Disabling a Washing Machine to Prevent Roommate Use?
zuziazła 20739 20
  • #1 6451740
    zuziazła
    As above. Tell me how to break the washing machine so that only I know what to do to make it work. I want to protect her from her roommates because they already broke the programmer...
  • #2 6451765
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    On this forum, we help in repairing this or that equipment, not in breaking or destroying it. I recommend having an honest conversation with your roommates.
  • #3 6451798
    zuziazła
    The washing machine is mine and I break or destroy it at my own risk. I would just like to know if it is possible to disconnect some cables so that it does not seem to work.
  • #4 6451818
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    I strongly discourage this type of practice. This may end badly, and not only for the washing machine. If you care so much about securing your property, please call a specialist who will install, for example, a switch in a place only known to you.
  • #5 6451858
    Damnian
    Help: 193
    Rate: 89
    For example: install a switch at the bottom of the washing machine to disconnect it from the mains. I think it`s a good idea and doesn`t interfere much with the mechanics/electronics :P
  • #6 6451891
    zuziazła
    Could I find out how to do it myself?
  • #7 6451897
    niutat
    Level 36  
    Help: 288
    Rate: 758
    But if the washing machine doesn`t work, won`t they spoil it even more by trying to start it in all sorts of ways? :wink:
    Maybe turn off the water and hide the tap knob.
  • #8 6451900
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    In exactly the same way as you connect a light switch in your house.
  • #9 6451910
    zuziazła
    I`ve already tried turning off the water tap ;/
    I know how to connect the switch, but it will be more difficult to do it in such a way that the switch is located at the bottom of the washing machine.
  • #10 6451935
    Doominus
    Help: 163
    Rate: 390
    230V reed switch and neodymium magnet.
    We glue the reed switch to the casing inside the washing machine, connect one power cable to the reed switch, the other end to the place where the power should come.
    I would protect the connections with heat shrink tubing + silicone.
    After applying a neodymium magnet to the housing (where the reed switch is hidden), the washing machine works :D
    There is no switch visible on the outside.
  • #11 6451945
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    I will say this honestly and with concern.
    Girl, give yourself a break with such modifications. If you mount the switch under the washing machine, fill it with water, it will shock you and it will be a disaster. Give it to someone to do it. Some time ago I built simple systems based on contactors and reed switches. All you had to do was place a magnet in the right place and it worked until you turned it off. But like I say, get a professional to do it.
  • #12 6451985
    zuziazła
    I have a specialist, he lives in my room ;] I will give him the idea with the reed switch, I hope he will be up to the challenge. I`ve already tried talking to my roommates, but they are extremely rude people, so I prefer this solution.
  • #13 6452000
    niutat
    Level 36  
    Help: 288
    Rate: 758
    The reed switch does not have to turn off the entire washing machine, it is enough to turn off the filling solenoid valves.
  • #14 6452046
  • #15 6452066
    Doominus
    Help: 163
    Rate: 390
    Or maybe a drum closing sensor?
  • #16 6452083
    luke666
    Help: 182
    Rate: 119
    Or maybe a key-operated ignition? The only drawback is the need to make a small hole in the casing, but you will make it clear that you do not want strangers to use the washing machine while ensuring it is well protected.
  • #17 6452122
    bartek3579
    Help: 5
    Rate: 10
    You can also put something into the washing machine that will damage your clothes (e.g. a dye). One wash like this and they won`t want to use other people`s clothes.
  • #18 6452167
    niutat
    Level 36  
    Help: 288
    Rate: 758
    I wanted to relieve the load on the reed switch because they are built for low power, the door switch turns off the entire washing machine, so it is loaded with the current consumed by the washing machine.
  • #19 6452209
    Ronin64
    Help: 248
    Rate: 349
    Apparently razor blades are good :)
  • #20 6452235
    zuziazła
    elektrit - I`m new here, this is my first topic. I hope you will have the opportunity to read a post in which I contribute something useful. For now, I`ve started a topic asking for useful advice.
  • #21 6452353
The discussion revolves around a user's request for methods to disable their washing machine to prevent roommates from using it improperly. Responses emphasize the importance of not damaging the machine and suggest alternatives such as installing a hidden switch or disconnecting specific components. Suggestions include using a reed switch with a neodymium magnet, turning off the water supply, or disconnecting the filling solenoid valves. Some participants caution against potential hazards, advocating for professional assistance. Other ideas include using a key-operated ignition or introducing a damaging substance to deter unauthorized use.
