[Solved] Samsung washing machine – red key icon, door lock won't turn off?
urbanpl4_97 59148 4
  • #1 14048832
    urbanpl4_97
    Rate: 12
    Hello, the problem is as above, there is a red key on the monitor and it does not disappear, and before that, it was enough to open the door. I have a choice of 2 buttons, ON / OFF and a washing button (see the first photo). Temp., Spin, Options and Empty buttons do not work. I immediately note that this is my first contact with this device (but it was used before) and that so far I do not have detailed information about this washing machine, i.e. the exact model, etc., but when I find it, I will write it. I add photos below:
    Samsung washing machine – red key icon, door lock won't turn off? Samsung washing machine – red key icon, door lock won't turn off?
    Thanks in advance for your help :)
  • #2 14650188
    alexandrite
    Rate: 39
    I have the same problem. The website has been with me several times and they are not able to close it.
    Does anybody have an idea?
  • #3 14650360
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    I once had an adventure with a samsung washing machine for the above-mentioned fault (the door light did not go out even though the washing machine was turned off), the heater turned out to be the fault - it had a puncture to the protective one.
  • #4 14650740
    alexandrite
    Rate: 39
    Thank you for your response. This has not yet been considered, so it's worth a try.
    Regards
  • #5 18706468
    kecajk49
    Help: 501
    Rate: 890
    The last one I had such a case, only the source was leakage to ground ....... from the MOTOR.
    The lock also did not release if the plug was not removed from the socket.
    It was enough to disconnect the protective wire from the motor, which itself has no other connection to ground, since the washing machine has a plastic tank.
    You can also replace the engine with ... a new one.
    Nobody can forbid the rich!
