Excel VBA Macro: Adding Rows in TABLE1 & TABLE2 with Button - Add More Rows Function
kikanek 13122 15
How can I make an Excel VBA button add one row to the specific Excel table it is placed under when I have multiple tables on the same worksheet?
Make the macro target the table identified by the button’s own code name or table name, instead of a fixed range, so each button works with its corresponding table [#17288479] The reply suggests choosing the appropriate example and using the name/identifier that belongs to the table the button refers to, because that is what distinguishes TABLE1 from TABLE2 [#17288479] If you want to expand it further, the macro can be reworked to add a fixed number of rows from a defined limit (for example, `If ilewrs > 10 Then Exit Sub`) [#17289178] Rows should be deleted one at a time from the last row to preserve order [#17289178] It is also possible to add code that prevents deleting the first row of the table [#17290444]
  • #1 17288182
    kikanek
    I have a problem, I have two tables in the file called "TABLE1" and "TABLE2"
    I want to add a button that will be under each table and its function will be to add more rows (one row)
    I have a macro like below,
    however, it only works for the first table. For the second one, which is 3 lines below, no longer ...
    How can this be solved?
    Sub WstawWierszTABELA1()
    Dim ost&, ile&
    ost = Range("Bytowa2").Rows.Count + 3
    ile = 1
    Rows(ost & ":" & ost + ile - 1).Insert CopyOrigin:=xlFormatFromLeftOrAbove
    End Sub
    Thanks for the help
  • #2 17288221
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    1. Attaching a sample data file - they do not have to be real, but they must have the target data layout in the sheet (s)
    2. The above will also explain exactly whether when you write about tables, you mean data lists or "most ordinary" excel table-tables - data lists have additional vba commands to handle them, ordinary tables only "standard"
  • #3 17288293
    kikanek
    Thank you for your willingness to help,
    the table is created in excel by "insert tables"
    an example file in the attachment
    in the target version there are other tables below for which I also want to make such a button
    • tabela.xlsx (16.13 KB) You must be logged in to download this attachment.
  • #4 17288319
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    So these are letters, and yet they add poems "by themselves" ...?
    Are you planning to insert something only manually, or can you "by some mechanism" transfer something to the list / list from another place of the sheet / notebook?
  • #5 17288337
    kikanek
    I want the macro to add another row in the table after the button (above the "SUM" row). So that each table has its own button
    I had to save the above file xlsx because xlsm did not pass here.
  • #6 17288392
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    Oki, but if you place the cursor in a given table, you already have a blank input line prepared by default, this is how table-list works.
    Excel VBA Macro: Adding Rows in TABLE1 & TABLE2 with Button - Add More Rows FunctionNowy wiers...tabeli.jpg (22.31 kB)You must be logged in to download this attachment.
    1. Do you mean, then, that apart from the line with an asterisk, the macro will insert an additional empty line as "next" (then there will be two empty lines, including one with an asterisk)?
    2. Is it enough just to place the cursor on the line with an asterisk (after making an entry, a new one will appear anyway with an asterisk)?
  • #7 17288406
    kikanek
    1. I click the "Add line" button
    2. The macro adds one row above the total row, leaving cell formatting. In this case, it numbers the next row in the first column from the machine and leaves the second empty
    Run the macro that is in the file, you will see.
    The problem is that when I insert this macro and assign a range to it, "Table2" inserts me into the first table anyway
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    You have two examples, choose the one that suits you or adjust to your own needs.
    tabela..zip (15.65 kB)You must be logged in to download this attachment.
    Look at the names of the buttons, not the buttons themselves, but their code names - each of them has the name of the table it refers to - this is the identifier:
    Excel VBA Macro: Adding Rows in TABLE1 & TABLE2 with Button - Add More Rows FunctionNazwy przy..ków.jpg (30.06 kB)You must be logged in to download this attachment.
  • #9 17288582
    kikanek
    It's great, and tell me how to make the same macro "add add line" so that it adds 5 lines at a time
    I would like to give you a button to delete lines as too much is added
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    A little macro rework:
    tabela..zip (18.43 kB)You must be logged in to download this attachment.
    Lines can be added from a strictly defined range that you set by yourself ("If ilewrs> 10 Then Exit Sub").
    Delete rows only one at a time, from the last one to keep order.
  • #11 17289912
    kikanek
    It's really awesome :)
    Tell me, is there any chance to add a line of code to delete so that the first line in the table cannot be deleted?
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    Chance (?) ... not rather not ... but it is possible ... :) ... to add a line of code to prevent deletion of the 1st line, one of the following:
    Code: text
    tabela..zip (18.38 kB)You must be logged in to download this attachment.
  • #13 17689965
    jend
    I have a similar problem as a colleague .. I have a dozen or so tables in one sheet .. I need to add 2 lines to each of them .. is it possible to insert two lines from the machine under each table, in the left column to enter the text FROM and the right column it would be empty. So, just like colleagues, the lines are numbered consecutively, instead of the numbering, the word FROM and the second column are empty and in the second line the word DO and the column are empty. screen in the attachment Excel VBA Macro: Adding Rows in TABLE1 & TABLE2 with Button - Add More Rows Function
  • #14 17690285
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    jend wrote:
    ... add 2 lines to each of them ... from the automat, insert two lines under each table ...
    That is, where to insert ... into the table or under the table?
    Prepare an example with a minimum of 3-4 tables on the worksheet.
  • #15 17883627
    mario123321123321
    I'd like to use your solution with the "add line" macro, but I can't handle it (I'm totally green in Excel).
    When I want to attach your macro, I get the error "Run-time error '9'. Subscript out of range" and after clicking debug I get this:
    can you write step by step how to implement your macro in my sheet?
  • #16 17890684
    lanzul
    Level 30  
    Help: 199
    Rate: 123
    Include any authoritative example that raises this error, maybe it's just a matter of the appropriate table name (variable nameTBL) or maybe something else.
The discussion revolves around creating an Excel VBA macro to add rows to two tables, "TABLE1" and "TABLE2," using buttons placed beneath each table. The initial macro provided only functions for "TABLE1," leading to inquiries about modifying it to work for both tables. Users seek clarification on whether the tables are standard Excel tables or data lists, and how to ensure the macro adds rows correctly above the total row while maintaining formatting. Suggestions include checking button code names for proper table identification and modifying the macro to add multiple rows or prevent deletion of the first row. Additional users express similar needs for adding rows to multiple tables and seek guidance on implementing the macro without encountering errors.
TL;DR: To add rows to Excel tables with per-table buttons, loop inserts (e.g., 10 rows max) and "Delete rows only one at a time". For Excel VBA users fixing misdirected inserts, Error 9, and Totals-row issues. [Elektroda, lanzul, post #17289178]
Why it matters: Clean table automation preserves totals, prevents errors, and speeds up daily data entry.
  • Excel worksheets support up to 1,048,576 rows; plan insert limits to avoid hitting hard caps. [“Excel specifications and limits”]
  • Use ListObjects.ListRows.Add to append rows that inherit table formatting and formulas. [“ListObject.ListRows.Add method (Excel)”]
  • Map each button to its table by matching the button’s code name to the ListObject name. [Elektroda, lanzul, post #17288479]
  • Run-time error '9' usually means the table name variable is wrong or the object isn't found. [Elektroda, lanzul, post #17890684]
  • Cap growth with a guard (e.g., If ilewrs > 10 Then Exit Sub) to keep tables tidy. [Elektroda, lanzul, post #17289178]
How do I add a new row to a specific Excel Table (ListObject) with a button?
Assign a button to a macro that targets the table by name. How-To: 1. Insert a Form Control button beside the table and assign a macro. 2. In a module: Sub AddRow_TABLE1(): ActiveSheet.ListObjects("TABLE1").ListRows.Add. 3. Test; the new row appears inside the table before Totals if shown. [“ListObject.ListRows.Add method (Excel)”]
Why does my macro insert into the first table instead of TABLE2?
This happens when the macro inserts worksheet rows or uses a named range tied to the first table. Target the ListObject directly, not sheet rows. Name each button after its table and route by that identifier. Then TABLE2’s button updates only TABLE2. [Elektroda, lanzul, post #17288479]
How can I add a row above the Totals row and keep formatting?
Use the table’s DataBodyRange. ListRows.Add inserts into the DataBodyRange, which sits above the Totals row. The inserted row inherits table formatting and participates in structured formulas. Keep the Totals row enabled; DataBodyRange always excludes it. [“ListObject.DataBodyRange property (Excel)”]
How do I add five rows at once with a button?
Loop the add operation. In your button macro, run ListRows.Add five times or use For i = 1 To 5. Add a guard like If ilewrs > 10 Then Exit Sub to limit growth. This pattern solved multi-add requirements in the thread. [Elektroda, lanzul, post #17289178]
How can I prevent deleting the first row in a table?
Add a guard at the start of your delete macro: If ActiveSheet.ListObjects(nazwaTBL).ListRows.Count = 1 Then Exit Sub. This stops deletion when only one data row remains. [Elektroda, lanzul, post #17290444]
How do I delete rows safely from a Table with a button?
Delete from the end to preserve order and numbering. "Delete rows only one at a time" to keep structure consistent. Implement the button to remove the last ListRow on each click. [Elektroda, lanzul, post #17289178]
What causes Run-time error '9' (Subscript out of range) in this setup?
Your code is referencing a sheet or ListObject that doesn't exist. Check the table name variable matches the actual ListObject name. Confirm the correct worksheet/workbook context before calling ListObjects. Fixing the name resolves the error. [Elektroda, lanzul, post #17890684]
How do I name buttons so each targets its own table?
Use the button’s code name as a routing key. Name the button exactly like the target table (e.g., TABLE2). In your handler, act on the ListObject that matches the control’s code name. Each button then controls only its table. [Elektroda, lanzul, post #17288479]
Can I just use the built-in asterisk new row instead of a macro?
Yes. When the cursor is in a table, Excel displays a blank input row marked with an asterisk. Entering data there automatically creates a new table row. Use a macro only for custom numbering, limits, or multi-add actions. [Elektroda, lanzul, post #17288392]
How can I add 'FROM' and 'DO' rows under multiple tables automatically?
Loop each ListObject on the worksheet. For each table, add two rows and set the first-column values to FROM and DO. Leave the other cells blank as needed. Run the macro once to update all tables in the sheet. [“Worksheet.ListObjects property (Excel)”]
Why should I prefer ListObjects over inserting worksheet rows?
Rows.Insert shifts whole worksheet rows and can break table alignment or totals. ListObjects.ListRows.Add adds a real table row, preserving structured references and layout. Use the table API when operating inside Excel tables. [“ListObject.ListRows.Add method (Excel)”]
What’s the maximum table size I should plan for when adding rows via VBA?
Excel worksheets hold up to 1,048,576 rows. Keep headroom for the header and optional Totals row. If your process might approach this limit, add safeguards to stop inserts and notify users to avoid failures. [“Excel specifications and limits”]
