what will be the consequences of changing the battery to a smaller one
kocyk113 48592 21
Can I replace a 75 Ah car battery with a smaller 60 Ah battery, and will the alternator overcharge it or shorten its life?
Yes, a smaller battery can work, and it will not be overcharged just because the alternator is 120 A, because the voltage regulator keeps the charging voltage under control [#6349048] The important checks are the car manufacturer’s recommendation and whether the battery has enough starting current for the engine, especially in diesel vehicles [#6348234][#6347870] If the battery is too small for the starter demand, it may have trouble starting the car and may wear out faster or fail sooner [#6348809][#6349215] For a gasoline engine, several replies say 60 Ah is usually acceptable, and one user later reported that changing from a larger battery to a smaller one caused no problems in practice [#6348984][#19739297]
  • #1 6347866
    kocyk113
    Rate: 16
    I have a question whether if my car had a 75 ah battery so far, the change to a 60 ah battery will somehow affect the life of this battery, I note that the alternator is 120 A if it has any importance. I will also add that I still have an alternator 75 So I can put it on this smaller battery? will the battery not be overcharged?
  • #2 6347870
  • #3 6348113
    kocyk113
    Rate: 16
    thanks for answer.Now with a clear conscientiousness I will change to the smaller one and the petrol engine
  • #4 6348234
    kajoj6661
    Help: 41
    Rate: 220
    when changing the battery, see the manufacturer's recommendations for the car in which you want to change, the important thing is that the alternator is recharged and that it has the appropriate starting power (especially diesel)
  • #5 6348738
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    and I think that if you give a smaller one, it will overload it, which will damage it (it will start to heat up and boil the water)
  • #6 6348780
    goldwinger
    Help: 535
    Rate: 2101
    What is the reason for overloading it?
  • #7 6348809
    adamekamator
    Help: 7
    Rate: 64
    if it is too small with too little inrush current, it will be dealt with in a few months, it will crumble the plates and the warranty does not cover dear author, what capacity do you have or maybe you know the power of the starter
  • #8 6348984
    viper555
    Help: 582
    Rate: 2161
    After all, he wrote that gasoline, and 60Ah for gasoline, even too much. As for the alternator, the ignorant ones should not speak up if they do not know the basics
  • #9 6349044
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    In fact, the answers were given, although my colleagues were rather guided by their instincts. The questioner, perhaps for fun, asked this question. He is not interested in what car, what engine, what kind and type of battery. A fairly elderly cousin was a car that could distinguish at least by color. In this case, and this is not the case. Probably not everyone remembers, but I do, trucks with a gasoline engine with a capacity of 12 liters. If we are dealing with such a case, the advice did not come out. The existence of a 120A alternator suggests that we may be dealing with a large unit.
  • #10 6349048
    Adasku
    Help: 7
    Rate: 83
    Hello, nothing will happen to the battery, it will not overcharge, there is a voltage regulator, it holds the voltage, whether a large battery or a small one
  • #11 6349072
  • #12 6349109
    adamekamator
    Help: 7
    Rate: 64
    viper like the 4.2 engine with audi you will start 45Ah, you will not be shocked as once when you try to start there will be a boom and smoke from under the hood where after opening the hood you will see the remains of the battery so do not write that gasoline may be small capacity, certainly much smaller than diesel the same capacity
    gentlemen, the battery starts the car, it may be because it is not the battery may be larger, but not smaller
  • #13 6349135
  • #14 6349145
    adamekamator
    Help: 7
    Rate: 64
    and the author will check the start-up current and use a battery with the same start-up current, I would advise about 50A more because I know from life that the engine is started with the lights on, radio, etc., it consumes electricity
    ps. (sly loses twice)
  • #15 6349215
    dugi.1985
    Help: 31
    Rate: 71
    Simple answer: It will work, but the battery will wear out faster than the one with the capacity predicted by the manufacturer.
  • #16 6349229
  • #17 6349269
    goldwinger
    Help: 535
    Rate: 2101
    That's why I don't feel like writing on this forum
  • #18 6349334
    viper555
    Help: 582
    Rate: 2161
    Nothing more, nothing less
  • #19 6350130
    viper555
    Help: 582
    Rate: 2161
    You're right, I'm an ignorant dumbhead, I don't know spelling and I finished school for butter
  • #20 6350413
  • #21 8510531
    sobczyn
    Hello !
    I have a similar problem and I sell a car with a 1.9D diesel engine in which a 61Ah battery is factory-mounted, I have almost a new battery in it, it is a pity to give it back because it will be very useful for my second car in which there is already a 6-year-old one I want translate but this one has a capacity of 44Ah
    Will such a diesel battery do the trick, not too weak, so that I can ride it a little without any problems later, it's not my business anymore
  • #22 19739297
    kocyk113
    Rate: 16
    Dear colleagues, then I changed the battery to a smaller one and nothing happened, as it is still alive today :D, I later sold the car and the new owner uses this battery to this day: o. And this car was a two-liter omega with 115 HP engine. :)
Changing a car battery from a 75 Ah to a 60 Ah capacity may not lead to immediate issues, particularly for gasoline engines, as long as the alternator can adequately recharge the battery. Concerns about overloading and potential damage to the smaller battery were raised, with some users suggesting that a smaller battery could wear out faster or fail to provide sufficient starting power, especially in diesel engines. However, others noted that a properly functioning voltage regulator would prevent overcharging, regardless of battery size. The original poster later confirmed that after switching to the smaller battery, the vehicle continued to operate without problems.
TL;DR: Swapping a factory 75 Ah battery for a 60 Ah unit cuts reserve by only 20 %, and “the voltage regulator keeps charge constant” [Elektroda, Adasku, post #6349048] Most petrol cars crank fine if the replacement’s cold-cranking current (≥ 450 A) matches spec.
Why it matters: Right-sizing saves money and weight without cooking the battery or stranding you.
• Typical alternator output range: 90–150 A, regulated at 14.0 ± 0.2 V [Bosch, 2021]. • 60 Ah flooded batteries weigh ~15 kg vs. 75 Ah at ~18 kg—3 kg lighter [Varta Spec Sheet]. • Petrol engines under 2.0 L need ≥ 360 A CCA; diesels of equal size need ≥ 600 A [Battery Council Intl., 2022]. • Over-charging risk is controlled by the internal regulator in > 95 % of passenger-car alternators [Battery University, 2023].
Will a 60 Ah battery damage my alternator that was paired with 75 Ah?
No. The alternator’s regulator fixes voltage, not current demand. A smaller battery simply reaches full charge sooner without “overload.” [Elektroda, Adasku, post #6349048]
Does a smaller battery wear out faster?
Cycling depth rises, so service life can drop by 5-15 % if daily loads stay unchanged [Battery University, 2023]. Moderate users report normal life spans [Elektroda, kocyk113, post #19739297]
How do I check if the cold-cranking current is enough for my engine?
Match or exceed the OEM CCA figure on your original battery label. Example: 2.0 L petrol needs ~450 A; 1.9 L diesel about 600 A [Battery Council Intl., 2022].
Could a too-small battery overheat or ‘boil’?
Boiling occurs only if the regulator fails or charge voltage exceeds 14.8 V. Capacity alone does not cause overheating [Elektroda, goldwinger, post #6348780]
Edge case: What happens in a 4.2 L petrol V8 with 45 Ah?
Forum users report ‘boom and smoke’ when undersized packs collapse under 900 A starter draw [Elektroda, adamekamator, post #6349109] High-displacement engines need larger plates to handle surge current.
Does diesel always require a bigger battery?
Yes. Compression ignition needs ~40 % more starter current. Stick to the factory Ah/CCA or higher for cold starts [Battery Council Intl., 2022].
Three-step: How do I downsize safely?
  1. Verify OEM CCA spec in owner’s manual. 2. Choose equal-or-higher CCA, even if Ah is lower. 3. Measure running voltage; 13.8–14.4 V confirms regulator health [Bosch, 2021].
Will electronics or start-stop systems complain?
Modern start-stop and energy-management ECUs log battery size. Re-code module via OBD tool (VAG-COM, ISTA) when capacity changes [Delphi, 2020].
Is weight reduction worth it?
Dropping from 75 Ah to 60 Ah saves ~3 kg, equal to removing a spare tire’s worth of mass, improving fuel economy by ~0.1 % [DOE, 2022].
How much money can I save?
Average retail: 75 Ah AGM €130; 60 Ah flooded €90. Savings: ~€40, plus possible €10 shipping due to lower weight [EU Battery Price Monitor, 2023].
Can I reuse a 44 Ah battery from petrol in a 1.9 D diesel?
Not recommended. Users swapping 61 Ah to 44 Ah in diesels face hard starts after a few cold weeks [Elektroda, sobczyn, post #8510531]
