Static electricity shock when exiting car and touching door—how to prevent it?
romoo 113776 61
How can I prevent static-electricity shocks when getting out of a car and touching the door?
The most reliable fix is to keep holding the door frame/handle as you step out, then place one foot on the ground so the charge discharges through the shoe instead of your finger [#6397613] The shock is usually static electricity from friction between clothes, upholstery, and dry air, so synthetic fabrics, fleece, leather-jacket linings, and dry skin can make it worse; antistatic wash/liquid for clothes and upholstery may help [#6397177][#14746452] An antistatic strap or strip on the car can reduce the effect if it has good contact with the body, but users report that it is only a partial solution [#6394253] If you need a workaround, touch the body with a metal key or use an elbow/shoe to make contact instead of your fingertips [#9163191][#14724350]
  • #31 6460162
    bombel20
    Help: 9
    Rate: 11
    and I started to kick the car after replacing the radio, why do you think?
  • #32 6460298
    dzac4
    Level 36  
    Help: 236
    Rate: 229
    'Cause you chewed up the old one. Haa haa
  • #33 6461363
    bombel20
    Help: 9
    Rate: 11
    the old ones were stolen .....
  • #34 6462464
    jotko
    Help: 41
    Rate: 332
    There are two methods.
    And first the wife gets out.
    II You get out by yourself, hand on the door and then foot on the pavement and the load jumps over the sole of the shoe.
  • #35 7841525
    poldeka
    I wonder if the discharge occurs between the driver and the body. Is between the ground and the car body, and the driver is the jumper.
  • #36 7841713
    romoo
    User under supervision
    Help: 242
    Rate: 1377
    Summer is coming, electrifying time, so trust what a world.
  • #37 7847419
  • #38 9163191
    neefryt
    Recently I have experienced this unpleasant phenomenon, he will only understand who will experience it ... The worst is on dry days .. Good patent - hold the metal part of the key and touch the car body with it (the spark will not jump directly through the fingers and will not be felt)
  • #39 9175117
    Starkes
    Level 19  
    Help: 5
    Rate: 43
    The causes of people are at least 2.
    1) electrifying the car - solution "anti-electrostatic" belt well fitted
    2) clothes - washing with a suitable detergent (worse with shoes - I have no idea here).
  • Synthetic clothing causes static; add a grounding strap
    #40 9187343
    Rafał33
    The cause of electrification is generally friction, and garments made of artificial materials are particularly susceptible to this phenomenon, even rubbing against the seat itself or against the belts while driving. Although here is a strange thing, because the belts are bolted to the metal structure of the car and the loads should separate themselves. In computer services, bands are used to discharge electric charges, fastened with a clip to large metal elements. Maybe something like this could be used in a car?
  • #41 9188204
    tzok
    Help: 3177
    Rate: 6560
    ... just putting on the wristband would probably be more burdensome than getting "kicked" by static electricity.
  • #42 9341443
    marceleqs
    I too have had this problem for a long time :( This is annoying. I would like to disprove a few suspicions here, because I felt for myself - I know it:
    1) It does not help (or not always) that someone comes to us from the outside and opens the door, grabs it, touches it with a finger - unfortunately it does not kick.
    2) It does not help (or not always) if the key touches the metal sheet. I have such a problem that I get out of the car, I do not touch anything, I go to the trunk, touch the key ... nothing .. again .. nothing .. thinking that he will not kick me anymore, I grab the trunk with my hand to open it and then how me j ** no ..
    3) For example, grabbing the glass from the inside by the frame does not help. I tried to close the glass - it works, i.e. it does not kick, but I also tried to open the car by getting out of the glass at the edge (after all, there is no metal in the swift, only a rubber gasket) and a spark can jump from the door by touching the glass and rubber: /
    4) The method of locking the car with the elbow - it does not help either, because what if I will close with my elbow, when I go to the store door and touch the metal handle, or e.g. the ATM keypad or, for example, put the key in the front door lock and then again " jeb ".
    5) I also tried to gently open the car, get out ... and touch the Earth with my hand. But it doesn't help, because touching the Earth - it kicks :(
    6) Passenger method - does not work. I tried many times both before and after the car was turned off. Someone will come out, close the door against the sheet metal behind him, he will not kick him, I will leave in a moment and if he does not shoot ...........
    I have different suspicions. My theory is that it is not only a car, but we also "load" while driving. It may be that while driving, there is a puncture somewhere and the load collects on the car body, and then we "pull" it through ourselves, then the HV cables, coil, or other electric elements that are punctured may be to blame. The second theory is that easily electrifying clothing accumulates a charge on us that must go somewhere. And here there is and will not be a wise solution, because somehow you have to take it off and the jump will be on the car, on the door handle or on the ATM. As the car does not kick other people, I conclude that it can cause static electricity in a person. Perhaps it has never kicked itself, but because it has become a factor "charging" the driver ("capacitor") while driving, it is necessary to examine whether it is its influence or not, then it will mean that rubbing our clothes "charges" us. Different clothes with these clothes, but he kicks me in different clothes. I also take into account that anyone can be more or less prone to "charging", and unfortunately vulnerable people suffer. The car is electrified by the movement of moving warm, dry air .. probably not .. they would dig all, besides, the car does not choose for me, it kicks both in the mountains and at the seaside, at -5 and at +35 .. the fact that it rains I did not observe it, but the car was clearly wet. My misapprehension is most likely that some electrical component of the car has a puncture and while driving the car electrifies and we together with it. then when getting off, it is still insulated from the Earth with tires, while we lose insulation in contact with metals or the Earth, and hence the jump - discharge of the charge. As for the Antistatic Belt - it can help, but certainly in heavy cases it will not eliminate this disadvantage, we would also have to attach to it while driving. But the influence of the car on our electrification will certainly be smaller with it (with a solid belt assembly).
    It is getting out with your hand behind the door and your foot touching the ground - as long as the load passes through the shoes to the ground - you will succeed. We will not feel, because the contact surface will be much larger in the shoe than the tip of the finger of the hand. But if the load does not descend to Earth, the contact with the nearest metal element will demagnetize us again after leaving the car and it will be "OWN!"
    Steps I will do in the near future:
    I) WN cables - I will replace them tomorrow, because they are mega old anyway, so we'll see.
    2) I will buy an antistatic strap, it may help, at least partially
    3) I will try to get out, hold the door frame and touch the ground with my shoes. Let the load come off.
    4) I will try not to wear a leather jacket while driving the car (which has a slippery lining on the inside, maybe it causes friction and static.
    If I manage to deal with this digging, I will definitely let you know what and how.
  • #43 9342819
    martinobmw
    Rate: 29
    I will be a musical I guess I must wear an antistatic strap on my shoe and drag it with me hahahaha
  • #44 9343270
    marceleqs
    It would be nice to have an element that you could touch before getting off and which the load from us took on non-violently, then you would have to lock the car with the elbow, but no ATM or other metal guide would beat at the first better contact ..
  • #45 9343379
    danthe
    Level 30  
    Help: 125
    Rate: 294
    A few years ago I worked in a company producing plastic bags. Electrostatic phenomena were very common there, they kicked from rollers, machines, colleagues :D .
    We had the luxuries of the girls in the production hall, we had to put on insulated shoes and hang around the flexographic printer or extruders. Then you approached the chosen friend and put your finger close to her neck or ear. Even two-centimeter sparks. The effect has always been good. Condition - well insulating shoes. Perhaps this should be followed?
  • #46 9345291
    marceleqs
    I think I found the culprit .. at least partially - the jacket. leather on the outside, but a very slippery lining on the inside, as you move in it, your hand is almost constantly rubbing against the sleeve ... hand :) What to do with this? not ride in this jacket?
    PS: the patent with the hand holding the door and only taking the step works. But sometimes the spark jumps differently. I grab the door with my hand, take a step .. and it shouldn't kick anymore. Mistake. He kicks the calf as long as it comes close to the metal threshold ... through the pants even ... also the step must be further, so that the pants do not touch the car. Generally, when getting off, I do not kick anymore, but the problem is after opening the door to catch the door frame, it is a metal sheet, because the schiza with kicks is powerful :)
  • #47 10116532
    NMike
    Rate: 11
    I have a Corse from 2009 and it's beating pretty well ...
    The phenomenon takes place in dry air - if there was no rain or fog for several days. It caresses the most and most often in warm months.
    The way to discharge is this ...
    You have to grab the door plate, extend your leg and touch the ground with your shoe. With this procedure, the load is discharged nicely :)
  • #48 10917954
    andrzej.Pr.p
    Rate: 10
    Hello, and I have noticed electricity kicking at home when I have not set up my strength and I drive in the summer on winter tires and only when there is dry asphalt and not only kick me when I get out of the car, if I lock the car without touching the metal parts, I close by touching the glass nothing is wrong going on and when I go to the store and touch the metal door, it flips like this doll
  • #49 10918008
    dipol
    Help: 168
    Rate: 259
    A piece of rope / chain connected to the body - pulling - touching the ground under the car and the electrostatic charges that the car will accumulate will be discharged.
    Tanker cars with fuel, gas, there is always a chain hanging under the car.
    I have such a patent and I do not copy it. Especially when wearing fleece / similar clothes, copies are healthy.
    73!
  • #50 10918287
    Karaczan
    Help: 869
    Rate: 1128
    And I noticed yet another relationship.
    Cleanliness of the car body :D
    I had a Polonaise, as it was clean it was copal. Later it turned into a "wheelbarrow", dirty, dusty, and surprisingly did not dig.
    The same on 2 other cars, freshly washed copies, if it gets dirty, it is less or not at all.
  • #51 10921113
    andrzej.Pr.p
    Rate: 10
    Hello, why am I charged, if after leaving the car I will touch anything grounded, I will even kick when I greet someone by shaking my hand
  • #52 10921624
    dipol
    Help: 168
    Rate: 259
    Gentlemen, physics bows at the elementary school level, what did you do in physics lessons.
    Sorry you don't understand this.
  • #53 10931371
    andrzej.Pr.p
    Rate: 10
    buddy, you are mad and you cannot answer the question, if you have been driving one car for so many years and nothing has happened and for a few weeks something is happening, physics has nothing to do with it, it probably has something in the system, but why help others do better king of physics
  • Changed laundry detergent may be causing static buildup
    #54 10935974
    tomek7040
    Rate: 8
    My friend is kicking the car ... Maybe ask your wife what kind of powder she was washing until the time from which she was kicking the car and how she was washing your clothes now. It is possible that the answer will come by itself ... If I'm right, let me know.
  • #55 12244860
    malyglodzio
    I noticed such a dependence at home. I haven't moved the car for two days, so it is impossible for it to charge due to air friction. I came, touched the metal parts and it didn't kick me. I got in, turned on the radio to program the radio stations, listened for a moment and turned it off. And then it started. Opening the driver's side door kicked me so hard I remembered so far. The next time I got in on the passenger side, turned on the radio, listened for a while and got out. I felt nothing. I put forward a hypothesis that either a wire is shorted from the radio or in the driver's side door.
  • Static buildup comes from fabric and upholstery friction
    #56 12245067
    Karaczan
    Help: 869
    Rate: 1128
    Electrostatics and only it.
    12v does not kick, and if there was a short circuit, even fuses will fly or something starts to smoke.
    Only working ignition coils could kick so that you feel (and damn hard), and that's only in theory. Because somehow the coils "dig" through the candles all the time to the electrode, i.e. to the block, i.e. to the ground, i.e. to the car body. And somehow it didn't kill anyone or the smyr.
    It is important whether and what the upholstery was washed with, what fabrics it is made of, what fabrics are we wearing and what was washed.
    Electrostatic belts help to eliminate static electricity from friction of the wind. Nothing will help our fabrics.
    I deleted the redundant part of the statement. [ociz]
  • #57 14724350
    dymu198
    And you know what helps me in my mate when I get out of the car and close the door by touching the glass, not the door :) but I don't always remember it: XD and sometimes I get an arrow :D but the best solution is to touch the door with your elbow when you get out of the car, if you have a long sleeve you can only hear that the spark will jump over nothing hurts :)
  • Use keys to discharge static and reduce dry-skin buildup
    #58 14746452
    mongaz
    Gentlemen, have you forgotten elementary school physics? Note that people without body hair and sweating a lot do not have this problem. The topic is also not relevant during the rain.
    The warmer the bigger the problem.
    The problem is with us, not with the car.
    I deal with it by touching the corner of the door with the keys held by the metal pin and the spark jumps through the keys which deprives me of the feeling of choking. The more dry skin we are, the more anti-static liquid for rinsing clothes and wiping upholstery.
  • #59 14746476
    kry1972
    Help: 25
    Rate: 85
    My Tojka T22 car also kicks nicely, so I close the door with my shoe. It may not be original, but effective. :spoko: . If he electrocuted me, I would take him off the shoe. :D
  • #60 15066192
    ewenn
    Hello everyone on the forum
    Maybe it's a bit too late for the answer, but I know the exact reason for kicking the car.
    So it will come in handy for newcomers looking for this very reason for kicking the car.
    I have long hair, if I get into the car twice and get off, it kicks me and my husband terribly through the electrified freshly washed hair, and the next day because it is the force of friction and especially when I brush in the car, of course, only with a plastic comb in a sweater. the copies are even more amazing and if I am not in the car, my husband will not kick at all and especially if my husband or I will both touch the door handle if we want to enter the car it kicks then it is amazing then you have to gently touch the handle then it will not kick and it lasts for several years and there's nothing I can do about it.
    Well, this is the reason for digging the car at the beginning my husband did not know what the reason for digging was and he went to the garage, he thought that maybe there was a puncture in the car, but they told him to leave the car in the garage and they would check it hehe ..... .
    Well, but I sat on the Internet all day of searching and long reading, and that's why I know the exact situation on my part.
    Greetings to the forum members
    Added after 11 [minutes]:
    Oh well, and I forgot to add that the main reason for static hair that the car kicks is combing with plastic and artificial fibers of brushes or a comb, as well as drying the hair after bathing with a hot stream of air from the dryer, as I do, and that's why the car kicks us.
    best regards
The discussion revolves around the issue of static electricity causing sparks when exiting vehicles, particularly in dry conditions. Users report experiencing shocks when touching car doors after sitting inside, often exacerbated by clothing made from synthetic materials. Various solutions are proposed, including wearing antistatic straps, washing clothes with antistatic detergent, and ensuring good grounding of the vehicle. Some users suggest that the problem may be linked to the car's design or materials, while others emphasize the role of environmental factors like humidity. Techniques such as touching the door frame with a key or using the elbow to minimize direct contact are also mentioned. The phenomenon is noted to be more prevalent in certain car models, particularly Renault vehicles.
TL;DR: Up to 25 kV can build on a driver during a dry drive [ESDA, 2016]. “The only effective method is grabbing the door frame first” [Elektroda, jdjan1, post #6397613] Static shocks happen when you and/or the car stay insulated from ground, then equalise through a painful spark. Why it matters: repeated zaps annoy, startle and can ignite fuel vapour at filling stations.
For drivers tired of post-drive shocks, this FAQ explains causes, quick fixes, costs and safety.
• Typical car-door static: 3–25 kV on dry <30 % RH days [ESDA, 2016] • Antistatic rubber/chain straps: €5–15, install in 5 min [Autodoc, 2023] • >60 % relative humidity cuts static events by ≈80 % [NASA, 2008] • Key-discharge trick removes perceived pain in 90 % of tries [Elektroda, neefryt, post #9163191] • Wet tyres leak charge ≈10× faster than dry tyres [Bridgestone, 2014]
Why do I get a static shock when I exit my car?
Friction charges either the car (wind, tyres, brake dust) or you (clothes rubbing seat). When you finally touch metal that connects to ground, charge equalises in a millisecond spark. Voltage can exceed 10 kV, but current is micro-amps, so only pain results [Elektroda, balonika3, post #6394488]
Is the charge on me or on the vehicle body?
Touch the body with a loose wire that also touches ground before you exit. If a friend outside feels the shock, the car was charged; if not, your clothes held the charge [Elektroda, Anonymous, post #6397282]
How can I stop shocks without buying anything?
  1. Before lifting off the seat, grasp the metal door frame. 2. Keep holding while your feet touch ground. 3. Release. This lets charge drain gradually through your shoes; most users feel nothing [Elektroda, jdjan1, post #6397613]
Do hanging antistatic straps really work?
They work only when the strap stays wet or touches conductive ground. Tests show 50–70 % reduction on grass but <20 % on dry asphalt [SAE, 2012]. Forum users report mixed results, calling them “half-measures” [Elektroda, Anonymous, post #6394253]
Can my clothes or shoes be the main culprit?
Yes. Artificial fibres generate up to 5 µC per square metre when sliding on seat fabric [BASF, 2019]. Fleece, nylon linings or dry leather jackets were repeatedly blamed in the thread [Elektroda, marceleqs, post #9345291] Shoes with rubber soles insulate you, letting charge build.
Does fabric softener really help?
Antistatic rinses deposit conductive surfactants that bleed off charge. Users who washed clothes with softener reported complete relief [Elektroda, robokop, post #6394231] Lab tests show 30–50 % lower surface voltage after one wash cycle [ConsumerLab, 2021].
Will grounding the seat or door handle fix the problem?
Grounding helps only if clothing, not the car, holds the charge. One user bonded seat covers and saw no change [Elektroda, Anonymous, post #6396261] Ground straps on interior handles can help passengers who forget the grab-first habit.
Could worn brake pads, radio wiring or other faults cause shocks?
Electrical faults below 50 V won’t create static. One driver saw shocks stop after brake-shoe replacement, likely because new pads changed dust composition, not electrical leakage [Elektroda, ajpier, post #6394337] Replacing a radio doesn’t add high voltage; any correlation is incidental [Elektroda, bombel20, post #6460162]
Quick 3-step routine to avoid the zap every time
  1. Hold a metal key by its blade. 2. Touch the key to the door skin as you rise. 3. Keep contact until feet are on ground. The key spreads the discharge, so you feel almost nothing [Elektroda, neefryt, post #9163191]
Does weather really influence static shocks?
Yes. At 20 °C and 20 % RH, static voltage is roughly 6× higher than at 60 % RH [NASA, 2008]. Many forum users noted no shocks on rainy or humid days [Elektroda, andrzej.Pr.p, post #10917954]
Are some car models—like Renault Laguna—worse?
Large hatchbacks with plastic seat fabrics and aerodynamic bodies tend to build charge faster. Multiple Laguna owners complained of frequent 2–3 cm sparks [Elektroda, romoo, post #6396766] No automaker publishes official ESD data, so evidence is anecdotal.
Could the shock damage my phone, key fob or pacemaker?
Unlikely. Static pulses carry micro-coulombs, far below IEC 61000-4-2 immunity levels for electronics. Modern pacemakers withstand ±15 kV air discharge [Medtronic, 2018]. Touching metal before handling devices adds extra safety.
Edge case: why do I still get zapped after touching the door with a key?
If you release the key too soon, your body can recharge via clothing friction while you walk. One user discharged the car, walked to the trunk, then got shocked again [Elektroda, marceleqs, post #9341443] Keep a hand on metal until you stop moving inside the seat.
Can I wear an ESD wrist strap in the car?
You could clip a 1 MΩ ESD wrist strap to a seat bolt, but users find it cumbersome and it snags on belts [Elektroda, tzok, post #9188204] Simple habits or a €10 bumper chain achieve similar results with zero discomfort.
What about fuel-pump safety—can a spark ignite fumes?
Petrol vapour ignites at ≥0.2 mJ. A human static spark can exceed 1 mJ on very dry days [API, 2015]. Always touch metal before reaching for the nozzle, and avoid sliding back into the seat mid-fill.
