Can a car battery below 6V recover after charging – lost capacity?
zapparena 27113 9
Can a car battery that dropped to about 6–7 V be recovered after charging, or is the lost capacity permanent?
No—if a car battery has been deeply discharged to around 6–7 V and then no longer holds charge, it is usually damaged and should be replaced [#9653567][#9653659] One reply says that a regeneration charger or very long low-current charging might recover something, but the chance is small and buying a new battery is the practical solution [#9653659][#9653688] A follow-up example described batteries drained to zero voltage that still would not hold power after charging; the electrolyte turned brown and the owner eventually bought two new batteries [#9654282][#9729512]
  • #1 9653552
    zapparena
    Rate: 17
    Due to carelessness, I allowed the battery to over-discharge. I left the key in the ignition overnight with the internal blower fan on, and in the morning it turned out that the battery had about 7V. The car started without any problems (old T4 1.9TD), but since then the battery seems to have completely lost its capacity. I charged it for over 10 hours with a charger, at the end the charging current dropped from the initial 8 to 2A, then it stood overnight and the car wouldn`t start anymore. The car`s quiescent current consumption is 50mA. The car installation is efficient.
    Is there any hope that he will come back to life?
  • #2 9653567
    kkknc
    Help: 1915
    Rate: 6709
    No, the battery is damaged and needs to be replaced.
  • #3 9653659
    Paolo1976
    Help: 43
    Rate: 424
    There are rectifiers with a regeneration function, but there is little hope and it is more profitable to buy a new battery. What you have will only need to be disposed of, unfortunately.
  • #4 9653688
    ociz
    Help: 1379
    Rate: 3486
    The car started right up without any problems
    This was a mistake, if you charged it with a low current for a long time, maybe something would come out of it, and the alternator could even suffer.
  • #5 9654282
    zapparena
    Rate: 17
    GREAT WORDS!!
    OK, I`ll tell you the whole truth. :(
    There are 2 batteries in the VW T4 Multivan, min. 80Ah each, in my case the engine one was BOSCH self-service and the rear one (under the driver`s seat for the passenger compartment) was an unbranded one of traditional design. After turning the ignition, a special relay shorts the positives of both batteries for charging while driving. When you turn off the ignition, the batteries are disconnected and can be used separately for the engine and for lighting, the refrigerator and other devices inside the car. In newer models there is apparently an electronic system that disconnects them automatically when the voltage is reached. installation drops below voltage. charging. I have a simple relay that responds to the key in the ignition.
    So, by leaving the ignition switch turned on, the fans, of which there are 3 in this car (front air vent, upper passenger air vent, lower passenger air vent from the passenger section heater - I don`t remember which ones were turning) and the radio, drained both batteries to "0". The front one had 7 V, the rear one discharged until the relay coil "fell off", which is probably to about 8 V. After starting the car with the ignition on and the discharged batteries shorted the alternator took such a hit that it simply fell apart . I managed to find a kind soul, I charged one battery, unplugged the second one and drove on the highway without charging, with the lights, radio and turn signals off, avoiding pressing the stop button for 300 km. The car was running and the engine was running at 6.8V!!
    Since then, neither of the 2 batteries has held power. in Bosch the green light went out and despite charging it does not want to turn on. In the latter, I filled the electrolyte with water to the appropriate level, I charge and charge, the charging voltage is OK, the current does not drop below 2A, the electrolyte gases, the hydrometer shows that the density of the electrolyte does not want to leave the red field and the electrolyte itself is brown in color.
    I`m writing this as a warning , because I`m already done with birds. Alternator repair PLN 250 + 2 batteries 80Ah each, inadvertently :(
  • #6 9654531
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    If you consider leaving your car with the keys in the ignition (and turned on) as a nuisance, the cost of training is not high.
  • #7 9654547
    kkknc
    Help: 1915
    Rate: 6709
    I agree with my friend here. Losing the car would be more painful.
  • #8 9654565
    zapparena
    Rate: 17
    The WV Multivan version has a fold-out couch, I slept soundly inside. ;)
  • #9 9654649
    kkknc
    Help: 1915
    Rate: 6709
    Well, you would lose your car and they would demand a ransom from your family :)
  • #10 9729512
    zapparena
    Rate: 17
    decided to buy 2 new batteries :(
    Now everything works as before.
The discussion revolves around the consequences of discharging a car battery below 6V, specifically in a VW T4 1.9TD. The user experienced battery over-discharge due to leaving the ignition on overnight, resulting in a voltage drop to about 7V. Although the car initially started, the battery subsequently lost capacity and failed to start the vehicle after charging. Responses indicate that the battery is likely damaged and may need replacement, with suggestions to consider rectifiers with regeneration functions, though these offer little hope. The user later confirmed the purchase of two new batteries, restoring functionality to the vehicle.
