Optimal FM Frequency for Vedia A10 MP3 Player with Built-in Transmitter: Minimizing Disturbance
patrisios 148347 8
  • #1 6412089
    patrisios
    Rate: 26
    Hello! I have a Vedia A10 mp3 player (A10.Vedia.pl). It has a built-in FM transmitter. Is there any optimal FM frequency with the lowest disturbance, noise, etc. ??
    Thanks in advance for your help.
    shadow0013
    Help: 243
    Rate: 314
    Choose a frequency that is as far away as possible from strong radio stations - it depends on the region of the country where you live.
  • #3 6412256
    patrisios
    Rate: 26
    Somewhere I read that there is a frequency with the lowest noise. It was something like 100. That's right ??
    shadow0013
    Help: 243
    Rate: 314
    I have not heard such an opinion - in fact, what difference is it, whether it will be 90 or 108MHz, it is important that the frequency is as far away from the working station as possible.
  • #5 6412670
    patrisios
    Rate: 26
    OKAY. Thanks, but if anyone has anything else to say about it, go ahead ...
    gregor33315
    Help: 5
    Rate: 29
    Look on the radio for a frequency with no broadcast or a very weak station, then turn on the transmitter and set it to that frequency, and that's it. Greetings!!
  • #7 6413342
    patrisios
    Rate: 26
    I already knew that, but thanks.
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 658
    In the frequency range 88.5MHz to 108MHz, there is no concept:
    You have to know that FM it's not a band or the so-called disturbance, only the mode of transmission (modulation). FM it is nothing but a broadcast FM that is F. -frequency M. -modulation (translation in Polish).
    If you want to use the so-called FM transmitter (read: Transmitter with frequency modulation) then follow the entries of its predecessors. They tell you well.
    Greetings.
  • #9 6414161
    patrisios
    Rate: 26
    OK> Thanks.
    According to regulations, point 10.2 We close topic. [SP5ANJ]
The discussion centers around finding the optimal FM frequency for the Vedia A10 MP3 player, which features a built-in FM transmitter. Users suggest selecting a frequency that is as far away as possible from strong radio stations to minimize disturbance and noise. One user inquires about a specific frequency, such as 100 MHz, but others clarify that the exact frequency is less important than ensuring it is free from nearby broadcasts. The consensus is to scan the radio for a frequency with no or weak signals and set the transmitter accordingly.
