Keyboard Shortcuts Not Working: Persistent Keys Issue, System Restore Failure, Ctrl+C Bang Sound
Sekusz 23745 6
  • #1 15770232
    Sekusz
    Hello, the keyboard shortcuts have not been working recently. I have the same problem as my colleague on this topic https://www.elektroda.pl/rtvforum/topic2690311.html.
    Unfortunately, that topic does not say what to do, but what to enter.
    I will write that it is rather a problem with persistent keys (I probably changed something and now I do not know how to fix). I was just doing a system restore and it didn't work. When I try to do the ctrl + c keyboard shortcut all that happens is all I hear is a sound, a "bang".
    Thanks in advance for your help :)
  • #2 15770251
    master-007
    Moderator on vacation ...
    Help: 330
    Rate: 390
    Yes, you have? (You haven't written what your system is installed on).
    Uninstall the keyboard drivers from the Device Manager and then restart the computer.
  • #3 15770285
    Sekusz
    I have windows 7. Just like you have on the screen. I have uninstalled the keyboard driver a moment ago, restarted the computer and after turning it on, the driver was installed automatically, then I had to restart the computer, so I did, but the problem still persists.
  • #4 15770406
    master-007
    Help: 330
    Rate: 390
    With this setting, everything works fine for me. Just before the shortcuts started working in a different way than before, did you install or update any software? Upload a screen from "Programs and Features", perhaps one of the applications reserves shortcuts. Shortcuts not working in both Office applications and the browser? This is a laptop? If so, use the alt + ctrl + fn shortcut.
    Check out this menu:
  • #5 15771543
    Sekusz
    I just didn't install anything. All I have is, I downloaded hurt world, but a pirate, so I didn't have to install anything, just download and play. I have a computer, not a laptop. Here you have ssy:
    Keyboard Shortcuts Not Working: Persistent Keys Issue, System Restore Failure, Ctrl+C Bang Sound Keyboard Shortcuts Not Working: Persistent Keys Issue, System Restore Failure, Ctrl+C Bang Sound
    Shortcuts do not work in the browser and Office applications also do not work.
    I just noticed buttons 5 and 6 are also not working.
  • #6 15772142
    master-007
    Help: 330
    Rate: 390
    Check the filter key settings again.
    Similar problems that can be found on the web are most often resolved by refreshing the driver. Are you sure the keyboard is working? Can you connect it to another device to check?
  • #7 15772201
    Sekusz
    The keyboard is working, because I checked with a friend. I have the same as on ss'ie. I've already tried uninstalling the driver and installing it and nothing. I have the latest version of the driver.
Keyboard shortcuts are malfunctioning, specifically the Ctrl+C command, which produces an error sound instead of executing the function. The user suspects an issue with persistent keys and has attempted a system restore without success. They are using Windows 7 and have already uninstalled and reinstalled the keyboard driver, but the problem persists. Other users suggest checking filter key settings, verifying if any software updates or installations may have affected shortcut functionality, and testing the keyboard on another device to confirm its operational status. The user reports that keys 5 and 6 are also non-functional.
