Standard Battery Voltages: Common Values for AA, AAA, 9V, Li-ion, Lead Acid
357 9
What standard voltage ratings are batteries available in?
Batteries are not available at one single standard voltage; a single cell can be anywhere from about 1 volt to almost 5 volts depending on the chemistry, and higher-voltage packs are made by connecting cells in series [#21681871][#21681879] AAs and AAAs are commonly 1.2 V nominal, though they are around 1.5 V when first used [#21681879] A 9 V battery is 9 V nominal [#21681879] To run a 3.3 V or 5 V system, you can combine AAs in packs of 3 or 4 [#21681879] Larger packs can be much higher, such as six 2 V cells in series for 12 V, or an electric vehicle battery made from many lithium cells in series to reach around 300 V [#21681871][#21681875]
  • #1 21681870
    Jaisal Jacob
  • Clarifying battery chemistry and load requirements
    #2 21681871
    Rick Curl
  • #3 21681872
    David Ashton
  • #4 21681873
    Jaisal Jacob
  • #5 21681874
    Jaisal Jacob
  • #6 21681875
    David Ashton
  • #7 21681876
    Jaisal Jacob
  • #8 21681877
    Rick Curl
  • #9 21681878
    Roy Jennifer
  • Common battery voltages and pack sizing guidance
    #10 21681879
    Clifford ytruyt
Battery voltages vary widely depending on chemistry and configuration. Common single-cell voltages range from about 1.2V nominal for alkaline AA and AAA cells (approximately 1.5V when fresh) to nearly 5V for some chemistries. Standard 9V batteries provide a nominal 9 volts. Rechargeable lithium-ion cells typically have nominal voltages around 3.6 to 3.7V per cell and are often combined in series to achieve higher voltages, such as the approximately 300V battery packs used in electric vehicles. Lead-acid cells commonly provide about 2V per cell, with six cells connected in series to form a 12V battery. Battery packs are designed by connecting multiple cells in series or parallel to meet specific voltage and current requirements. Factors influencing battery choice include rechargeability, current capacity, size, weight, cost, longevity, and safety considerations. Resources such as batteryuniversity.com and teardown videos of brands like Tesla provide detailed insights into battery construction and voltage standards.
