user experiencing issues with their keyboard not typing Polish characters. Despite attempts to switch keyboard layouts using CTRL + SHIFT and ALT + SHIFT shortcuts, the user could not revert to Polish. They explored the Control Panel settings but found no available language options. Responses included suggestions to add a Polish keyboard layout, perform system checks using commands like "sfc /scannow," and consider potential system restore points. Ultimately, the user successfully restored their system to a previous state, resolving the issue, and expressed concerns about future occurrences, seeking advice on creating backups.
