[Solved] FM Transmitter Interference & Noise: Solutions for Common Issues with [Brand/Model]
VoSooler 96012 8
  • #1 16586175
    VoSooler
    Help: 9
    Rate: 93
    Hello! I found a lot of topics with such a problem, but I did not find a good answer. Well, I have noises, squeaks when I connect the transmitter. The transmitter I bought:
    Can something help to hype, if it's in the wrong section, please move.
  • #2 16586194
  • #3 16586212
    VoSooler
    Help: 9
    Rate: 93
    Without charging the phone, I do not connect the jack, only the USB, but if I connect the jack it is even worse and there are squeaks and noises regardless of whether there is a sound source.
  • Suggesting warranty replacement for noisy transmitter
    #4 16586245
  • #5 16586317
    VoSooler
    Help: 9
    Rate: 93
    Do not do anything on the tile? Because I saw the resistors somewhere.
  • Recommend replacing FM transmitter with CD/MP3 radio adapter
    #6 16586325
    Cobrat
    Help: 35
    Rate: 502
    I do not know how much you spent on this device, but generally I tell you and every next one not to spend money on these toys. First of all unsatisfactory sound quality, secondly sooner or later it will stop working from like this. I threw a lot of these breasts because I wanted to keep the radio from the era. I gave so many transmitters that I would have a normal radio. He lasted the longest for 70 zlotys, probably about a year, there was no noise, no cracking, but the sound was muffled anyway. Those for 20 - 30 zlotys, they lasted a maximum of one month. After throwing money away
    and these funny transmitters, I bought a cd / mp3 radio, an adapter to not cut the installation, and finally I do not have to wrangle!
  • #7 16586512
    VoSooler
    Help: 9
    Rate: 93
    He wanted to check with this transmitter, see for yourself. And tell me how many zlotys, you can expect a good sound from cd / mp3 radio? Can you link something? I saw on Allegro the most people were taking, some for PLN 50 and I doubt that it will satisfy me, I'm involved in music (I create it) I want to hear some quality :) And do you know anything else about the transmiter cassette?
  • #8 16589934
    Cobrat
    Help: 35
    Rate: 502
    I know that there are already 50 PLN radios, but you probably can not expect miracles in the reception. Personally, my radio in a one passenger car I have just such a cheap quinola, but I do not remember the name. The sound is even ok, but the songs on the card can already mix, play or not, or break the track and I do not know what it depends on. On the other hand, I have pioneer dvh-p9999usb on the bus (a radio purchased from the Russian rags of time ago, in the times when nobody here has dreamed of such inventions, or it was terribly expensive :) ) and performs very well .. The sound is very decent, despite the standard speakers, nothing breaks off, all the songs reproduce without a problem.
    I do not want to recommend anything, but I think that for 50 PLN there is no reason to expect anything if there are any requirements ;) .
    And with the transmitter transmitter I suspect that it will be even worse, the friend once had, there was no crazy.
    These transmitters are such a cheap escape from listening to shit from the radio.
  • #9 18002058
    VoSooler
    Help: 9
    Rate: 93
    I got rid of this scrap. It's better to buy a radio, do not bother yourself with the guitar.
The discussion revolves around issues of noise and interference experienced with an FM transmitter. Users report persistent squeaks and noises, particularly when connecting via USB or jack cables. Suggestions for troubleshooting include checking the quality of the cables and considering the power converter or digital components of the device as potential sources of interference. Some participants recommend contacting the seller for a replacement or repair, while others express frustration with the overall quality of low-cost FM transmitters, advocating for investing in a better radio system instead. The conversation highlights the limitations of inexpensive transmitters and the importance of sound quality for users involved in music creation.
