Water in the paddling pool during washing - clogged drain?
WSRH 33348 7
  • #1 17948787
    WSRH
    Rate: 62
    Hello, today I had a rather strange situation, the washing machine was turned on and it was throwing out water, at that time in the shower cubicle it suddenly started to gurgling and a little water flew into the cabin, I have had a washing machine and a shower cubicle for 10 years and I have never had something like this. Today, when I entered the bathroom, I could smell sewage and the smell of "sulfur". Is it a clogged drain in the shower tray and the spiral will help? I regularly clean the siphon from the top of the shower tray and now it was like that ...
  • #2 17949520
    Madrik
    Help: 627
    Rate: 1190
    Yes, it is very possible.
    The pipe behind the connection point between the drains from the washing machine and the shower tray is rather clogged.
    Over 10 years, sewage pipes often collect thick and greasy deposits from soap, dirt, hair and all kinds of crap. If you have thin pipes for this - 50's, for example, it is a relatively low thickness coating, it greatly narrows the diameter of the pipe and makes drainage difficult.
    Probably the same thing happens when you drain the water from the shower tray, but you didn't notice because the water was flowing into the washing machine pipe.
    The spring is the minimum when plugging it in. It won't always help. Sometimes it is necessary to dismantle pipes or open an inspection and thoroughly wash, often under pressure, the sediments blocking the drain.
  • #3 17949544
    WSRH
    Rate: 62
    Only ... the washing machine and the paddling pool are on both sides of the bathroom, it is not possible to dismantle the pipes or open the inspection ...
  • #4 17949597
    r103
    Level 37  
    Help: 283
    Rate: 968
    The testimonies are slowly becoming more and more extensive - and what is closer to the sewerage riser, washing machine or paddling pool ???
  • #5 17950269
    zbich70
    Help: 1171
    Rate: 6666
    WSRH wrote:
    I have had a washing machine and a shower cubicle for 10 years and I have never had anything like it.
    How many years have you lived with a woman? Maybe explain to her (ask politely) to brush her hair before stepping into the shower. ;)
  • #6 17950368
    WSRH
    Rate: 62
    paddling pool
  • #7 17950463
    Madrik
    Help: 627
    Rate: 1190
    All that's left is rubber gloves, a large bowl or two, a mop at the ready, and a hydraulic spring in your hand.
    Disassemble the siphon under the shower tray and move the whole day towards the vertical. ;)
  • #8 17951150
    Tommy82
    Help: 455
    Rate: 1074
    How do you have your washing machine plugged in? Maybe you will reach the spring faster from this side, all the sewage holes lead to the main pipe, paraphrasing the old saying. Here you have at least two entrances behind which there is a potential blockage.
The discussion revolves around a user's experience with a washing machine and shower cubicle, where water from the washing machine caused gurgling and sewage odors in the shower. The consensus is that the issue likely stems from a clogged drain, possibly due to accumulated soap, hair, and debris over the years. Suggestions include using a hydraulic spring to clear the blockage, disassembling the siphon under the shower tray, and checking the plumbing connections for potential blockages. The conversation highlights the challenges of accessing plumbing in tight spaces and the importance of regular maintenance to prevent such issues.
