Connecting & Soldering Tonsil MEO 55 Microphone to Input: RC Formula & Frequency Transmission
Pytong 12653 7
  • #1 6290496
    Pytong
    Level 32  
    Help: 159
    Rate: 81
    Does anyone in the group of forum members know how to solder this microphone to cooperate with the microphone input? And possibly a formula for a fixed RC for transmitted frequencies. I have a footpath, but I could not find anything more besides what below:
  • #3 6290742
    Pytong
    Level 32  
    Help: 159
    Rate: 81
    Well, it does not suit me very well, because it looks like it works with a line input. Besides, I do not know if 2.2k is for 9V? And from what follows the use here in the C2 capacitor schematic for the weight on the leg described in the microphone as WY. Besides, from the battery I will not only power it from 12V. But thanks for your interest anyway and I am waiting for further info.
  • #4 6909971
    Andrzej L.
    Help: 282
    Rate: 489
    The use of a capacitor connected from the "Wy" foot to the ground in the case of 3-pin electret microphones results in an increase in gain and a higher level of the MW output signal. from the microphone.
    Here you have https://obrazki.elektroda.pl/75_1213721051.jpg is shown on the example of the internal scheme of these tonsilowskie electrets. By downloading the signal m.cz. from the "+" foot and by blocking the resistor in the source of the field effect transistor you have a typical amplifier circuit.
    In general, the use of additional reinforcements on the external bipolar transistor added to such a microphone - when used as a CB microphone - is not serious. Then you hear on the radio full of "rectangular" modulations.
    The MeO-55 electret microphone alone gives a much higher MV voltage. in a typical system - without blocking the "Wy" foot condenser ("+" foot directly to + 12V power supply, "I" signal output from the "100" output to the current signal line)
    I made the renovation of the original pear from Alan 28, replacing the old dynamic transducer with this electret - of course, 10nF ceramic capacitors respectively + power supply 1kOhm + 47uF filter to ground and to the MeO-55 microphone in parallel 10nF to make the HF it did not follow the signal lines and nothing aroused.
    You do not need any reinforcement.
    For such a system, the MIC potentiometer Gain on the radio sets at most to 11 o'clock. Above this threshold you can already hear modulation limiter from the radio and flatten the modulation.
    With such a system, the modulation is in a vein compared to the old dynamic insert.
    There is no logical explanation for using here additional reinforcements that are in stupid fashion and then instead of the voice you hear one big gibberish and engine noise.
    The constructors of these reinforcements would listen to earlier on the second radio before they put into practice. These rectangular, distorted modulations simply knock you to the ground.
    In the case of a system with power supply through a resistor and collecting the signal from the transistor's resistor, the resistor is selected to half the voltage (more specifically, above the source potential) of the power supply (the highest signal dynamics, without unbalanced clipping of one of the signal halves) for a particular microphone.
    For example, for MeO-55 with a white dot on the + 15V power supply, half of the voltage fell for resistors around 10-13k ohm (depending on the FET parameters).
    Personally, however, I recommend the basic version without tapping the gain of the microphone itself.
    In the case of typical modern small electret, double bed electrons, it is good to only add an emitter repeater (ie no voltage gain) so that the MIC Gain input potentiometer on the radio does not truncate its mains voltage. which will be placed on the resistor in the microphone transistor, from which we collect the signal. Then people reinforce them so that everything will be lost again on the divider, which will create a resistor in the collector along with the resistance of the potentiometer MIC Gain (usually 10 KOhm)
  • #5 10556676
    biter
    What book does the microphone connection scheme come from?
  • #6 10632135
    Pytong
    Level 32  
    Help: 159
    Rate: 81
    I was taking it from the RE, but that some time has passed I'm not 100% sure.
  • #7 10635816
    biter
    Could you elaborate the abbreviation RE, give the author?
  • #8 10635927
    irekr
    Help: 1192
    Rate: 1239
    Such a monthly ......
The discussion revolves around connecting and soldering the Tonsil MEO 55 microphone to an input, specifically addressing the need for a suitable RC formula for frequency transmission. Forum members provide insights on powering the microphone with 9V, the importance of using a capacitor connected to the "Wy" foot for increased gain, and the potential issues with using a 12V battery. There are inquiries about the source of the microphone connection scheme, with references to a book and requests for clarification on abbreviations used. The conversation highlights the technical aspects of microphone circuitry, including the use of additional amplification and the effects of different configurations on output signal quality.
