Vista Key Presses Opening Programs - Disable Run Window & Other Unwanted Actions
anonymousexd 35136 6
  • #1 6235868
    anonymousexd
    Help: 62
    Rate: 127
    You have accidentally turned on a program in Vis which, after pressing different letters, opens different windows ... for example, when pressing R the "run" window opens .... how can I turn it off?
  • #2 6235883
    tronic1
    IT specialist
    Help: 2640
    Rate: 1108
    Forgot what program did you install? Look for HotKey entries in the services and disable.
  • #3 6235901
  • #4 6236500
    anonymousexd
    Help: 62
    Rate: 127
    Gusioo wrote:
    Enable Sticky Keys .
    Can sticky keys be turned on by pressing shift five times?
  • #5 6236515
  • Restart restored behavior; Sticky Keys ruled out
    #6 6236722
    anonymousexd
    Help: 62
    Rate: 127
    After restarting the computer everything was back to normal.
    Then I wanted to check if the problem was caused by the keys permanently, so I pressed shift 5 times, a message appeared asking "do you want to enable the keys permanently", I replied "yes" but I did not get the same effect as before, i.e. ER keys etc. they don't turn on anything. .. So sticky keys weren't the cause of my problem, maybe you have any other ideas?
  • Intermittent startup keyboard modifier triggers shortcuts on Windows 8
    #7 12955462
    pawco
    Rate: 50
    I will refresh the topic a bit, I have the same effect on windows 8 turns on randomly when starting PC. Not every time and not every day, but it happens, the shortcuts assigned to the mouse buttons also stop working. What is responsible for it, as I mentioned, it happens after turning on the PC, I do not press anything on the keyboard and the keyboard may not work immediately and the selected letters trigger various functions. I have been using the eight for several months and this has only started to happen in the last 3 weeks. How can it be, I am asking for a hint what to turn off so that it would not happen.
The discussion revolves around a user experiencing unintended program launches in Windows Vista, triggered by specific key presses, such as the "Run" window opening when pressing 'R'. Suggestions include checking for HotKey entries in installed programs and disabling them, as well as exploring the Accessibility Center settings to manage Sticky Keys. A follow-up reveals that the user confirmed Sticky Keys were not the cause of the issue. Another participant mentions a similar problem occurring intermittently in Windows 8, where keyboard shortcuts activate unexpectedly upon startup, prompting inquiries about potential solutions to prevent this behavior.
