Eliminate Static Electrification in Workplace: Anti-Static Mats & Solutions for Packing Tables
majkee 66980 12
How can I prevent static discharges when packing parcels at a table without restricting workers' hand movement?
Use proper ESD grounding rather than relying only on a loose mat: a grounded strap can be worn on the leg instead of the hand, as long as the contact is stable [#2226477] The thread also suggests antistatic footwear and a conductive/grounded floor or grounded sheets on the floor, for example aluminum connected to earth, so the charge has a safe path away [#2227277][#2240971] In industrial ESD setups, workers also use protective clothing and wrist/foot bands, often with built-in 1 MΩ resistors [#2231606][#2242385] A simple “mat under the seat” is discouraged because intermittent contact can let the charge build up and then discharge suddenly [#2226477] Humidification was mentioned as a possible aid, but it was not suitable for this production area [#2219129][#2221576]
  • #1 2217996
    majkee
    Rate: 37
    in the company we have a problem with electrification which is transferred from parcels packed by people on their own. after packing a few packages and touching the metal frame of the packing table, quite strong discharges occur. You cannot use cable ties too much because the hands of the proactors must be unrestrained.
    Do you have any other ideas not hindering hand movements?
    e.g. anti-static mats or other inventions.
    thanks for your help in advance
  • #2 2219129
    wladi.klimek
    Help: 20
    Rate: 46
    Hey, see "antistatic" at www.tme.pl
    or maybe air humidification?
  • #3 2221576
    majkee
    Rate: 37
    Hi.
    Unfortunately, air humidification is not an option due to the nature of production (tea) and the size of the hall. The air is dry, that's true, but there's nothing you can do about it.
    But thanks for the hint :)
  • #4 2226477
    marek_Łódź
    Level 36  
    Help: 208
    Rate: 66
    After all, the earthing does not need to be on hand. You can put grounded handcuffs on, for example, a leg. The certainty (stability) of the contact is important. An additional advantage - they will not be able to leave the post without permission. On the other hand, I do not recommend a loose "mat under the ass" type, because after a temporary lack of contact the effect can be achieved thundering .
  • #5 2226835
    majkee
    Rate: 37
    Have you ever met something like wristbands without wires, for example with resistors discharging the accumulated charges? that would be the perfect solution :)
  • #6 2227277
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    And where would they take these loads?
    Perhaps, at best, something that would be a wristband, and a "wire" with high resistance hangs from it
    - so that touching it to something grounded does not give a noticeable discharge, but that
    caused the cargo to float away in a fraction of a second; the capacity of the human body is of the order
    1nF, static voltage a few kV, so a charge of a few uC - a current of the milliampere will discharge it within
    milliseconds, and will not be perceptible. Only when someone touches the grounded table frame with his hand so that
    does not touch this "wire" before, it will not avoid discharging despite such a device ...
    Perhaps it is better to pay attention to the floor, and to the footwear - there are special antistatic shoes, used
    eg by employees of telephone exchanges - there, too, the static was annoying.
    Question: Are ordinary rubber soled (black rubber) sandals antistatic?
  • #7 2229183
    majkee
    Rate: 37
    And is it theoretically possible that the charges on the wristband were neutralized by the resistors mounted on it?
    I think something like this would work, but is it?
    Then the charges would be released in the form of heat, but only if the current would flow through the resistors if the potential was obtained :)
    a seemingly banal subject, but only seemingly :)
  • #8 2231490
    _jta_
    Help: 3212
    Rate: 4258
    Unfortunately, the charge retention law applies - so far no exceptions have been detected,
    and changing the load into heat or heat into a load (it would also be useful) has no chance ...
  • #9 2231606
    WoŹnY
    Help: 76
    Rate: 149
    As the previous speakers say, if you do not want bands and cables, it is only a suitable substrate and protective clothing. Read what antistatic protections are used in factories of electronic parts and assemblies. The floors are very expensive and so are the clothes.
  • #10 2240444
    majkee
    Rate: 37
    And is there any way to neutralize or discharge them apart from the flow of charges to ground? These are electrons? :)
  • #11 2240971
    WoŹnY
    Help: 76
    Rate: 149
    chyab, the only known methods are good (effective) earth electrode. For example, in flextronics, the floor is made of special materials, employees use appropriate clothing, including bands, and the more endangered areas are entered through gates that check the load of the bodies and if the standard is exceeded, you must first discharge. It is no wonder that the production of high-class electronics forces us to make such moves. In your production, I would try to put some sheets on the ground, e.g. aluminum, and connect them to the ground, and maybe shoes with some conductive carbon rubber. when it works, you already know what to do.
  • #12 2242385
    Darek Dykowski
    Welcome,
    There is quite a lot of materials on ESD - one thing is certain, to properly protect electronic components (or other components sensitive to electrostatic discharges), you should use bands (for shoes, hands) and here it is important - that these bands have built-in resistors with a value of 1Mohm, I think you know why.
    In our company (Lacroix Electronics) http://www.sofrel-ems.com/
    it is very much respected
    Below is one of the websites offering such security.
    http://www.cyfronika.com.pl/narzedzia_antystatyczne.htm
The discussion revolves around addressing static electrification issues in a workplace, particularly during the packing of parcels. Users suggest various solutions, including the use of anti-static mats, grounded wristbands, and conductive footwear. Air humidification is dismissed due to production constraints. Suggestions include using grounded handcuffs on legs, conductive carbon rubber shoes, and specialized ESD protective clothing with built-in resistors. The importance of grounding and effective discharge methods is emphasized, with references to materials used in electronic component manufacturing. The conversation highlights the need for practical solutions that do not hinder movement while ensuring safety from static discharges.
