[Solved] Checking AA & AAA Energizer Ultimate Lithium Batteries Using Meter - Voltage Standards & Settings
asziatko 53512 15
How do I check whether Energizer Ultimate Lithium AA/AAA batteries are still good with this multimeter, and what voltage/range should I use?
Yes—you can check them by measuring DC voltage on a range above the cell voltage, e.g. 2.5 V DC, or use the meter’s 1.5 V battery-test position marked GOOD/REPLACE [#6956792] [#16941038] A healthy 1.5 V cell should read about 1.50 V, and a fresh one can be a bit higher, even up to about 1.7 V; a discharged cell will read lower [#6957314] [#16941560] The GOOD/REPLACE scale is only a quick check, not an absolute judgment, and the meaning of “good” depends on the device that will use the battery [#16941038] [#16942637] For a more reliable test, measure the battery under load with a small lamp or suitable resistor, because some cells can show correct open-circuit voltage but still fail to supply useful current [#6957475] [#6957469] The meter can be used on 1.5 V and 9 V battery settings, but always select a voltage range higher than the battery being tested to avoid damaging the meter [#16941038]
  • #1 6956719
    asziatko
    Help: 7
    Rate: 176
    I have a pair (I do not know if good) batteries, both AA and AAA Energizer Ultimate Lithium, I know I used them, but how many and for what I do not remember - and I do not want to throw away good batteries, what I gave for them :D . I have a meter like below
    it has BATT for battery check. I just admit that I do not know how to find out on this meter whether the battery is good or to be thrown away.
    It is possible to use this meter to check whether the above-mentioned batteries are good, e.g. if they have the right voltage, what voltage should it be and how to set the meter then?
    Greetings,
    Arthur
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    Of course. Set the range of 2.5V on the left side with the gray background and measure the voltage.
  • #3 6957293
    asziatko
    Help: 7
    Rate: 176
    I set myself to 2.5V and checked the batteries and each of them shows that it has a value of 150 on the black AC DC bar of the meter, that's a good battery, is it good voltage ?.
    How would it be or will be used, the value will be lower?
    piterus99
    Help: 1084
    Rate: 328
    not 150 and 1.50V, it's a good battery. Discharged it would be lower.
  • #5 6957329
    asziatko
    Help: 7
    Rate: 176
    Oops, blunder on my part, 1.50V is supposed to be.
    Thanks for the help.
    kasjo
    Help: 94
    Rate: 89
    As for me, when measuring the battery, you should not pay attention only to the voltage value. Always measures the short-circuit current of the battery. Many times I have encountered batteries that had the correct voltage and even 100mA of current could not be removed from them.
    Lutek49
    Level 36  
    Help: 440
    Rate: 407
    You can measure the voltage under load for a more precise check of the battery condition. As a load, you can use a 1.2V bulb or a properly selected resistor.
    shogun
    or maybe the meter in the photo adds such a load itself, after all, it has a scale for batteries (REPLACE and GOOD), i.e. REPLACE and GOOD, you just need to confidently select it on the BATT 1.5 knob
  • #9 6957567
    asziatko
    Help: 7
    Rate: 176
    And on my meter you can also measure the short-circuit current of the battery?
    Yes, there is an option like checking the battery. I also checked this option and all batteries were GOOD (good) there was no clue until the end, but there was a clue in the middle of GOOD.
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    After all, measuring tension is more effective than color pictures. At least there is no tolerance just a pure voltage reading.
    Ronin64
    Help: 248
    Rate: 349
    I confirm :) Short-circuit current measurement gives a clear picture of the state of a given cell.
    Using a meter’s 1.5 V battery test range
    #12 16941038
    matrixluk
    Rate: 33
    First of all, with any DC voltage meter, you can measure such a battery by measuring the voltage.
    In turn, in this meter you have the option of "quick" checking the battery whether it is good or to be "thrown away" ;)
    With the batteries in the fingers, that is, the 1.5V voltage is set as shown in the photo and by applying the meter tips:
    + to battery plus, - meter tips to battery minus.
    The pointer should lean towards GOOD, if good, the better, the more it will lean to the right :)
    The weaker the battery, the pointer will deflect less and less to the right.
    The field on the gauge "?" it is the limit of good or bad battery. The REPLACE field is a bad battery, to be replaced.
    On your meter you can measure "fast" 1.5V and 9V batteries (setting one to the left from the current one)
    Remember about the poles of the battery and the tips of the meter so that the pointer deflects well :)
    Generally, without it, by switching the meter to the given voltage, you can measure "every" battery / accumulator.
    Set the meter so that the voltage of the battery being measured is not higher than that set in the meter!
    You can damage your meter (most of the fuse will blow, but it's better not to risk it!)
    For example, for a 12V battery, set 50V DC (dc constant voltage - where the polarity is "+" and "-"),
    setting the voltage lower than 12V, i.e. 10V DC, for example, is a risk of damaging the meter!
    For alternating voltage, you set the AC voltages as much, more or as much as the equipment under test, never less!
    With higher voltages, be careful not to touch! (e.g. 50V up :) )
    japycz321
    Help: 92
    Rate: 141
    Unfortunately not. This meter has a range of up to 250mA, which is too little even for a battery.
    You could measure the voltage drop across a known resistance and calculate the current. But it's not worth doing something like that.
    Use a load test to verify battery condition
    #14 16941560
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    There used to be a battery test meter that showed voltage and had a button to load the battery - you read the voltage and pressed the button for a moment to see if it would drop a lot under load. You can connect the meter to the battery, attach a load (e.g. a lamp from a flashlight) to it for a while and watch how the voltage drops.
    The new "1.5V" cell gives a slightly higher voltage - even up to 1.7V - and this voltage indicates that the cell has not been used, but it is appropriate to have a tested meter, because it happens that it is incorrectly calibrated and shows incorrectly, modern digital meters hold better calibration, the old analog ones were sometimes mediocre in this respect.
    wieswas
    Help: 240
    Rate: 400
    The term "good" or "bad" is a relative term.
    The same link for a camera may not work. The camera itself measures its voltage at a certain load and will flash "Low Battery" or similar and turn off. The wireless mouse will stutter.
    Inserting such a link into an LCD wall clock will allow the clock to run for six months.
  • #16 17111090
    asziatko
    Help: 7
    Rate: 176
    I bought an electronic meter with a digital display showing the voltage V, how much the battery has - a 1.5V and 9V battery tester.
The discussion revolves around testing the condition of AA and AAA Energizer Ultimate Lithium batteries using a multimeter. The user seeks guidance on how to determine if the batteries are still good or should be discarded. Responses suggest setting the multimeter to a 2.5V range to measure the voltage, with a healthy battery showing around 1.5V. It is emphasized that voltage alone may not be sufficient; measuring short-circuit current under load can provide a clearer indication of battery health. Users also mention the importance of ensuring the meter is calibrated correctly and that new batteries may show voltages slightly above 1.5V. Various methods for testing, including using a load or checking the meter's built-in battery test function, are discussed.
