Comparing Siemens and Bosch: Which Brand Offers Superior Quality?
pawelira 35393 10
Are Siemens and Bosch the same company, and is Siemens actually better quality than Bosch appliances?
Siemens and Bosch are not the same brand, but they belong to the same BSH group/company [#6228086][#6229391] The thread’s consensus is that any difference is mostly branding/positioning: Siemens is treated as the higher shelf and often costs more, but people did not notice a clear quality difference between comparable Bosch and Siemens models [#6216081][#6216433][#6274971] For equivalent appliances, compare the exact model features rather than the logo, because the practical differences may be small or unnoticeable [#6216433][#6229391] If you are choosing between near-twin models, the advice given was to buy the cheapest one or the most expensive one if you specifically want the Siemens version’s extra features [#6216433]
  • #1 6216035
    pawelira
    Rate: 40
    Are Siemens and Bosh really the same thing? because I have heard opinions that Siemens is better in terms of quality.
  • #2 6216044
    Hucul
    Help: 382
    Rate: 470
    Although Siemens and Bosch come from the same city, they are not the same.
  • #3 6216081
    popey111
    Rate: 73
    Better? Different for sure. It`s a matter of comparing specific models :) But mainly marketing :) Siemens is a higher shelf and Bosch is a lower one. There is also the gaggenau, i.e. the highest shelf :)
  • #4 6216233
    pawelira
    Rate: 40
    One of the main reasons was considering buying a dishwasher
    Supposedly twin models: Siemens 26M890 and 26T890 and Bosch 69M02 and 69T02
    Siemens is more expensive by about PLN 300-400. The question remains: is it worth it?
    One more thing, someone once wrote that models with the letter T are of worse quality. I don`t know, because their parameters are better.
  • #5 6216433
    popey111
    Rate: 73
    Personally, I didn`t notice any quality differences. If you choose "T", take a Siemens (it has an additional glass car program) and if you change it, it doesn`t matter. You can ignore the volume and water consumption, the difference will be unnoticeable. My advice is: buy the cheapest of these four or the most expensive one :)
  • #6 6228086
    Monter Nr3
    Help: 9
    Rate: 46
    Bosch and Siemens are the same (BSH means: Bosch Siemens Holding), just like Polar and Whirlpool.
  • #8 6228293
    kskrainski
    Rate: 17
    BSH products can also be found under the names Constructa and Neef
  • #9 6229391
    popey111
    Rate: 73
    bsh is one company, but individual models differ and the point is that sometimes Bosch and sometimes Siemens are more profitable. There is still gaggenau in the group :)
    and a few others :)
  • #10 6274971
    XAX
    Help: 27
    Rate: 159
    Siemens and Bosch are the same company.
    During the production process, various grilles are mounted at the end (or rotated 180 degrees) and sometimes small adjustments are made to the electronics settings.
    Siemens is a higher brand, which makes it nicer, for example, it has 100 more spins in the washing machine and costs more. If you walk around the store, if you find a Siemens, you will definitely find a similar Bosch.
  • #11 21055543
    arek_f
    Help: 5
    Rate: 22
    I am faced with the choice of household appliances. After several days of studying the topic I have chosen the following models.
    Please give me your opinion SIEMENS or BOSCH?
    Siemens:
    Oven HB774G1B1
    Microwave BF722L1B1
    or
    BOSCH:
    Oven HBG675BB1
    Microwave BEL634GB1
    Dishwasher I have chosen: Siemens SR65YX04ME (because of the kitchen area I have to have 45) and the induction hob BOSCH PIE631FB1E
    However, the oven+microwave I can't decide :( Help
Siemens and Bosch, while originating from the same parent company (BSH - Bosch Siemens Holding), are distinct brands with different market positioning. Siemens is generally perceived as a higher-end brand, offering superior features and quality, while Bosch targets a broader market with more affordable options. The discussion highlights specific models, such as Siemens 26M890 and Bosch 69M02, noting that Siemens models tend to be more expensive. Users suggest that quality differences may not be significant, and the choice often comes down to specific model comparisons. Additionally, there are mentions of other brands under BSH, such as Gaggenau, Constructa, and Neef. The conversation also includes a query about specific household appliances, comparing models from both brands.
