AA 1.5V Batteries: Where to Buy & Equipment Compatibility with 1.2V Rechargeable Cells
jareckixxi 43721 10
Can I buy AA rechargeable batteries that provide 1.5 V, and why are many devices not designed to work well with 1.2 V cells?
Yes—AA rechargeable cells with 1.5 V exist, and examples mentioned in the thread include Alcava 1.5 V AA/AAA, EcoCell 1.5 V AA, and 1.6 V Ni-Zn cells; one user pointed to a 1.5 V AA listing on Allegro, but noted the price is several times higher than обычные batteries and that a special charger may be needed [#6760071] [#6754020] [#6953401] Standard rechargeable AA cells are usually 1.2 V because of their chemistry, and a charged NiMH cell is only about 1.35 V before it drops quickly under load [#6507961] Devices are often designed around alkaline batteries because they are widely available and have a different discharge curve; some cameras even offer a battery/rechargeable mode, which changes how the device estimates remaining power and can greatly affect runtime [#6521955] The problem with many digital devices is that they shut down at a fixed voltage threshold, and 1.2 V cells reach that threshold sooner because of their lower voltage and discharge behavior [#6521385] [#6507961] Low-consumption devices like remotes may work well with 1.5 V rechargeables, but heavily discharged 1.5 V alkaline-style cells were reported to lose life quickly if discharged too far [#6953401] [#6762833]
  • #1 6507807
    jareckixxi
    are there AA 1.5V batteries?
    where can you get them?
    or 1.2V is max.
    resulting from the electrochemistry of the cell?
    btw. why manufacturers of equipment that is supposed to run on rechargeable batteries do not adjust the electronics to a lower voltage, but insist on the battery voltage of 1.5V?
  • Rechargeable AA cells are rated 1.2 V nominally
    #2 6507961
    owert
    Help: 9
    All available rechargeable batteries have this rated voltage because each cell has about 1.2V (hence 10 such cells in the battery). The charged AA rechargeable battery has about 1.35V, but the voltage drops quite quickly under load.
    Probably this is due to the fact that each equipment is designed for the widest possible group of people, so under the voltage of ordinary batteries that are generally available in most stores, in total, in any place, while rechargeable batteries are more expensive, they require a charger that also costs and not everyone can buy it. allow it and not everyone pays off.
    And what kind of equipment are we talking about now?
  • #3 6521385
    jareckixxi
    it is about mp3 players, digital cameras,
    discmany, cameras
    they often do not have a mode switch 1.2V 1.5V (actually 2.4V 3V)
    the problem is also that these are digital devices, not analog ones, and they turn off completely at a certain voltage level
    this insufficient level is achieved fairly quickly
    because this is the result of the battery discharge curve
    other than with batteries
    hence the question - is the mountain to Muhammad or Muhammad up
  • #4 6521955
    owert
    Help: 9
    discmany, cameras
    Such equipment is designed for batteries (otherwise, instead of 2 AA batteries, we would have room for 3 rechargeable batteries and then a stabilizer).
    Some devices still have these modes (but this is not a mechanical switch, but a power mode selection option in the device menu). I have a digital camera from 6 years ago and can choose whether to use batteries or rechargeable batteries - if you used rechargeable batteries and the battery mode was on, the device stopped working quickly, while when the battery mode was turned on, the device began to work for a very long time - the device was charged differently, according to a different curve, which saved energy. After all, alkaline batteries have different characteristics, and other Ni-mh batteries
  • #5 6754020
    pawel-foto
    Level 19  
    Help: 12
    Rate: 42
    They are 1.5V. For example here:
    http://www.allegro.pl/show_item.php?item=678946303
    Admittedly, it is probably something like a rechargeable battery, but 100 times it's still good. And the price is only 4x higher than the battery.
  • 1.5V rechargeable cells still need better discharge curves
    #7 6762805
    jareckixxi
    thx
    you can see that they are trying to meet customer demand
    but they still need to work on the discharge curve
    http://aphnetworks.com/review/pure_energy_xl/xlaa_tds.pdf
    http://aphnetworks.com/reviews/pure_energy_xl
    although they are already pretty good in the tests
  • #8 6762833
    Darrieus
    Help: 406
    Rate: 289
    These 1.5V alkaline perform well as long as they are not discharged over 60-70%, so not a very happy solution.
    With excessive discharge, the service life drops x10 ....
  • AK-4 charger also recharges ordinary AA/AAA cells
    #10 6953401
    hojlo1
    Help: 253
    Rate: 181
    For several years I have been using:
    - Alcava 1.5V AA / AAA
    - EcoCell 1.5V AA
    ... and they work great where energy consumption is low (remote controls, etc.).
    However, the charger (I have AK-4) for these batteries is also a curiosity.
    For several years now, they have also been using it to charge ordinary AA / AAA batteries
    (of course - at your own risk).
    The effect is that for several years I have not bought a battery (I also have a lot of 1.2V batteries) and, for example, a used AAA battery fully charged (there is a LED indicator) can in the remote control and walk for 1/2 year.
    Recently, I experienced another pleasant surprise - 2 AA 1.5V Energizers in my digital camera were used up (after several hundred photos), after charging I put it back in and took about 150 photos and they still work.
    It is such a curiosity (and rather with a charger). :D
  • #11 20712911
    jancio1973
    Rate: 27
    No curiosity, it has always been known that alkaline batteries can be recharged, and the more often and less they are discharged, the better and the more times they can be regenerated. Of course, we do not charge with any charger, only, for example, dedicated to rechargeable batteries.
AA batteries typically have a nominal voltage of 1.5V, while rechargeable NiMH batteries have a nominal voltage of 1.2V, which can rise to about 1.35V when fully charged. Many digital devices, such as MP3 players and cameras, are designed to operate on 1.5V alkaline batteries and do not accommodate the lower voltage of rechargeable cells, leading to rapid shutdowns when the voltage drops. Some devices offer a mode selection for battery types, but this is not universal. Alternatives like 1.6V Ni-Zn batteries exist but may not be widely available. Brands like Energizer and EcoCell offer 1.5V rechargeable options, which can perform well in low-energy devices. Users have noted that alkaline batteries can be recharged under specific conditions, although this is not recommended without a proper charger.
