Washing Machine Candy CLT362L - Locked Drum: Detachable and Laundry Blockage Solutions
kazik1993 7824 4
  • #1 16621576
    kazik1993
    I have a problem because the washing machine drum has got stuck and the laundry has run out and something must be blocked. Now the question is whether this drum is detachable?
    • Washing Machine Candy CLT362L - Locked Drum: Detachable and Laundry Blockage Solutions 15016786368411053934990.jpg (2.55 MB) You must be logged in to download this attachment.
    • Washing Machine Candy CLT362L - Locked Drum: Detachable and Laundry Blockage Solutions 1501678601515922071395.jpg (872.25 KB) You must be logged in to download this attachment.
  • #2 16622012
    stanislaw1954
    Help: 2013
    Rate: 4675
    On the picture No. 2 on the left you can see the screws.
  • #3 16622333
    kazik1993
    There is no way to reach these screws. Could it be an indelible drum?
  • #4 16622363
    Kenworth 18
    Help: 2445
    Rate: 3752
    The washing machine should be unscrewed and the tank taken out of the washing machine housing and only the tank itself can be dismantled.
  • #5 16622735
    h jaworski
    Home appliances specialist
    Help: 466
    Rate: 717
    Cannot unlock without taking apart? , the drum probably opened during spinning and got stuck. Try to remove the heater and unblock the drum through the opening. The problem has been described dozens of times in the forum.
