The water in the washing machine smells like a septic tank ....
sujka5 56092 9
Why does water left in a washing machine smell like sewage, and how can I get rid of the odor?
The smell usually comes from residual water and detergent residues left in the hose, pump filter, and dispenser, where bacteria can grow [#6261194][#6282647][#6287947] Check and clean the pump filter regularly, because opening it drains the leftover water from the filter area [#6261194] There is always some water left in the drain hose and damp, sticky residue inside the pump/filter housing, so leaving the machine open after use can help it dry out [#6282647] One suggested fix is to run the machine empty on a hot/boil cycle with powder only, then remove the detergent/rinse-aid drawer and scrub it and its compartment thoroughly, for example with Domestos [#6291357] Washing at higher temperatures may also reduce the germs that cause the smell [#6261194]
  • #1 6252633
    sujka5
    Help: 79
    Rate: 537
    I know there are cases where people report the problem of washing machine water smells ...
    Most often, when a washing machine starts to work, it first releases the water and the remains "pound" as if from a septic tank ....
    I once bought such a washing machine from a customer and noticed that large amounts of powder (because my wife gives a lot of washing powder) "cleaned" the remains of dirty sediment that was deposited on the drain hose and the remaining water in it stinks and stinks in a specific way ...
    After about half a year, the washing machine stopped stinking, which made me happy
    this process can be accelerated by the use of professional descaling agents from time to time
    greetings.
  • #2 6258389
    sujka5
    Help: 79
    Rate: 537
    I am happy to read the opinions and other solutions about this fault, maybe someone has better ways ....
  • #3 6258645
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2657
    I am wondering about a similar story of a friend.
    2.5-year-old washing machine (5 months after the warranty - immediately after the warranty, the drain hose was replaced with a new one, because it was not possible to put in the laundry, because it smells like this). It was good for two months on the new hose. It is washed daily on average. The hose is hanging on the tub, so it is not allowed to drag anything from the sewage system. Water is not likely to be squeezed within 24 hours. The laundry is taken out immediately and you do not feel anything after washing.
    So where does this smell come from? I would understand if some rags, mops were washed (as is sometimes the case in laundries, supermarkets) and they would lie for a few days.
  • #4 6261194
    joozwa
    Help: 189
    Rate: 102
    Although the washing machine "thoroughly" pumps the water at the end of the wash cycle, a small amount of water (often with rinse aid residues and abrasion residue) remains in the washing machine's tubing, most often in the pump filter. The problem may decrease when we wash at higher temperatures, because then some of the germs that could multiply there die. After all, it is possible to clean and check the pump filter (unscrewing it causes drainage of residual water). Maybe it is worth doing it more often?
    Regards
  • #5 6262955
    MARCIN.SLASK
    Help: 1037
    Rate: 2657
    Or maybe it's just a problem with some models or that the door / lid is closing.
    Personally, I have an old Polar, I do the washing max 3 times a week, more often at 30-40 ° C, and it has never smelled like anything from the inside. Of course, I don't close the door.
  • #6 6282647
    Jędrek59
    Help: 40
    Rate: 119
    There is always a certain amount of water left in the drain hose between the pump and the highest point of the hose. After pumping out, the water from the hose flows through the pump (the pump impeller is standing) to the filter housing, connecting pipes and possibly the interior of the boiler. This water can only be removed by opening the filter, but the inside will always remain damp and covered with washing residues, and it will be sticky. I always leave the washing machine open, but occasionally I smell a specific smell and have no simple remedy for it
  • #7 6287009
    MadMixer
    It is said that it helps to dilute the rinse aid, rather than pouring it concentrated into the dispenser.
  • #8 6287078
    pgoral
    Help: 27
    Rate: 107
    Or maybe just pour a little detergent after washing?
    I have never done this in any washing machine. But maybe it's a question of drying the washing machine after washing.
  • #9 6287947
    joozwa
    Help: 189
    Rate: 102
    Current detergents are easily biodegradable and they can contribute to the growth of bacteria because they are a good medium for them.
  • #10 6291357
    bad_boy
    I had a similar problem some time ago, and the clothes were messy, I read somewhere on the net how to get rid of it, so you have to run the washing machine with only the powder without clothes and set it to cooking, in addition, remove the detergent and rinse aid drawer and scrub it thoroughly e.g. domestosem and also scrub the place (hole) where the drawer is inserted. As my previous speaker mentioned, bacteria that feed on powders are growing there, it has helped me, and this activity must be repeated from time to time.
    Regards.
The discussion revolves around the issue of unpleasant odors emanating from washing machine water, often likened to a septic tank smell. Users share experiences and potential solutions, noting that residual water and detergent buildup in hoses and filters can contribute to the problem. Recommendations include washing at higher temperatures, regularly cleaning the pump filter, and ensuring proper drying of the machine by leaving the door open. Some users suggest using diluted rinse aids and running the machine empty with detergent to eliminate odors. The conversation highlights the importance of maintenance to prevent bacterial growth from biodegradable detergents.
