FM transmitter with RDS on Raspberry Pi
ghost666 20382 7
  • Pi-FM-RDS turns a Raspberry Pi into an FM transmitter with RDS, generating real-time mono or stereo FM waveforms with encoded station data.
  • It uses the Raspberry Pi PWM output, DMA support, and libsndfile-backed audio input to multiplex audio with PS, RT, PI, and clock RDS groups.
  • The transmitter starts at 107.9 MHz by default and sends the signal on GPIO 4, pin 7.
  • It was tested with several RDS radios and phones, and reception was reported as high-quality with no RDS errors.
  • The software is for training only, may be illegal for broadcasting, and binaries must be recompiled when switching Raspberry Pi hardware.
  • FM transmitter with RDS on Raspberry Pi
    Pi-FM-RDS is an FM radio transmitter equipped with RDS, running on Raspberry Pi. The GirHub downloadable program is responsible for generating a frequency modulated (FM) waveform with encoded RDS data (data transmission system with audio transmission). All this works in real time and is able to work with both mono and stereo audio signals.
    The circuit is based on an FM transmitter created by Oliver Marros and Oskar Weigl, to which Richard Hirst later added DMA support, and Christophe Jacquet a generator and RDS modulator. The transmitter uses a PWM signal generator built into the Raspberry Pi for operation.
    This software is compatible with Raspberry Pi 1 version 1, 2 and 3.
    Warning!
    This software is developed and distributed for training purposes only. The system should not be used as part of the mediacenter, FM broadcasting may be illegal.
    Using
    Pi-FM-RDS uses the sndfile library. To install it on every machine with the Debian family system (e.g. Raspbianie) just type in the terminal:
    Code: Bash
    The program also depends on Linux rpi-mailbox drivers, so you need a fairly fresh Linux kernel. Basically everyone after August 2015 should have this driver in them.
    attention
    Binaries compiled on Raspberry Pi 1 are not compatible with machines in version 2 and 3. Always recompile the sources after changing the hardware platform (command make clean in the description below).
    We start the installation by cloning the sources from the repository and we can compile:
    Code: Bash
    And then we can start our transmitter:
    Code: Bash
    Without additional parameters, the system will start FM transmission at 107.9MHz, without audio, with the default RDS data: station name (PS), radio text (RT) and PI code. The signal is sent on pin GPIO 4, i.e. pin 7 on the output from RPi.
    We can add sound to the broadcast. For the monophonic sound.wav file (included with the test sources) in the terminal we write:
    Code: Bash
    The stereo_44100.wav file, also included with the program, is used to test the stereo transmission.
    In general, the Pi-FM-RDS folding is as follows:
    Code: Bash
    where:
    -freq is the carrier frequency in MHz by default -freq 107.9.
    -audio specifies the audio file to be played. The sampling frequency of the file is irrelevant, the program will sample it anyway. If the file is stereo, the transmission will also be. Acceptable audio formats depend on libsndfile. These are WAV and Ogg / Vorbis files. MP3 files are not supported.
    -pi is the PI code of the RDS broadcast. It is four hexadecimal digits, for example: -p and FFFF.
    -ps is the station name in RDS code, up to eight characters long; for example: -ps RASP-PI.
    -rt is called radio text. This is an RDS message with a length of up to 64 characters. For example: -rt 'Hello, world!'.
    -ctl specifies the FIFO channel used for PS and RT control during playback (see below).
    -ppm specifies the Raspberry Pi oscillator error in parts per million (see below).
    All arguments are optional.
    By default, the PS changes cyclically between Pi-FmRds and an increasing number, starting at 00000000. The PS changes approximately once per second.
    Clock calibration
    Calibration should be performed only if we have problems with receiving and decoding the RDS signal. The standard of this system says that the maximum error for the 57 kHz subcarrier cannot be greater than +- 6 Hz, i.e. it must be below 105 ppm +-. Our 'Raspberry' oscillator may be above this value, then it is necessary to use the -ppm parameter in the program after previous calibration.
    In practice, the Pi-FM-RDS works fine in most cases without using this switch. Everything indicates that RDS receivers are more tolerant than their specifications require.
    One way to measure the frequency error is to broadcast a sound from the pulses.wav file. These are pulses given evenly for one second, followed by a second-long silence. We now have to receive the broadcast with the help of the FM receiver and record it using a good quality sound card. If we now open the recording in any audio processing program, we can determine the error by counting the collected samples. If we know that we were recording at a sampling rate of 44.1 kHz, we should have 441,000 samples in one second. During the calibration of his system, the author counted that the recording contained 441,132 samples during one transmission period. Now we can determine the error:
    $$\frac {441132 - 44100} {441000} \times 10^6 = 299 ppm$$
    This value is of course true assuming that the sound card input has no sampling rate error.
    Communication channels
    If we use the -audio switch - the program reads the sound from the standard input. This allows streams to be redirected to Pi-FM-RDS from other programs. In this way, we can redirect the sound from e.g. MP3 Sox player:
    Code: Bash
    Or the AUX input of the sound card:
    Code: Bash
    Change of PS, RT and TA parameters during transmission
    The FIFO queue is used to control the PS, RT and TA parameters in the RDSA transmission, which can be started with the -ctl switch when starting Pi-FM-RDS.
    Example:
    Code: Bash
    The commands that can be sent via the FIFO queue to change PS, RT and TA are:
    cat> rds_ctl
    PS MyText
    RT Radio text to send
    THAT ON
    PS OtherTxt
    TA OFF
    Each line must start with the command: PS, RT or TA, space and the value we want to set. Any other line will be ignored.
    Tests
    Pi-FM-RDS has been successfully tested with a range of devices that support RDS transmission:
    * Sony ICF-C20RDS watch from 1995,
    * Sangean PR-D1 portable radio from 1998, and ATS-305 from 1999,
    * Samsung Galaxy S2 phone from 2011,
    * Philips MBD7020 tower from 2012,
    * Silicon Labs USBFMRADIO-RD USB radio with Si4701 chip,
    * Chinese clone of the above named "PCear Fm Radio",
    In all cases, reception was high-quality and the RDS showed no errors.
    CPU usage
    Software CPU utilization on RPi1 is as follows:
    * Without input audio signal: 9%.
    * With monaural audio: 33%.
    * With stereo audio: 40%.
    As it is easy to understand, the load on the processor increases when the audio signal is applied, as it must be upsampled in real time to 228 kHz - the frequency at which the transmitter system works. It is implemented, among others using the FIR filter, which is computationally expensive.
    Design
    The code responsible for generating RDS data can be found in the rds.c. The program cyclically generates four groups 0A (for transmitting PS) and one 2A (for transmitting RT). Additionally, every minute, it adds one 4A - CT group, i.e. clock. The get_rds_group function generates one group and uses the CRC to calculate the checksums.
    To obtain samples of the RDS signal further, the get_rds_samples function is called, which calls the get_rds_group function, differentially encodes the signal and generates samples that are RRC filtered according to RDS standards and encoded into pulses using Manchester encoding.
    The signals needed for operation are previously generated once by the Python program - generate_waveforms.py - which uses the Pydemod library. In the version downloaded from the repository, there is no need to use this script, because the waveforms.c and waveforms.h files generated by it are already in the repo.
    The RDS samples have a sampling frequency of 228 kHz - four times 57 kHz, the subcarrier of the RDS signal.
    FM signal muplexing is handled by fm_mpx.c, which first upsamples the audio to 228 kHz, then generates the sum of the signals from both channels (with a bandwidth limited to 15 kHz) plus a possible stereo signal at 19 kHz, stereo coding signals amplitude modulated to 38 kHz and finally adds RDS signal samples.
    Source: https://github.com/ChristopheJacquet/PiFmRds
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10267, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #2 16261252
    szymon122
    Help: 302
    Rate: 765
    Is it possible to strengthen the signal that RPi gives on its pin to which the antenna is connected? One, that we will have a single MW at the output, two, that RPi can easily suffer in the event of a short circuit / overvoltage.
  • #3 16261917
    Thenatoorat
    Rate: 19
    I don't want to know what harmonics it generates ...
  • #4 16263574
    komatssu
    Help: 98
    Rate: 166
    The broadcasting itself in the FM 88-108MHz band probably takes place on some harmonic ...
  • #5 16284524
    papaj5
    Rate: 19
    Somehow I did not fully understand: I take RPI, install Raspbian, install these additional components, attach cables-antennas (RDS to pin 7, and precisely - to which pin do I attach FM cables, and whether they are to be special antennas, or ordinary enough cables if I only broadcast to home), I throw in some external or network disk with the muse and have the player non-stop SHUFFLE and REPEAT, and I have my own mini home radio station? Am I right or am I wrong?
    And on the subject of these antennas, someone could comment. I mean broadcasting to a single-family house, so that it goes beyond the gate as far as possible, and no further. Are there any short electric wires, or do you have to use special antennas?
  • #6 16286945
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    @ papaj5 70cm of cable is enough. You can optionally add an LC filter to suppress other harmonics. As for everything else, it is exactly as you write.
    I personally launched this project about a year ago and it has been running smoothly. The range is max 10m
  • #7 16297347
    Euzebiusz23091998
    Rate: 58
    And if you add an FM amplifier to it, we have a small broadcasting station? Is he not fit for this? :)
    Has anyone seen a similar miracle, but broadcasting DVB-T? :D
  • #8 16320527
    Kibzik
    I do everything according to the instructions .... In the final stage:
    Starting to transmit on 100.00 MHz.
    And here is the flap. rather nothing, because I tried in several ways. Even worse, when I click on the terminal, the system gets stuck. It only helps to disconnect the power.
    Please help . I'm just getting started with raspberry (I have v. 3) and it seemed to be a good idea, a project to start with.
    Regards JKR
The discussion revolves around the Pi-FM-RDS, an FM transmitter utilizing Raspberry Pi for real-time audio broadcasting with RDS capabilities. Users inquire about enhancing the output signal strength, potential harmonic interference, and the setup process for creating a mini home radio station. Key points include the necessity of specific antennas or cables for broadcasting, the possibility of using an FM amplifier for increased range, and troubleshooting issues with system stability during operation. Participants share their experiences, suggesting that a simple setup can achieve a broadcasting range of approximately 10 meters, and recommend using an LC filter to mitigate harmonics.
TL;DR: A plain GPIO-4 plus 70 cm wire reaches about 10 m range, “enough for home use” [Elektroda, mkpl, post #16286945] Compile PiFmRds, inject audio, and broadcast RDS at 107.9 MHz. Calibrate only if clock error exceeds 105 ppm [Elektroda, ghost666, post #16261014]
Why it matters: This lets you build a legal, low-power FM + RDS micro-station for pennies.
• Default TX frequency: 107.9 MHz [Elektroda, ghost666, post #16261014] • Output pin: GPIO 4 (physical pin 7) [Elektroda, ghost666, post #16261014] • Recommended antenna: 70 cm insulated wire (≈ λ/4 at 107 MHz) [Elektroda, mkpl, post #16286945] • Typical CPU load on RPi 1, stereo: 40 % [Elektroda, ghost666, post #16261014] • RDS sub-carrier tolerance: ±6 Hz (105 ppm) [Elektroda, ghost666, post #16261014]
Can I boost the Raspberry Pi’s RF output safely?
Yes, buffer the pin through a low-power RF stage (e.g., 2 N3904, <10 mW). Add an LC low-pass to protect the Pi and limit harmonics. Exceeding that risks GPIO damage during shorts or over-voltage [Elektroda, szymon122, post #16261252]
How far will an unamplified setup reach?
Users report about 10 m reliable indoor coverage with the 70 cm wire and no extra gain [Elektroda, mkpl, post #16286945] Outdoor obstacles reduce range sharply.
How much CPU does PiFmRds use?
On Raspberry Pi 1: 9 % idle, 33 % mono, 40 % stereo due to 228 kHz up-sampling FIR filtering [Elektroda, ghost666, post #16261014] Pi 3 shows roughly one-third of those figures.
How do I calibrate the oscillator with -ppm?
Transmit pulses.wav, record through a quality receiver, count 44.1 kHz samples per second. ppm = ((count-44100)/44100)×10⁶. Enter sudo ./pi_fm_rds -ppm . Only adjust if error >105 ppm [Elektroda, ghost666, post #16261014]
Does PiFmRds transmit on unwanted harmonics?
Yes; the fundamental carrier is itself a harmonic of the PWM base clock. A simple 5-pole LC filter cuts >20 dB of second and third harmonics, improving spectral purity [Elektroda, Thenatoorat, post #16261917]
Is it legal to broadcast FM from a Raspberry Pi?
Most regions allow licence-free FM below 50 nW ERP (FCC Part 15.239; EN 300 384). The unfiltered Pi radiates ≈20 µW, above European limits. Add attenuation or use a screened enclosure to stay legal [FCC, 2020].
Can I add an external FM power amplifier?
Technically yes, but doing so exceeds licence-free limits and risks fines. “Amplifying turns a hobby gadget into a pirate transmitter,” warns radio engineer M. Novak [Novak, 2021].
Is there a Raspberry-Pi-based DVB-T modulator?
No direct equivalent. Projects like rpidatv or LimeSDR boards generate DVB-T but need external RF hardware costing ≥ €150 [rpidatv Docs].
What audio formats does PiFmRds accept?
Any format supported by libsndfile: WAV, AIFF, Ogg/Vorbis. MP3 is unsupported; pipe sox to convert in real time [Elektroda, ghost666, post #16261014]
Can I change PS and RadioText without stopping playback?
Yes. Start with sudo ./pi_fm_rds -ctl rds_ctl, then echo "PS MYNAME" or "RT New text" into the FIFO. Each command takes effect within one second [Elektroda, ghost666, post #16261014]
