Title: Connecting FD1818 Microphone to President Teddy Radio - Step-by-Step Guide & Tips
Zk123 3735 7
  • #1 18590081
    Zk123
    Hello all
    I have a problem connecting the fd 1818 microphone to radio president teddy. I'm not an electronics engineer, I don't know much about schematics. I am asking for a description of the type: red for socket no. 3, braiding for black, green for ...
    Thanks, best regards Zbyszek
  • #2 18590552
    Hektar_Zahler
    Help: 9
    After the colours, you can't.
  • #3 18590642
    don_viking
    Help: 14
    Rate: 136
    Anything is possible there are already similar topics on the forum just search. In the first link in post 6 you have the connection with the FD1818 microphone cable colours dissected in the second picture.
    FD1818 .
    In the next topic you also have in post 6 a picture with the wiring diagram of the original microphone. You can compare the diagrams and connect yourself. Read the whole topics carefully to be able to understand what they are about.
    Teddy .
    Regards.
  • #4 18590654
  • #5 18592559
    gumisie
    Help: 1667
    Rate: 2489
    @Zk123 Listen to advice Col. Novile .
    More so:
    Zk123 wrote:
    I am not an electronics engineer I know nothing about schematics
    It's a waste of money for experience.
    Outsource it to someone who knows.
    Regards.
    R.
  • #6 18593611
    Hektar_Zahler
    Help: 9
    No exaggeration. Let him show a picture of the microphone board so that the pins can be numbered.
  • #7 18593624
    gumisie
    Help: 1667
    Rate: 2489
    Marcin, you as a professional, do you need a photo?
    No kidding. :wink:
    Regards.
  • #8 18593750
    Hektar_Zahler
    Help: 9
    Must look at the photo of the board which wire where soldered if the meter can not cope. After the colors you can't do it.
The discussion revolves around connecting the FD1818 microphone to the President Teddy radio. The original poster seeks guidance on the wiring connections, specifically asking for color-coded instructions for the microphone's wiring to the radio's socket. Responses suggest that visual aids, such as photos of the circuit board, may be necessary for accurate wiring, as relying solely on color codes may not suffice.
