[Solved] Configuring FM Frequency for New Art FM-08BT Transmitter: User's Experience
Kamcioooo 32556 9
How do I set the same FM frequency on an FM transmitter and a radio so they work together?
Set the transmitter and the radio to the same free FM frequency, for example 100 MHz, and make sure that frequency is not occupied by another station [#18137241][#18137474] If the radio is using auto-scan, switch it to manual tuning and search for the transmitter’s broadcast frequency [#18137368] Also put music on a memory card or pendrive in the transmitter so it has audio to play [#18137382] Then tune the radio to the exact frequency shown on the transmitter’s display [#18137382][#18137474]
  • #1 18133952
    Kamcioooo
    Yesterday I bought an FM transmitter. I still can't set the radio in it. What do I need to set on the transmitter and on the radio?
  • #2 18137196
    sosarek
    Help: 9320
    Rate: 15542
    How to set radio on it?
    After switching it on, it defaults to some frequency - have you tried searching for it on the radio?
    By the way, they didn't attach such a piece of paper called instructions?
    Z
    Pka, Poznań, 60-850
    gumisie
    Help: 1667
    Rate: 2486
    "To start playing music, it is enough to set the same (not occupied by another radio station) MHz frequency on the device and car radio."
  • #4 18137360
    Kamcioooo
    "To start playing music, just set the same on the device and car radio (not occupied by another radio station)
    And what to do when the car radio automatically searches for radio stations?
  • #5 18137368
    sosarek
    Help: 9320
    Rate: 15542
    Switch to manual search, by the way, if the transmitter is broadcasting something, the radio should find the frequency.
    What radio is this?
    Z
    Pka, Poznań, 60-850
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    First, you need to connect a memory card or pendrive with music, when the mp3 will be played on the radio, set the frequency that is on the transmitter's display and we can enjoy the music.
    General instructions for FM transmitters.
    • transmiter.pdf (34.24 KB) You must be logged in to download this attachment.
  • #7 18137424
    Kamcioooo
    What radio is this?
    Some old kenwood radio is already a good 8 years old :)
  • #8 18137458
    sosarek
    Help: 9320
    Rate: 15542
    Is that funny to you? Is it hard to read the model from the panel and look at the manual?
    Z
    Pka, Poznań, 60-850
    gumisie
    Help: 1667
    Rate: 2486
    Program the transmitter to some full frequency, e.g.; 100MHz, play the songs from the cards and then try to tune the radio to this frequency.
  • #10 18137808
    Kamcioooo
    Thank you, everything works as it should, I close the topic
The discussion revolves around configuring the FM frequency for the Art FM-08BT transmitter. Users share their experiences and solutions for setting up the transmitter with a car radio. The primary steps include ensuring the transmitter is powered on, selecting an unoccupied frequency on both the transmitter and the car radio, and using manual tuning if the radio automatically searches for stations. Additionally, users suggest connecting a memory card or USB drive with music to the transmitter to facilitate playback. The conversation concludes with the original poster confirming successful setup.
