Samsung WF0600NXW: Eliminating Cesspool-Like Odor from Inlet Hose & Fast Water Deterioration
pannamigotka86 12390 22
Why does the washing machine inlet hose smell like sewage and the water go bad so fast?
The odor is most likely coming from contamination in the inlet-side filter/valve or the hose itself, so clean or replace those parts rather than blaming the drain system [#16618317][#16618948] Unscrew the inlet hose at both ends and clean the strainer in the washing machine’s solenoid valve and the strainer in the wall valve/ball valve, because deposits there can stink badly even when the tap water smells normal [#16618317][#16618948] There is always pressurized water left in the connected inlet hose, and one user found the smell right at the washing-machine-side connection/seal after a day of standing [#16619518][#16619363] If the supply valve is corroded or won’t close properly, replace it; one user also disinfected the hose with a Domestos solution and the smell stopped [#18738634] Another report says replacing the hose solved the problem, and the hose should not sit near heat sources such as central-heating or hot-water pipes [#21057162]
  • Stagnant inlet hose water causing sewage odor
    #1 16617739
    pannamigotka86
    Good day. I have a problem with the washing machine, it smells of ... cesspool for some time. After cleaning everything I could, it turned out that the bad smell came from a place I wouldn't even think about - the water supply hose! Which actually makes sense, after all, the stench does not appear until the water is tapped and disappears after the washing machine is rinsed, which I have to do before each wash. What is worse, the water "deteriorates" at an extremely fast pace, in less than a day. I unscrewed the hose today, drained the water into the bathtub and after plugging it back into the washing machine, the stench did not appear in the washing machine, which also confirms my theory that its only source is the hose, not something stuck in the washing machine. Unfortunately, I have no idea what is wrong. The hose is connected directly to the bathtub faucet (such an ordinary extra knob). Can too weak or too much open water matter? When it comes to taking water through the washing machine, I did not notice any problems.
    Any ideas?
    Thank you.
  • #2 16617809
    Kenworth 18
    Help: 2441
    Rate: 3747
    Does the water that the bathtub is filled with from this faucet also have this bad smell?
  • #3 16618116
    pannamigotka86
    No, I didn't notice anything like that. The fact that this faucet is used frequently during the day, but I suppose it would feel something from the night.
  • #4 16618142
    abart64
    Help: 271
    Rate: 633
    There is probably no "siphon" on the drain side and filling the washing machine with water pushes the air with the stench that got in overnight. Impossible that the running water stinks.
    Maybe the drain hose is poorly laid and there is no elbow where the water should stay, isolating the odors of the sewage system.
  • #5 16618317
    Kenworth 18
    Help: 2441
    Rate: 3747
    Maybe she misinterprets what the author of the topic wrote, but the author claims that the smell comes from the inlet hose and the water in it generates this smell.
    From my own experience, I can say that something similar happened to me. Well, most probably the waterworks workers removed some failure in the water supply system and after restoring the water pressure in the water supply system, the water took with it dirt that deposited on the hose filter, i.e. the strainer, the end of which is pinned to the ball valve in the wall.
    When I wanted to do the washing, the water flowed into the washing machine with less pressure, which prompted me to clean the strainer in the solenoid valve and the valve in the wall.
    It turned out that on this strainer in the wall valve there was dirt deposited probably from the remains of rotting plants or something like that and the smell was intense and unpleasant, that is, to put it simply, the stench was merciless.
  • #6 16618927
    pannamigotka86
    This is 100% not the drain hose's fault. When the washing machine is left unused for one day, the water that remains in the filter does not smell like anything, the hose is rinsed off. also feel nothing. The stench occurs only when water is being drawn. Anyway, the drain hose is not even connected to the sewage system, but inserted into the bathtub, so not much, which would probably go back. In addition, the washing machine does not smell when it is not used, but the unscrewed inlet hose - yes, the remains of water that smells like a septic tank pour out.
    What kind of strainer in the solenoid valve is it? :) The one that is on the border of the hose and the washing machine, or are there any additional solenoids? Honestly, I didn't look at them. I understand that the wall rather falls off, since the tap water is ok?
  • #7 16618948
    Kenworth 18
    Help: 2441
    Rate: 3747
    It is best to unscrew the inlet hose on both sides, i.e. from the washing machine and the battery.
    There is a strainer in the washing machine's solenoid valve, i.e. a filter that can be removed with pliers.
    With the battery in the hose screwed to it, there should be a strainer on which, in my case, these rotting and smelly remains of ... something.
    I suggest cleaning everything thoroughly.
  • #8 16619363
    pannamigotka86
    I unscrewed the hose on both sides today. From the faucet side, no smell, but from the washing machine side, there is a familiar smell at the connection / seal. So it is not so much the remnants of the water in the hose that stink as the water that lingers at the connection to the washing machine, at the seal, strainer, etc. By the way, is there a right to water in this place in a washing machine that has not been operated for a day? I turned it on today and washed everything I could on the connection, but there were no visible impurities. I have no idea why this place generates such a stench at such an express pace, since there was no permanent contamination, even limescale deposits. I don't know where the bacteria, like the ones that produce gas in the septic tank, come from because the smell is identical.
  • #9 16619518
    Kenworth 18
    Help: 2441
    Rate: 3747
    There will always be pressurized water in the connected hose to the washing machine even when the water supply is turned off. Since there is no pollution, you would have to ask your neighbors if someone is struggling with a similar case. If so, then the quality of the water supplied to the house or apartment by the water supply leaves a lot to be desired.
    If you had a toilet with a flush not mounted under the plaster, then after removing the flush cover, the situation should be analogous to that in the case of a washing machine. If you have one, you can check if this is the case.
  • Asking whether to replace the supply hoses
    #10 18115936
    samsungus
    Rate: 28
    I will dig up the topic a bit because I am struggling with the same problem as pannamigotka. It clearly stinks from the washing machine supply hose. I live at the end of the estate and, as the called water workers once told me, we are at the end and in our house, pollution from the water supply system can settle on the sieves. However, I wonder if I should replace the water supply hoses right away. Did Miss Migotka deal with the topic?
  • #11 18241457
    pannamigotka86
    I dig out the old topic - the problem has not disappeared, I am used to rinsing the washing machine before use ... I will be replacing the washing machine soon, we'll see if it changes anything.
    Samsungus and you managed to solve the problem?
    If it is really the fault of the water quality, it is very, very bad - this year I switched from bottled to tap ...
  • #12 18241678
    samsungus
    Rate: 28
    So for me the situation is as follows. The water supply valve did not work, i.e. it could not be closed due to corrosion, so I replaced it and since then, after finishing washing, I shut the water supply. At the same time, I leave the washing machine with the door open. I have disinfected the washing machine twice, then at a washing temperature of 65 ° C, and with special solutions or at a temperature of 95 ° C with two dishwasher tablets. Generally, the washing machine does not stink. Unfortunately, there is still a stench when starting the wash when the water reaches the detergent container. This is a short-lived phenomenon. For about 3-5 seconds. Some clothes smell musty after washing. Cleaning the water supply hose did not improve either. I think there is no point in replacing it, because there is a stench in the washing machine from the water supply side of the powder container. I load the washing powder directly into the chamber. I am waiting for a visit from a specialist to dispel my doubts. Let me know if replacing the washing machine helped, because I'm also close to replacing it.
  • #13 18738510
    pannamigotka86
    I know I'm digging up an old topic, but maybe you or someone else could use a little update. Although everything indicated that it stinks from the water supply hose, because the bad smell only appeared when the washing machine was drawing water, the stench had to be sucked in from the inside. It helped ... changing the washing machine ;-) I was close to disassembling the drum in order to have access to clean the space under it properly, "luckily" there was another breakdown and in good conscience I replaced the washing machine with a new one, it has been running for half a year and nothing stinks :)
  • #14 18738572
    palmus
    Help: 233
    Rate: 752
    Check if the light does not penetrate the snake to some extent. It was like that in my snake and there was some nasty stuff in the snake that created the local ecosystem. Only caustic soda helped.
  • #15 18738634
    samsungus
    Rate: 28
    In my case, so far I did not buy a new washing machine. I only replaced the water supply valve to the washing machine. The old one was open all the time and after 5 years of not using it, I discovered that closing the valve did not stop the water. Everything inside has corroded. By the way, I cleaned the hose with a solution of water with domestos and knock on everything ok for now. Clothes do not stink anymore.
  • Stagnant water in inlet hose causing sulfur smell
    #16 20509472
    shiva28
    Hello, I know this is an old topic. But I have the same problem. The rotten egg smell only comes from literally the water supply hose. The same is for new purchased dishwasher too. I discovered this smell from disconnecting the water supply from washing machine and I ran some water in a bucket and the rotten egg smell came from it, but it disappears when you pour about like liter of water, so literally the hose alone has the smell. Obviously it is connected to the cold water intake which gives water to faucet too. Faucet does not have the smell at all, and even when I disconnected the washing machine intake pipe and I tried to run water only from the pipe alone (from the place where intake water is connected for water supply) and it didn't smell at all, which is logical because the faucet water has no smell. What the hell kind of mystery it is? The source of rotten egg smell is literally the hose which provides water. How could hose alone cause this??????? We purchased dishwasher recently and I tried to check if the water supply also has rotten egg smell.. and it does, the dishwasher and water intake hose are all new. Now how it is possible? It makes no sense because if you disconnect the first part where it is connected to cold line the water does not have any bad smell. it is like the second the water enters the water hose for washing machine then it starts to rot there lol.. it smells everyday if you use washing machine or dishwasher. And as I said the smell disappears when you run the water for a little bit, like liter or two and there is no smell anymore. So the only logical explanation I currently have that water in intake hose just rots fast and that's it?? How is this possible? I don't believe replacing the intake hose will fix the problem because the smell disappears when you run the water for a little bit, and also the new dishwasher also has this smell from intake hose. Has anyone found solution to this mystery? And I don't see any logic thinking about drain hoses, if there was a problem there the water everywhere in faucet too would smell bad, drain system and water supply system are not connected at all of course, so why would only the hose itself smell bad?
  • Need for a plumber to inspect siphons and sewage lines
    #17 20937886
    mirkasvabova
    Good morning, I have the same problem. Water that smells like sewage is flowing into my washing machine. It only smells when the washing machine is turned on, after turning it off it doesn`t smell anything, the washing machine doesn`t smell, it doesn`t leak from the pipes either. The washing machine is only two years old, it is clean, there is no moldy smell. The Samsung washing machine service technician said that they don`t deal with this.
    What specialist should be called for this problem? Who is responsible for replacing/cleaning siphons, replacing pipes, and checking the sewage system? Honestly, I don`t want to list it myself, mainly I see that there are several ideas listed above, so I don`t think there is one obvious solution.
  • #18 20937905
    Kenworth 18
    Help: 2441
    Rate: 3747
    Please provide the model and manufacturer of the device.
  • #19 20937948
    Sebastian_M26
    Level 30  
    Help: 130
    Rate: 436
    Plumber.
  • #20 20938683
    mirkasvabova
    >>20937905
    Samsung WW60A3120WE washing machine.
  • #21 20938831
    Kenworth 18
    Help: 2441
    Rate: 3747
    As the problem concerns a different washing machine model, please create your own new topic because this one will be closed anyway.
  • #22 21056884
    pannamigotka86
    >>20509472
    Have you managed to solve the problem? I have replaced the washing machine, I don't use washing powders (only liquids), I often wash at 90 degrees and after a few years the problem has returned again. My hands are falling off.
  • #23 21057162
    mariukonie
    Help: 197
    Rate: 379
    Replace the hose and problem solved.
    The smell is often a result of heat so try to position the inlet hose so that it is not near a heat source, such as a central heating or hot water pipe.
The discussion revolves around a persistent cesspool-like odor emanating from the inlet hose of a Samsung washing machine, specifically the WF0600NXW model. Users report that the smell is noticeable only when the washing machine draws water, suggesting that the source of the odor is not within the machine itself but rather in the water supply hose. Various suggestions include checking for blockages or dirt in the hose and strainer, ensuring proper installation of the drain hose, and considering the quality of the water supply. Some users have experienced similar issues, leading to the conclusion that the problem may stem from contaminants in the water supply or the hose itself. Solutions discussed include cleaning the hoses, replacing the water supply valve, and in some cases, replacing the washing machine altogether. The importance of maintaining a clean and properly functioning water supply system is emphasized.
TL;DR: Studies show 80 % of washer odors originate in stagnant inlet water [EPA, 2020]; “Clean the strainers thoroughly” advises Kenworth 18 [Elektroda, Kenworth 18, post #16618948] Flush or replace hoses, clean filters, and isolate drains to stop the rotten-egg smell.
Why it matters: Ignoring the smell lets biofilm corrode parts, raise energy bills, and shorten appliance life.
• Cold-water inlet flow: Typical 8–12 L min⁻¹ [Whirlpool, 2022]. • Hose life span: Replace every ≈5 years to cut leak odds by 70 % [Consumer Reports, 2021]. • Standard inlet filter size: 60–80 µm mesh [Whirlpool, 2022]. • Biofilm can double every 20 h at 25 °C [Journal of Water Health, 2019]. • EU plumber call-out: €30–€60, parts extra [EU Home Services, 2023].
Why does the inlet hose smell like a cesspool?
Stagnant pressurised water remains trapped behind the closed solenoid valve. Anaerobic bacteria break down sulphates and create hydrogen-sulphide gas, the classic “rotten egg” odour [Elektroda, pannamigotka86, post #16618927] Without flow, biofilm grows on rubber seals and mesh filters, amplifying the smell.
Can standing water in the hose really turn foul within 24 hours?
Yes. Lab tests show bacterial counts can reach 10⁵ CFU mL⁻¹ inside a day at room temperature [Journal of Water Health, 2019]. Warm laundry rooms speed growth, so odour appears after even a single night’s pause.
How do I clean the inlet hose and strainers effectively?
  1. Close the wall valve and disconnect the hose at both ends.
  2. Remove filter screens with pliers, soak everything 30 min in 1 L hot water + 50 mL bleach.
  3. Rinse, refit, and flush 2 L through before reconnection [Elektroda, Kenworth 18, post #16618948]
Should I replace the hose or the whole washing machine?
Start with the €10–€20 hose; 5-year replacement is already advised [Consumer Reports, 2021]. Only replace the washer if odour persists after hose, filter, and drain checks—pannamigotka86 eliminated the smell by changing machines after an internal drum fault [Elektroda, pannamigotka86, post #18738510]
Could poor municipal water quality be the culprit?
Possibly. Users at the distribution line’s end reported debris on inlet screens after pressure repairs [Elektroda, Kenworth 18, post #16618317] Ask neighbours; if several homes share the smell, demand a mains flush or lab test from the supplier.
How can I tell if the smell comes from the drain side instead?
Disconnect the drain hose from the sewer and place it in a bucket. Run fill-only; if odour remains, source is supply. If smell appears during drain, faulty siphon or low hose loop is letting sewer gas back-feed [Elektroda, abart64, post #16618142]
Who do I call if DIY cleaning fails?
A licensed plumber inspects valves, siphons, and pipework; that’s the trade’s remit [Elektroda, Sebastian_M26, post #20937948] Provide model and fault notes to speed diagnosis and reduce labour time.
Does shutting the inlet valve after every wash help?
Yes. samsungus eliminated musty clothes by closing a new valve after cycles, preventing warm-room stagnation [Elektroda, samsungus, post #18738634] This simple habit also halves burst-hose risk [Consumer Reports, 2021].
What hose materials resist biofilm best?
Reinforced EPDM with an inner antibacterial lining shows 40 % lower bacterial adhesion than plain PVC [“Antimicrobial Plumbing”, 2020]. Stainless-braided hoses also stay cooler near heat pipes, slowing growth.
Edge case: Smell returns with a brand-new machine—why?
If the inlet hose runs beside a hot-water or heating pipe, heat accelerates bacterial growth. Relocating or insulating the hose solved the issue for mariukonie [Elektroda, mariukonie, post #21057162]
How often should I replace inlet hoses?
Manufacturers and insurers recommend every five years or sooner if bulging, cutting leak claims by 70 % [Consumer Reports, 2021].
What quick routine keeps the smell away long-term?
  1. After the last weekly wash, close the wall valve.
  2. Run a 60 °C empty cycle with 2 dishwasher tablets monthly.
  3. Leave the door and detergent drawer open for airflow [Elektroda, samsungus, post #18241678]
